Water transfer printing activator ideas
In summary, the conversation discussed the process of water transfer printing and the need for an activator to dissolve the PVA film and adhere the ink layer to the object being printed on. The most popular chemicals used in the activator were listed and the possibility of using coalescing agents or plasticizers was mentioned. It was suggested to try Texanol as an alternative to the hard-to-find phalates and the potential benefits of using a plasticizer with a higher boiling point were discussed.
japcarmaniac
hi, I am from scotland uk and have little chemistry knowledge so i hope I've posted in the right section to start lol.
as in the uk I am finding it difficult to get activator for water transfer printing. there a few formulas that can be mixed up by myself but id rather be able to understand why these chemicals are needed and perhaps be able to make my own. for those who are unaware water transfer printing is basicly a sheet of PVA with an image printed on one side. this film is placed in warm water and an ACTIVATOR is sprayed over it to dissolve the PVA and leave behind the ink and its adhesive so that an object can be placed into it and coated in the image.
so at a glance i need to be able to dissolve the PVA. I've looked at many formulas and the most popular chemicals i can see in them are
xylene
isobutanol
mek
ethyl acetate
butoxyethanol
what i do know is that my chemicals would need to be non soluble in water. I've seen the msds iof an activator sold in aerosol form and its 70% butoxyethanol. i have no idea what the other 30% could be.
any help would be most appreciated and i hope to learn a thing or two.
thanks in advance
derek
Likes mortiz
Chemistry news on Phys.org
xylene
isobutanol
mek
ethyl acetate
butoxyethanol
thanks in advance
derek
Derek,
You have it backwards a bit. The print on the PVA sheet is placed PVA side down in hot water. The hot water dissolves the PVA leaving the ink layer behind. The hydrophobic ink floats on the hot water and the part is pushed through the thin film. The water pressure adheres the ink layer onto the irregular surface of the part. In the old days, this ink layer was thermally bonded to the part in a subsequent step but the newest version of the process uses an "activator" to soften the ink layer, allowing it to bond to the part. The "activator" is acutally a plasticizer dissolved in a volatile solvent that is sprayed onto the ink layer while it floats on the surface of the hot water. Hot water speeds up the solvent evaporation (xylene, MEK, butoxyethanol for example) and also speeds up the plasticizer's softening of the ink layer. The plasticizer also softens the primer which has been applied to the part and helps to create a strong bond.
In latex type paints, these plasticizers are referred to as coalescing agents and could probably be used in your process. Search for coalescing agents (Texanol for example) that have limited water solubility and you are likely on the right track. I've seen dimethyl- and diethyl phthalate used in water transfer printing as an "activator" but I think something like Texanol is a bit safer.
Hope it's helpful.
Likes mortiz
dimethyl- and diethyl phthalate are extremely hard to find here in the uk. if a plasticiser needed the arent those other formulas I've been looking at useless? here is one
xylene 50%
isobutanol 9%
mek 12%
ethylacetate 29%
Likes mortiz
I don't know enough about the polymers used in the dye to tell you. You've listed some solvents with varying volatility. The boiling points are:
xylene 140C
isobutanol 108C
mek 80C
ethylacetate 77C
The boiling points of the plasticizers I mentioned are:
Dimethylphthalate 284C
Diethylphthalate 298C
Texanol 254C
Notice anything different about them? The water transfer is performed a elevated temperature, not high enough to boil away these solvents but I'm sure they evaporate pretty quickly. The plasticizers stick around for a lot longer and are likely much more effecient at softening or tackifying the dye layer.
If you can't get the phalates, perhaps you should try Texanol. You CAN get that in the UK.
Likes mortiz
hi, first off thanks for the help i really appreciate it. I've found a company who can supply the texanol here in the uk.
am i right in assuming that if the solvent has a higher boiling point then it will hang around longer than one with a shorter boiling point and with texanol added that should give a longer window of time for dipping and also more 'pliability'.
all i need to do now is experiment with mixtures and i don't think ill need as my chemicals as i first thought although i did here that the reason all those solvents are used is to make it more universal to different grades of pva film.
here is another formula i have
65% ethyl acetate
15% butoxyethanol
20% BBzP. <-- possibly replace with texanol? i can get bbzp but its £150 a litre:(
Likes mortiz and (deleted member)
I think the solvent is around so that you can evenly apply small amounts of the plasticizer using simple equipment like an aerosol can. The solvent dilutes it and allows it to be sprayed evenly. Use too much and the ink will be soft for a long time and might need extended heat treatment for it to firm up on the part. The Texanol or plasticizer or coalescing agent helps to soften the polymer matrix of the ink and to bond it to the primer on the part. My point about the boiling point was to show you that the solvents are made to go away and leave the plasticizer behind. The plasticizer has a much lower volatility so it sticks around to do it's thing.
