Symmetry and range of interaction
In summary, if symmetry is exact, the gauge bosons are massless and the interaction is long range. When gauge symmetry is broken, the gauge bosons acquire mass and the interaction becomes short range. However, there are exceptions such as in the case of the strong force, where confinement restricts the actions of the gluons making up the quarks. This means that the range of the force is determined by the range of the force acting on the quarks, not the nucleons. This concept can also be understood by considering the effects of mass on gravity, where a massless particle can travel a relatively longer distance due to less gravitational pull.
Lepton_vn
I have just read a book. It said that: "if symmetry is exact, interaction is a long range". Could you explain me more detailed? Thanks!
You're going to need to provide a longer context.
Does it refer to gauge symmetry?
If gauge symmetry is exact, the gauge bosons are massless so interaction is long range; if gauge symmetry is broken, the gauge bosons get mass and interaction becomes short range.
that's probably what the book means, although it's wrong! QCD has an "exact" gauge symmetry and yet the force is short-ranged due to confinement. And while we're at it, the phrase "exact symmetries" includes "spontaneously broken" symmetries!
I think your book lied to you! :mad:
I think you need to be little more careful here. It's certainly true that the force between nucleons is short-ranged. However, nucleons have 0 charge under the strong force. Using nucleons to judge the range of a force is like saying the electromagnetic force is short-ranged because atoms have to be close to each other to feel such forces. What matters is the range of the force which acts on the quarks making up nucleons; and, this is a much subtler question.
It is, however, possible to create a quark-gluon plasma (if you're at high enough temperature and pressure), in which quarks no longer remain bound. Since there's no confinement here, it should be much clearer that the strong force is, in fact, long-ranged.
Please note that the careful assessment released by experimental groups does not claim discovery of a QGP. This seems to contradict at least "naive" expectations dating back to the design of the machines. It therefore not so obvious that your claim holds even in principle.
Besides, it's important to maintain distinction of phases. Gluons, photons, etc. are massless in the absence of any other matter, including any potential condensates.
However, I think Phiphy managed to guess the OP's intent --- good work sir :-) For a first level understanding of things, I think it's fairly to say that exact gauge symmetry => massless bosons. It's a useful rule of thumb until you have to face reality :-p
Yep, I was just trying to guess the meaning of the sentence. And I guess the OP's book may well be a popular science book. I agree that it is too sloppy to make a statement like this using the not well defined terms like "long range".
That's right. But i don't understand why if gauge bosons are massless then interaction is long range and vice versa ? Could you explain more clearly? If it is possible, can you prove by using mathematics?
The introduction of a mass causes a dropoff of the effective range of the mediated particle. Effectivel, the range drops as ~[tex]e^{-x m}[/tex] (give or take a few parameters). For instance, a massive photon would give rise to a modified Coulomb potential that looks like: [tex]\frac{1}{r}e^{-x m}[/tex]. For m=0, the exponential dropoff vanishes and we have long-ranged behavior again.
I agree with you in full. I think exact symmetry means when you cannot distinguish the three types of intermediate vector bosons (W+,W-, Z0 particles). They are long range since existing as quarks, they are massless but acquire masses as the symmetry is broken. In this case, they become short range forces. The strong force is an exception as you rightly said since the property of confinement restricts the actions of the glouns making up the quarks. great insight
I think we could make this more logical for him than mathematical. We know that gravity is brought on by the presence of mass and that gravity attracts and thus drops distances a mass is to travel. If we have, let's say, zero mass, there is very little gravitational pullback on the particle and the particle is capable of traveling a relatively longer distance. think you got me.
Here we are not discussing the color force's broken symmetry. In fact there's no way to achieve such high temperatures. Put simply, because the gluons are contained in the neutron and proton. they cannot be used to predict the range. anything coming out of the neutron or proton will be a quark-antiquark pair and we could presume that since the pion is the lightest possible meson, it's possible to use them for range calculation. the range of the gluon is indeed short (it is considered the acrrier of the strong force).
The color force doesn't have a broken symmetry. That's kind of the point here. The finite range of internucleon interactions is essentially a result of the fact that nucleons are uncolored states. This is much like the fact that a neutral atom will neither be attracted nor repelled by a net charge.
As for quark-gluon plasmas, I was under the impression that the consensus view was that they have, in fact, been created in heave atom collisions at RHIC.
Finally, confinement, in and of itself, is not sufficient to say that the interaction is short-ranged. It is, in fact, quite possible to write down a model of an SU(3) gauge theory in which the quarks are able to be separated to arbitrary distance (given, of course, that there's a way to give them sufficient energy). What is necessary is that all quarks in the model have mass much greater than the strong coupling scale of the theory (which, in QCD, is approximately the pion mass). In this case, the fragmentation of a bound state (which is what really restricts the range of the fundamental interaction in normal QCD) is suppressed by a factor of [itex]e^{-m_q^{\phantom{q}2}/\Lambda^2}[/itex]. Models like this are generally referred to as "quirk" models. (See, for instance, http://arxiv.org/abs/0805.4642.)
1. What is symmetry in the context of interactions?
Symmetry in the context of interactions refers to the balance or correspondence between the properties of two interacting objects or systems. This can include properties such as shape, size, orientation, and motion.
2. How does symmetry affect the range of interaction between two objects?
The symmetry between two objects can affect the range of interaction between them, as it determines the strength and type of force that they exert on each other. Objects with more symmetry may have a longer range of interaction, while those with less symmetry may have a shorter range.
3. What are the different types of symmetries that can influence interactions?
There are several types of symmetries that can influence interactions, including rotational symmetry, translational symmetry, and reflection symmetry. These symmetries can be present in different forms, such as mirror symmetry, rotational symmetry around a specific axis, or translational symmetry along a specific direction.
4. Can symmetries exist in electromagnetic interactions?
Yes, symmetries can exist in electromagnetic interactions. For example, the laws of electromagnetism exhibit symmetry under both time reversal and charge conjugation. This means that the laws are the same whether time is moving forward or backward, and whether particles are replaced with their antiparticles.
5. How do scientists study the symmetries and range of interaction between particles?
Scientists use various experimental methods, such as particle accelerators and detectors, to study the symmetries and range of interaction between particles. They also use theoretical models and calculations, such as quantum field theory, to understand and predict these interactions based on the symmetries present.
  • High Energy, Nuclear, Particle Physics
  • Atomic and Condensed Matter
