Endothermic absorb energy How do they begin in the first place?
In summary, the phenomenon of spontaneous endothermic reactions between two substances is due to their state of being unstable and the cost of a little bit of heat energy being used to make them more stable.
hondaman520
33
Endothermic absorb energy... How do they begin in the first place??
PLEASE, BEFORE ANSWERING I would like you to hear me out. >>>
Im really confused as to the phenomenon of why endothermic reactions between mixing of two substances just spontaneously happen.. giving them temporary "cold" properties...
Thermal neutrality and the urge for everything to equalize in temperature is completely intuitive to me, so when i think of something getting hot, obviously energy was introduced to the system... In endothermic reactions however, this is not necessarily the case.
Obviously one the reaction happens, it has gone to a state of less energy... It is absorbing the room temperature heat and from your fingers when touching.
i understand how putting a source of heat between two substances can cause an endothermic reaction, because your introducing outside energy to start with.. they say when bonds are being broken, it costs energy. But what energy is being displaced to being the endothermic reaction, before it gets real cold..
how do bonds just spontaneously break apart and loose energy when they are mixed like metal in a salt solution for example.
Could someone explain this in a precise clear manner, cause i think the hardest part of the question is communicating my misunderstanding, I couldn't get the answer I wanted from my chem teacher, she kept saying entropy causes this, naturally. I know what entropy is, i am still confused, however.
Thank you for reading, I would very much appreciate some insight.
ammonium nitrate cold packs for example... they just magically get cold.
this is my observation so far: these spontaneous endothermic reactions when substances are mixed are because they are at an unstable state? and with the cost of a little bit of (room temperature) heat, they break apart into more stable molecules/atoms?
The want to go from unstable to stable at the cost of a tiny bit of heat energy from its surroundings make sense to me, but I am not sure..
Chemistry news on Phys.org
I could be wrong, but I don't think endothermic reactions result in the product of the reaction being in a state of LESS energy. That energy isn't lost, it has to go somewhere, so it should go be bound up in the molecules, putting them in a higher energy state. If this energy is taken from the heat of the substance, it would result in a lowering of the temperature.
The main idea to keep in mind is that there are three tendencies that drive reactions in one direction or the other:
  1. A tendency to go in the direction of lower internal energy
  2. A tendency to go in the direction of smaller volume (in the presence of external pressure on the system)
  3. A tendency to go in the direction of higher entropy
When the 3 tendencies favor different directions, you have to calculate the Gibbs Free Energy for the products and reactants; whichever has a lower G "wins" in terms of reaction direction:
Gibbs Free Energy = G = U + PV - TS
In an endothermic reaction, the U+PV terms alone would favor the reactants. But, the products have a sufficiently higher entropy so that overall the products are the favored direction for such a reaction. That "-TS" term (-Temperature·Entropy) is what makes G smaller for the high-entropy products than for the low-entropy reactants, even though heat must be transferred into the system for this to happen.
Hope this explanation makes some sense -- I probably left out some details in the interest of keeping things fairly brief. If you have more questions, feel free to ask.
1. What is endothermic absorption of energy?
Endothermic absorption of energy is a process where a substance or system absorbs energy from its surroundings in the form of heat or light. This results in an increase in the internal energy of the substance or system.
2. How does endothermic absorption of energy occur?
Endothermic absorption of energy occurs when a substance or system is exposed to a source of energy, such as heat or light. The energy is then absorbed by the substance or system, causing an increase in its internal energy.
3. What are some examples of endothermic absorption of energy?
Some examples of endothermic absorption of energy include melting of ice, evaporation of water, and photosynthesis in plants. In these processes, energy is absorbed from the surroundings, resulting in a decrease in temperature or an increase in the internal energy of the system.
4. How is endothermic absorption of energy different from exothermic reactions?
Endothermic absorption of energy is the opposite of exothermic reactions, where energy is released from a substance or system into its surroundings. In endothermic reactions, the products have higher energy than the reactants, while in exothermic reactions, the products have lower energy than the reactants.
5. What are the practical applications of endothermic absorption of energy?
Endothermic absorption of energy has various practical applications, such as refrigeration and air conditioning, which rely on the absorption of heat from the surroundings to cool down a space. It is also used in chemical reactions to produce certain products and in industrial processes to control temperature and pressure.
  • Chemistry
  • Chemistry