Very likely. Since I only have what you write here to judge your understanding of the process I'll make the following observation. It might be common practice to refer to the design on a PVA film as a "PVA film" but I doubt the ink layer is itself composed of PVA. The PVA layer is there to provide support for the otherwise gossamer ink layer and allow it's manipulation without damaging it. Once it is placed, PVA side down, on the surface of the water the PVA dissolves away into the water. I suppose they could have about as easily used rice paper rather than PVA. The activator spray acts on the ink layer only, not the PVA layer. It would be more correct to say that those different solvent recipes are used to make it more universal to different ink layer compositions. It may sound like I'm nitpicking but I'm only doing it to ensure that you have the right info and don't go off trying to test solvents with different samples of polyvinylalcohol rather than different brands of ink designs.
65% ethyl acetate
15% butoxyethanol
That formula looks good to me. I wonder if BBzP is butylbenzylphthalate? That would be a reasonable choice, IMO.
Here is a http://www.specialchem4coatings.com/product-directory/film-forming-coalescing-agents_0_12425/index.aspx?did=0 that helps you choose a coalescing agent (which I believe is the same thing as an 'activator' in the water transfer process). You can see on this website that not only do you need to choose a range of solvents but perhaps also the appropriate 'activator' as well. Also note that in some cases the solvent can be a coalescing agent.
Likes mortiz
thanks again for your help. ill let you know how i get on and what was successful and what was not.
Likes mortiz
Hi, just a not that might help you with the activator, I have been printing for some now and like you had trouble obtaining the activator, the formula i have is as follows
Xylene = Dimethybenzene 42%
Iso-butanol = isobutyl alcohol = methyl propanol 5%
Butyl = butyl acetate = butyl ethanoate 17%
B-butanone = methyl isobutyl ketone = MEK 8%
Methyl =methyl acetate = acetic acid methyl ester =
methyl ethanoate 28%
As you can see some of the chemicals all have different names ( trade names from manufactures) all the same chemical though.
The formula that i have been using is as follows,
Xylene 60%
n-Butyl acetate 25%
n-Butanol 10%
Cyclohexanone 5%
The problem you will have is obtaining these chemicals in small quainties and the cost plus storage they are quite danderous to have sitting around as you can see some you need very little of but you have to buy large amounts.
My background is spray painting and panel repaires so i was quite suprised when using the activator the smell was quite familair eg: thinners to be precise 2pak thinners not acrylic thinners so i tried it and the result is ammazing exactly the same have been useing it for some time now easy to obtain cheap to buy in quaintities from 500 mil to 25 litres from any automotive paint suppies store.
Buy a small amount =500 mil and try it, rememmber ( 2 pac thinners only) hope this is of some help to you as people try to keep this prosses a secet.
Cheers, Don.
Likes mortiz
Hi don, that's great advice thank you. Do you have a preferred brand as there's lots on the market and some are universal? Thanks again.
Hi, I just use any universal 2pak thinners' when you go to purchase it you should ask if they have the MSDS ( Material Data Safety sheet ) for the one that you purchase , it will list all the chemical formula and ratio's. When I tried to get the activator made here the first thing that alerted me to this was they asked me why I wanted to mix my own thinners as this was a basic formula for thinners.
I did a test using first the activator on some front computer panels and the the same using the thinners, the results where pretty much the same, the trick is your water temp, the spread you allow the film to have afer activation and the pressure at which you apply the activator.
If you need any info on abtaining the film and not paying though the nose I can give you all the info that I use to deal direct with the manufacturers as it saves you a small fortune.
You can contact me at visualtransformers@hotmail.com if you wish for mor info.
Cheers, Don.
Likes mortiz, (deleted member) and (deleted member)
1. How does water transfer printing activator work?
Water transfer printing activator is a process that involves transferring a printed image or pattern onto a three-dimensional surface by using water as a medium. The activator is a chemical solution that dissolves the printed image and allows it to adhere to the surface of the object. This process is also known as hydrographic printing or immersion printing.
2. What types of objects can be printed using water transfer activator?
Water transfer activator can be used on a wide range of objects and materials, including plastic, metal, wood, and even glass. It is commonly used in industries such as automotive, sports equipment, and home decor to add custom designs or patterns to products.
3. Are there any limitations to the designs that can be printed using water transfer activator?
Water transfer activator allows for a high level of customization, as almost any design or pattern can be printed onto an object. However, intricate or highly detailed designs may not transfer as well and may require additional touch-ups or adjustments after the printing process.
4. Is water transfer activator a permanent printing method?
Water transfer activator is a semi-permanent printing method, as the printed image is not directly applied to the object's surface. Instead, it adheres to a clear coat or primer that has been previously applied. This means that the design can be removed or changed by sanding or stripping off the clear coat.
5. Can I do water transfer printing activator at home?
Water transfer printing activator can be done at home with the right materials and equipment, but it does require some skill and practice to achieve professional-looking results. It is recommended to consult tutorials or seek assistance from experienced individuals before attempting to do it yourself.
  • New Member Introductions
  • Mechanical Engineering
  • MATLAB, Maple, Mathematica, LaTeX
