New Reply
velocity in a pipe via a pressure test.
Share Thread Thread Tools
Jan31-13, 04:02 PM   #1
Okay i'm currently doing a thrust block design for a water supply system. The new line is a 250mm line. The water is fed from water towers where council has said the operating head is about 30m. I've set up my thrust block program in excel and it is all working fine. The only trouble is i'm unsure on exactly what flowrate/velocity of the water in the new pipeline to calculate the thrust.
Now i was thinking the best way to do it was to solve with bernouli's with two unknown V's.
and simultainiously solve for v1 = v2a2/a1 and vice versa. but was thinking maybe there might be a better way.
I do have a pressure test from a current line in the area where the new line is going. The information from the pressure test is as follows:
65mm line
Flow rate/second (L/s) Pressure (kpa)
0 220
5 185
10 125
15 0
16.5 (open) 0
So using this pressure test, is it possible to gain the velocity of water in a 250mm line under similar conditions? or do i use the approximate 30m head in there to calc it instead? I may have to go to council and get more info off them but i struggled enough to get the pressure test.
If anyone can help that would be great! Cheers.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> A quantum simulator for magnetic materials
>> Atomic-scale investigations solve key puzzle of LED efficiency
>> Error sought & found: State-of-the-art measurement technique optimised
Jan31-13, 06:04 PM   #2
Sorry i just relised that the pressure test formatting didnt come out right...
So it was a 65mm pipe
fully closed valve = 220kpa
running 5 l/s = 185 kpa
running 10 l/s = 125 kpa
running 15 l/s = 0 kpa
Fully open running 16.5 l/s = 0 kpa
So what i'm chasing is a velocity in a 250mm line in order to accurately calculate thrust in the pipe. We have an estimated head in water towers of 30m and the pressure test in the above.
Can any one help?
Hope this has clarified things a bit.
Cheers!
New Reply
Tags
flow, pipe, pipeflow, thrust blocks, velocity of fluid
Thread Tools
Similar Threads for: velocity in a pipe via a pressure test.
Thread Forum Replies
Air pressure and velocity in a pipe Classical Physics 0
How do you relate the flow velocity through a pipe with the pressure of the resvoir? General Physics 2
Flow through a pipe, pressure, velocity, Bernoulli, etc... Introductory Physics Homework 0
Pressure Drop vs Velocity in a Rectangular Pipe General Engineering 3
