Infinite potential well with a step
In summary, the homework statement says that a particle of mass m moves in the potential U. For x<0 infinity, the potential is infinite. For 0<x<a -U, the potential is a downward sloping line. For a<x<b 0, the potential is a downward sloping line and for b<x infinity, the potential is a downward sloping line and infinity. The equation for the potential is Asin(kx). The condition for U to be valid is that the second derivative of psi is equal to 0. In addition, for x=b, there is an additional constraint on psi2 for x=b. The equation for the potential is
Rorshach
136
Hey guys:) Maybe you will be able to help me with this problem i got as an assignment for my quantum mechanics course, it goes as follows:
for x<0 infinity,
for 0<x<a -U,
for a<x<b 0,
for b<x infinity.
a) Sketch the potential.
b) We are looking for a solution with energy E=0. Set up the Schrödinger equation (in different areas), and determine the general solutions. Put E=0 from the beginning of Schrödinger equation.
c) Use the continuity conditions for reducing the number of constants. Note that continuity condition always applies to ψ(x) at all points, but it only applies to dψ(x)/dx at points where the potential is finite. In the case above, we can not require continuity of dψ(x)/dx in points x=0 or x=b but in the point x=a.
d) Determine the condition for U to be valid.
Of course i attemted to solve this by solving the schrodinger's equations for indicated ranges, however i faced the problem by having to present E as 0 from the very beginning.
Just work with E, and replace every occurence of "E" with "0" afterwards if you like. Setting E to 0 just makes the equations easier, not more complicated.
I tried to calculate the schrodinger equations for the regions-ok, i have two wavefunctions psi1=Asin(k1x) with k1=root(2Um)/hbarred, and psi2=Csin(k2x) with k2=root(2Em)/hbarred, where E=0. Those two wavefunctions equalize in point a, that's when I have this equation Asin(k1x)=Csin(k2x), so it is Asin(k1x)=C*0. I am not sure if I got it right. Where am I making a mistake?
I just divided the range into regions, psi2 is the wavefunction for region a<x<b. I am not sure if I am doing it right?
"psi2=Csin(k2x)" <- how did you get this?
If you solve the Schrödinger equation, you should get a different result.
for this region V(x)=0, and energy is also equal 0. I put this to the schrodinger equation and it looked something like this:
-(hbarred)^2/2m*psi''=E*psi(x)
then I derived this: k=root(2mE)/ℏ
from border conditions I got this: psi=Csin(kx), where k is equal to 0. In the end I could show this wavefunction as 0, but decided to show it like this and maybe get something from it later.
This cannot be derived from the equation above.
Did you see any particular reason to use a sin here? I am sure it was not the result of your calculation.
Fine. Now we can use E=0:
$$-\frac{\hbar^2}{2m}\psi''=0$$
Can you simplify and solve this? Please solve it yourself, and don't try to use solutions to other problems.
it states that second derivative of psi is equal to 0, but how am I supposed to use this information?
Can you give a general description of all functions with zero second derivative?
Sorry, forgot about linear function:P Now I have two equations, first one for 0<x<a (psi=Asin(kx)), and second one for a<x<b (psi=Cx+d). Now the only thing that comes to my head is to equalize them in point a, is this right?
Right.
You get an additional constraint on psi2 for x=b. This gives you two conditions with 3 free parameters, but the global normalization is irrelevant.
I think I got lost about this point. I have psi for 0<x<a (Asin(kx)), and I have psi for a<x<b (Cx+d), and I know that they equalize in point a, and their derivatives should equalize too, but I still don't know how to get the constants A, C and d. It is probably something simple, but I am missing it.
Can you write that as an equation?
And that one, too.
You have an additional constraint at x=b.
I get a set of three equations:
Asin(ka)=Ca+d
Akcos(ka)=C
Cb+d=0
I am probably missing some ridiculously simple step, but only thing I obtain is equation
Asin(ka)=Akcos(ka)(a-b) and this is where I no longer know what to do. What am I missing?
sin(ka)=kcos(ka)(a-b)
tan(ka)=k(a-b)
a and b are constants, you can solve the equation for k numerically or graphically.
You can divide A out and rearrange slightly to get
$$\tan ka = ka\left(1-\frac{b}{a}\right).$$ This is the condition you're looking for in part (d). For given values of ##a## and ##b##, this relationship is satisfied for only certain values of ##ka##, which corresponds to certain values of U. You can see this by plotting the two sides of the equation and seeing where the curves intersect.
I'm having a little problem with plotting this, mostly due to the fact that I don't exactly know the values of a and b, only bit of information is that b>a. Please help me uderstand this?
Plot it for some different values of b/a? The general pattern of the solutions is the same for all ratios, just the numerical values are different.
1. What is an infinite potential well with a step?
An infinite potential well with a step is a theoretical model used in quantum mechanics to describe the behavior of a particle confined to a specific region of space. The "well" refers to the region where the particle is allowed to exist, while the "step" represents a sudden change in potential energy within the well.
2. How does the particle behave in this system?
Inside the well, the particle's potential energy is constant and it behaves like a free particle, meaning it can move freely within the well. However, when it reaches the step, the sudden increase in potential energy causes the particle to behave like it is hitting a barrier, and it can either reflect back or tunnel through the barrier depending on its energy level.
3. What is the significance of the infinite potential in this model?
The infinite potential serves as a simplification of a real-world barrier, allowing for easier mathematical calculations and analysis. It also helps to illustrate the concept of quantum tunneling, where a particle has a non-zero probability of passing through an energy barrier even if it does not have enough energy to overcome it classically.
4. How does the width of the step affect the particle's behavior?
The width of the step directly affects the probability of the particle tunneling through the barrier. A wider step means a higher potential energy barrier, making it less likely for the particle to tunnel through and increasing the chances of reflection.
5. Can this model be applied to real-world systems?
While the infinite potential well with a step is a simplified theoretical model, it can be used to approximate the behavior of particles in certain real-world systems, such as semiconductors and quantum dots. However, it is important to note that in reality, there are no perfect infinite potential barriers and other factors, such as particle interactions, must also be taken into account.
9K
