Consider 2 dipoles separated by a distance of atleast 2 light minutes
In summary, the conversation discusses the behavior of two dipoles, A and B, separated by a distance of at least 2 light minutes. As the distance between the opposite charges in dipole A increases, the field strength also increases and travels to dipole B. By combining the charges of dipole A to neutralize it, there is no opposite reaction for the motion of dipole B, resulting in non-conservation of momentum.
aizen___
Consider 2 dipoles separated by a distance of atleast 2 light minutes or so .
we can call the 1st dipole A .
the distance btw the opposite charges is small so the field strength is weak same for the other dipole B .
Now we increase the distance btw the charges in dipole A so the field strength increases and it travels to B.
at the exact time it reaches B we increase the distance btw the charges of the dipole B . so due to the Field which has reached B it statrs accelerating let's say in the positive x direction.
Now due to the increase distances btw the charges at B the filed generated by B starts traveling towards A .
BUT if we combine the charges at A effectively Neturalising it there won't be any charge for the field to act on .
BUT MOMENTUM is not conserved in this case because only b is moving and nothing is moving in the opposite direction.??
Science news on Phys.org
Yes, momentum is not conserved in this case. Momentum is only conserved when there is an equal and opposite reaction. Since the charges of dipole A are combined to neutralize it, there is no opposite reaction for the motion of dipole B, and thus momentum is not conserved.
I would like to clarify that the concept of momentum is not applicable to electric fields. Momentum is a property of matter in motion, and electric fields do not possess mass or motion. Therefore, the statement "MOMENTUM is not conserved in this case because only B is moving and nothing is moving in the opposite direction" is incorrect.
Furthermore, the scenario described in the content is not physically possible. The charges in dipole A cannot be effectively neutralized without affecting the charges in dipole B. The electric field generated by dipole A will still act on the charges in dipole B, even if the distance between the charges in dipole A is increased. This is because electric fields have an infinite range and do not require a physical connection between charges to exert a force.
In conclusion, the content presents a flawed understanding of electric fields and momentum. As scientists, it is important to accurately represent scientific concepts and avoid making assumptions or incorrect statements.
1. What is a dipole?
A dipole is a pair of equal and opposite charges or poles that are separated by a distance. It is a type of electric or magnetic field that occurs due to the separation of these charges or poles.
2. Why are the dipoles separated by a distance of at least 2 light minutes?
The distance of 2 light minutes is chosen because it is a significant distance that allows for the study of the interaction between the dipoles without any external interference. It also allows for a measurable amount of time for any changes in the dipoles to be observed.
3. How does the distance between the dipoles affect their interaction?
The distance between the dipoles plays a crucial role in determining the strength of their interaction. The closer the dipoles are, the stronger the interaction will be. As the distance increases, the strength of the interaction decreases.
4. What is the significance of using light minutes as a unit of measurement for the distance between the dipoles?
Light minutes are used as a unit of measurement because they represent a significant distance in space that can be easily visualized. It also allows for a better understanding of the effects of distance on the interaction between the dipoles.
5. Can the interaction between the dipoles be affected by other factors besides distance?
Yes, the interaction between the dipoles can be affected by other factors such as the strength of the individual charges or poles, the orientation of the dipoles, and the presence of any external fields or forces.
  • Classical Physics
  • Electromagnetism
