| New Reply |
Regarding Load Resistances |
Share Thread | Thread Tools |
| Jun25-12, 07:37 AM | #1 |
Hi Every One,
I am working on the Class E DC-DC converters. My circuit is working good for full load (RL-load resistor) and also giving the 90% of efficiency. But, the problem is that how to maintained the output voltage is constant by changing the load resistance from full load to no load. If you have any document or any ideas please forward to me. |
| Jun25-12, 08:07 AM | #2 |
| Jun28-12, 04:17 PM | #3 |
Hi jegues,
My specifications are Vin=100v;Vo=50v;Po=50w;f=3.5Mhz and Q=5. I tried in the way of changing the duty cycle and also tried to keeping the voltage regulator, but no use. So, please give me the clear explanation about how to maintained the output voltage is constant by changing the load resistance from full load to no load. |
| Jun28-12, 04:24 PM | #4 |
| Jun28-12, 10:22 PM | #5 |
Also, I think your minimum load will be whatever your feedback circuit losses are, as in the resistor divider. That minimum current has to be enough that you can control.
| Jul2-12, 02:19 PM | #6 |
Hello DragonPetter,
How to control the switch with respect to the output voltage? |
| Jul2-12, 02:43 PM | #7 |
| Jul3-12, 08:44 AM | #8 |
Please let me know that, how can I choose the correct duty cycle? They are any formulae to choose that?
By the way, My circuit is not buck converter.. that is Class E DC-DC converter. |
| New Reply |
| Thread Tools | |
Similar Threads for: Regarding Load Resistances
| Thread | Forum | Replies | ||
| Load voltage with shorted load / open load | Introductory Physics Homework | 6 | ||
| Bending moment query re. uniformly distributed load and concentrated load(s) | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Uniformly Varying Load/Uniform Load to Concentrated Point Load | Engineering Systems & Design | 4 | ||
| Applied ME: Dynamic load calculation, drag force correlation. Load cells and LabVIEW? | Mechanical Engineering | 8 | ||
| Calculating the dead load (G) and live load(Q) of this tunnel - civil engineering que | Engineering, Comp Sci, & Technology Homework | 4 | ||
