Prove rotational invariance leads to conservation of ang. momentum
In summary: L}{\partial θ-dot}And since dθ and dθ-dot are independent variables, we can set them equal to each other, giving us:\frac{\partial L}{\partial θ} = -\frac{\partial L}{\partial θ-dot}Finally, we can use Lagrange's equations to show that this implies the conservation of angular momentum Lz about the symmetry axis. Using the same logic as in the translational invariance example, we can write:\frac{\partial L}{\partial θ} = \frac{d}{dt} \left(\frac{\partial L}{\partial θ-dot} \right)And since we have shown that \frac{\partial
xWaffle
30
Noether's theorem asserts a connection between invariance principles and conservation laws. In section 7.8 we saw that translational invariance of the Lagrangian implies conservation of total linear momentum. Here you will prove that rotational invariance of L implies conservation of total angular momentum. Suppose that the Lagrangian of an N-particle system is unchanged by rotations about a certain symmetry axis. (a) Without loss of generality, take this axis to be the z axis, and show that the Lagrangian is unchanged when all of the particles are simultaneously moved from (rα, θα, ϕα) to(rα, θα, ϕα + ϵ) (same ϵ for all particles). Hence show that
[itex]\sum_{\alpha=1}^{N} \frac{\partial \mathcal{L}}{\partial \phi_{\alpha}} = 0[/itex]
(b) Use Lagrange's equations to show that this implies that the total angular momentum Lz about the symmetry axis is constant. In particular, if the Lagrangian is invariant under rotations about all axes, then all components of L are conserved.
Lagrange Equations: Translational Invariance Example
No external force.
Simply, the change in potential is:
[itex]\delta U = U(\overline{r}_{1} + d\overline{r}_{1}, \overline{r}_{2} + d\overline{r}_{2}, ... , t) - U(\overline{r}_{1}, \overline{r}_{2}, ... , t)[/itex]
[itex]U = \sum_{\alpha\beta} U_{\alpha\beta}(\overline{r}_{\alpha} - \overline{r}_{\beta})[/itex]
And very similarly for the Lagrangian:
[itex]\delta\mathcal{L} = \mathcal{L}(\overline{r}_{1} + d\overline{r}_{1}, \overline{r}_{2} + d\overline{r}_{2}, ... , t) - \mathcal{L}(\overline{r}_{1}, \overline{r}_{2}, ... , t)[/itex]
Stationary requires this change in action to be zero:
[itex]\delta\mathcal{L} = 0[/itex]
And, earlier in the semester, we proved that a conservative force can be written as the negative gradient of a scalar valued function. We will use this here:
[itex]\delta\mathcal{L} = d\overline{r} \bullet \nabla_{1} \mathcal{L} + d\overline{r} \bullet \nabla_{2} \mathcal{L} + ... = 0[/itex]
And to redefine some of the terms in the last line:
[itex]d \overline{r} = \hat{x} dx[/itex]
[itex]d \overline{r} \bullet \nabla_{1} \mathcal{L} = dx \frac{ \partial \mathcal{L} }{ \partial x_{1}}[/itex]
Now, plug them into make it look a little bit more like what we want..
[itex]dx \sum_{\alpha} \frac{ \partial \mathcal{L} }{ \partial x_{\alpha}} = 0[/itex]
[itex]\sum_{\alpha} \frac{\partial \mathcal{L}}{\partial x_{\alpha}} = 0[/itex]
Lagrange Equations for any particle in the system:
[itex]\frac{\partial \mathcal{L}}{\partial x_{\alpha}} = \frac{d}{dt} \left(\frac{\partial \mathcal{L}}{\partial \dot{x}_{\alpha}} \right)[/itex]
Which is the same as saying:
[itex]\frac{\partial \mathcal{L}}{\partial x_{\alpha}} = \frac{d}{dt} \left( p_{x\alpha} \right)[/itex]
[itex]\frac{\partial \mathcal{L}}{\partial x_{\alpha}} = \dot{p}_{x\alpha}[/itex]
And from here, out conclusion can be shown very simply:
[itex]\sum_{\alpha} \dot{p}_{x\alpha} = \dot{p}_{total} = 0[/itex]
[itex]\dot{p}_{total} = 0[/itex]
[itex]p_{total} = 0 \rightarrow consant[/itex]
We've been shown an example with translational invariance leading to conservation of momentum. He used the Lagrange equations and related them to U(r) potential energy, showed that with no external forces, a change in the Lagrangian can be written as a re-written form of the difference of potentials. Which then led to the full time derivative of the Lagrangian not explicitly depending on x (only x-dot), which meant p (momentum) was constant.
I've tried to approach it in a similar way, but I'm stuck trying to wrap my head around what would be the 'rotational equivalent' of his first step. Is this the wrong way to approach it?
Should I be trying to manipulate the Lagrangian in some way instead?
Thank you for your post. It is great to see that you are actively thinking about how to approach this problem and are making connections to previous examples. Let me guide you through the steps to prove Noether's theorem for rotational invariance.
Firstly, we need to understand what rotational invariance means in terms of the Lagrangian. In the given problem, we are told that the Lagrangian is unchanged when all particles are simultaneously moved from (rα, θα, ϕα) to (rα, θα, ϕα + ϵ). This means that the Lagrangian does not depend on the angle ϕ, which is the angle of rotation about the z-axis. Therefore, we can write the Lagrangian as L(r, θ, θ-dot, ϕ-dot) = L(r, θ, θ-dot). This is the rotational invariance condition for our system.
Now, let's move on to part (a) of the problem. We are asked to show that the Lagrangian is unchanged when all particles are moved by the same angle ϵ. This means that we need to show that the change in Lagrangian, δL, is equal to zero. Using the rotational invariance condition, we can write:
δL = L(r, θ, θ-dot) - L(r, θ, θ-dot, ϕ-dot) = L(r, θ, θ-dot) - L(r, θ, θ-dot) = 0
Therefore, the Lagrangian is indeed unchanged when all particles are moved by the same angle ϵ. Now, using the same logic as in the translational invariance example, we can write:
δL = dθ \frac{\partial L}{\partial θ} + dθ-dot \frac{\partial L}{\partial θ-dot} = 0
But, as we have just shown, δL = 0. Therefore, we can write:
0 = dθ \frac{\partial L}{\partial θ} + dθ-dot \frac{\partial L}{\partial θ-dot}
Now, we can rearrange this equation to get:
dθ \frac{\partial L}{\partial θ} = -dθ-dot \
1. What is rotational invariance?
Rotational invariance is a property of physical systems where the laws of motion and behavior remain the same regardless of the orientation or rotation of the system.
2. How does rotational invariance relate to conservation of angular momentum?
Rotational invariance leads to conservation of angular momentum because it implies that the laws of motion and behavior of a system do not change when it is rotated, meaning the total angular momentum of the system remains constant.
3. What is angular momentum and why is it conserved?
Angular momentum is a measure of an object's tendency to keep rotating at a constant rate. It is conserved because of the rotational invariance principle, which states that the laws of motion and behavior of a system do not change when it is rotated.
4. Can you provide an example of how rotational invariance leads to conservation of angular momentum?
One example is a spinning top. As long as the top maintains its shape and is not affected by external torques, its angular momentum will remain constant, regardless of its orientation or rotation.
5. How does rotational invariance and conservation of angular momentum impact our understanding of the physical world?
These principles are fundamental to our understanding of the physical world and are used in many areas of science, such as mechanics, astrophysics, and quantum mechanics. They help us explain and predict the behavior of objects in motion, from the rotation of planets to the spin of subatomic particles.
