What would the universe be like if c were not uniform
In summary, if the speed of light was not invariant for all observers, the universe would be Newtonian rather than Einsteinian.
bobsmith76
336
I sort of understand Einstein's theory of relativity. I'm trying to visualize what the universe would be like if the speed of light were added on to moving objects. objects are moving in so many directions that it's hard to understand how one would even add the speed of light on to a motion. for example, our galaxy is moving in a direction, our sun is moving around the galaxy's center, and we're moving around the sun and moving around our Earth's axis. i suppose if visual light were added on to movement it might just be too confusing, but i cannot exactly imagine how.
Are you asking what would happen if basically, the universe had a minimum speed, the speed of light?
Well, for one, physics wouldn't exist because interactions would be impossible.
No, I'm asking what would happen if the speed of life depended on how fast observer is going.
Do you mean speed of light?
Well, you'd basically go back to classical mechanics/classical electrodynamics. At our human scale, nothing would really change.
how about on a non-human scale?
Well, there would exist no "relativistic context" so far high energy and massive objects at the planetary/solar/galactic scale, the world would be just like Newtonian physics would predict.
Then again, it makes a difference if you say "what if the speed of light was not invariant for all observers" vs. "what if there was no maximum speed limit". The former still allows you to have general relativity and all that. The latter wouldn't allow you to have relativity.
Non-relativistic quantum mechanics would stay the same. Depending on whether or not you picked the former or latter choice above, you may or may not be able to keep most of relativistic quantum mechanics unchanged.
even now i think our universe doesn't add up everything to 'c' it jus appear that way. sorry i am a non believer. :)
What does "add up everything to 'c'" even mean?
bobsmith76 said:
Re: what would the universe be like if c were not uniform
The non local speed of light, i.e. the speed of light between two points, in a gravitational field is NOT uniform. Only the local speed of light, i.e. the speed of light at a point, is always the same.
If the speed of light was not uniform , the relation between time and space which was constructed in the relativity theory will be destroyed and we will get an absolute space and absolute time.
This constant value of the speed of light is the real deep link between Time "t" and Position "x" for anybody , and without it we return back to the old ages of classical physics.
This thread is confusing.
As I understand bobsmith's question, he means, what would happen if Einstein's postulate about the speed of light were wrong.
I am far from being able to answer that.
However - I do understand the guy's question. It's a good approach, I think. It's sometimes very hard to understand Einsteins postulate "c is constant in every inertial frame". It might make sense then to ask: what would happen if it weren't the case? I think that's what he means.
in a similar way, one could ask: How come the gravitational force is proportional to r^-2. Why not r^-2.00...1?
Because - apparently, nothing would be able to exist as we know it, were it the case. (that's at least what I understood).
Still haven't understood the answer though.
The simple answer is that if light's velocity depended on the speed of the observor, the universe would be "Newtonian" rather than "Einsteinian". That is, classical physics would apply.
As far as cosmology goes nobody seriously tries to do Newtonian cosmology anymore. I imagine a few old problems, such as Olber's paradox, would arise again if you tried.
You'd probably wind up with a finite sized universe like a large version of our solar system. One which would have a center, maybe you could arrange to have the Earth at the center of it:).
You'd have to throw out a bunch of actual observations and measurements though, including pretty much all of modern cosmology (and the associated observations), but if you shut your eyes to all these contradictory measurements that are trying to wake you up and telling you "it's not really like that", I suppose it could be peaceful.
And what about the possibility of one catching his own emitted light? Doesn't that lead to a crazy paradox? :-)
There are a few documented cases from the early days of jet aircraft where a pilot fired a forward facing machine gun, then out-distanced his bullets and turned into their path, thus shooting his own aircraft. If light speed were not invariant then the same thing would be possible and no more paradoxical
Well, it's true that assuming that something that is impossible happens (like catching up with a light beam in a vacuum while at the same time using the rules of relativity) does lead to crazy results, the problem is that a false assumption can be used to prove anything.
Other than that, I'm not quite sure what the question is, or why.
1. What is the significance of c not being uniform in the universe?
If the speed of light, c, is not uniform in the universe, it would have significant implications for our understanding of the laws of physics. This is because the speed of light is considered a fundamental constant and is used in many equations to describe the behavior of matter and energy in the universe.
2. How would the behavior of light and other electromagnetic radiation change if c was not uniform?
If the speed of light was not uniform, the behavior of light and other forms of electromagnetic radiation would also change. It could result in different wavelengths of light traveling at different speeds, which would affect how we perceive and measure light in the universe.
3. Would the concept of time and space be affected if c was not uniform?
Yes, if the speed of light was not uniform, it would have a significant impact on our understanding of time and space. This is because the speed of light is used as a universal constant to measure time and space in the theory of relativity.
4. How would the expansion of the universe be affected if c was not uniform?
The expansion of the universe is currently described by the theory of general relativity, which relies on the assumption that the speed of light is constant. If c was not uniform, it would have a profound effect on our understanding of the expansion of the universe and could potentially change our predictions for the future of the universe.
5. Are there any theories or evidence that suggest c is not actually uniform in the universe?
Currently, there is no evidence or widely accepted theories that suggest the speed of light is not uniform in the universe. However, there is ongoing research and debates in the scientific community about the possibility of c varying in different regions of the universe or in different time periods. Further studies and observations are needed to fully understand the true nature of the speed of light in the universe.
