Proof of relativistic energy/mass to grow to infinity for v approaching c?
In summary, according to relativistic energy and mass being proportional to the Lorentz factor γ, the relativistic mass increases to infinity as velocity approaches the speed of light. This relationship has been confirmed by the Kaufmann experiment and its successors.
Vincentius
78
By SR, relativistic energy and mass are proportional to the Lorentz factor γ, therefore, grow to infinity for v[itex]\rightarrow[/itex]c. This relationship for the relativistic mass has been confirmed by the Kaufmann experiment and its successors, via measuring the deflection of high velocity electrons by an electric and/or magnetic field.
My question is: is this really unambiguous proof of energy/mass increase? Or, could as well the effective electric (and/or magnetic) deflection force on the electron go to zero for v[itex]\rightarrow[/itex]c, such that the inertial mass (and energy) only appears to increase?
Hi Vincentius, welcome to PF!
Generally, the concept of relativistic mass has been discarded by modern physicists. However, from particle accelerator experiments it is abundantly clear that the total energy increases to infinity for v->c. Or, if not to infinity, then at least for as high energy as we have been able to probe thus far. If it were just a decrease in the Lorentz force then there wouldn't be enough energy to make the reaction products that we observe.
Thanks DaleSpam. Yes, I know the particle accelerators run on high energy to make the reaction products. However, if an electron is being accelerated over a potential of 1 V, then the electron is considered to have acquired 1eV of energy in kinetic energy. But does this still hold at relativistic velocities? How can we be sure the effective force of the accelerating field isn't falling off with the velocity of the electron (like the deflection force in my original question)? On the basis of which experimental result can this possibility be ruled out?
Particle accelerators accelerate particles in many small steps. If the potential difference ΔV in the later steps didn't produce qΔV in additional kinetic energy, it would be pretty obvious at the end, after the last step.
Do you mean the energy of the particle after the last step is somehow measured, other than by adding up all ΔV's?
Yes.
As I said above, the observed reaction products are more massive and energetic than you could get otherwise.
Yes. For example, you can smack the particle(s) into a target to bring them to a stop, and then measure how much the target warms up (a calorimeter). This assumes the target is big and dense enough that it can absorb any secondary particles produced by interactions of the incoming particles inside the target.
Or you send the particles through a magnetic field and measure the curvature of their path, which gives you the momentum. From the momentum, you get the energy from
[tex]E^2 = (pc)^2 + (m_0 c^2)^2[/tex]
and then the kinetic energy from [itex]K = E - m_0 c^2[/itex].
Thanks jtbell! Using a calorimeter, I suppose, also requires measurement of the number of incoming particles, right? Or isn't it a true temperature measurement, but some indirect method?
On the second method: I understand the principle, but this deflection method raises the exact same question of my original post.
Try to elaborate a theory that instead of using Relativistic Newton's Second Law of Motion (1) and Lorentz force (2) uses Classical Newton's Second Law of Motion and that modified weak Lorentz force that you suspect might act on fast moving particles.
(1) http://en.wikiversity.org/wiki/Special_relativity
(2) http://en.wikipedia.org/wiki/Mass-to-charge_ratio
The predictions of you theory should fit the experimental results!
If the Newtonian KE formula were correct then highly relativistic electron collisions would max out at about 1.5 MeV, which could never produce muons with a mass of over 100 MeV. You simply cannot explain that based on weakening EM forces.
Do two relativistic electrons form a non relativistic 100 MeV muon?
http://en.wikipedia.org/wiki/Muon
If two relativistic electrons form a relativistic muon then a mass spectrometer will behave as if the electrons and muon have large energies when in reality maybe just the Lorentz force is weaker at high speeds.
Even if the electrons and muons have classical kinetic energies at relativistic speeds, if Lorentz force weakens then they will appear deviated as if they had relativistic energies and Lorentz force were classical.
However, this theory of weak Lorentz forces seen by high speed particles likely leads to contradictions or huge complications. Likely physicists took it into account but something did not work.
1. What is the concept of relativistic energy/mass and how does it relate to the speed of light?
Relativistic energy/mass is a concept in physics that explains how energy and mass are interrelated in objects that are moving at high speeds. This concept is based on Einstein's theory of special relativity, which states that the energy and mass of an object increase as its speed approaches the speed of light. This means that as an object moves faster, its energy and mass also increase, and as it approaches the speed of light, its energy and mass approach infinity.
2. How does the equation E=mc^2 relate to the concept of relativistic energy/mass?
The equation E=mc^2, also known as Einstein's famous mass-energy equivalence equation, is the mathematical representation of the concept of relativistic energy/mass. It shows that energy and mass are equivalent and can be converted into one another. This equation also explains how an object's energy and mass increase as its speed approaches the speed of light.
3. Can an object's energy and mass truly reach infinity as it approaches the speed of light?
According to Einstein's theory of special relativity, an object's energy and mass will continue to increase as its speed approaches the speed of light. However, it is impossible for an object's energy and mass to truly reach infinity, as this would require an infinite amount of energy. Instead, as an object's speed approaches the speed of light, its energy and mass will approach infinity, but never actually reach it.
4. How is the concept of relativistic energy/mass relevant in modern physics and technology?
The concept of relativistic energy/mass is relevant in many areas of modern physics and technology. It is used in particle accelerators, such as the Large Hadron Collider, to understand the behavior of particles at high speeds. It is also important in space travel, as it explains how an object's energy and mass can change as it travels at high speeds through space.
5. Are there any practical applications of the concept of relativistic energy/mass for everyday life?
The concept of relativistic energy/mass may not have direct practical applications in everyday life, but it has greatly contributed to our understanding of the universe and how it behaves. It has also led to the development of various technologies, such as GPS systems and medical imaging devices, which rely on the principles of special relativity to function accurately. Furthermore, understanding the concept of relativistic energy/mass can help us understand and appreciate the fundamental nature of our world.
  • Other Physics Topics
10K
13K
