Find hybridisation of Carbon compounds
In summary, Finding the hybridisation in carbon compounds can be challenging, as the usual method of dividing the valence electrons by 8 may not work. This method is not accurate and can cause confusion. Instead, it is important to consider the principles of valence bond theory, including atomic orbitals, electronic configuration, and overlap criteria. The preferred method of determining hybridisation involves considering the number of bonds and lone pairs in a molecule, as well as its geometry. Additionally, carbon can form up to four sigma bonds, but their identity depends on the hybridisation of the carbon atom.
Saitama
4,243
93
Hello!
How to calculate the hybridisation in carbon compounds? Most of the time whenever i try to find out the hybridisation i get a wrong answer.
I think the usual way of finding hybridisation doesn't work with carbon compounds. Is there any other way?
Chemistry news on Phys.org
May be you could describe what you consider to be the "usual" way?
By "Usual way" i mean adding the valence electrons of the atoms of the molecule and dividing by 8. If the value comes:-
2- sp
3- sp2
4- sp3
5- sp3d
6- sp3d2
7- sp3d3
For example, NF3
Total valence electrons=26
Dividing by 8 gives 3 as quotient and 2 as remainder.
"3" is the number of sigma bonds.
We will divide the remainder by 2 for finding out the lone pairs.
2/2=1 <-------Number of lone pairs.
I hope you understand. :)
This is certainly not the usual way to look at hybridization. I have never seen this before and in fact it seems to make not the least sense at all. Where did you find this number mysticism?
Why doesn't it make sense?
I think that's the most easiest way to find the hybridisation. This is just a trick to find the hybridisation. Which way do you use to find hybridisation?
I forgot to mention what's the hybridisiation in the example.
NF3 has sp3 hybridisation. 3 + 1= 4.
4 indicate sp3 hybridisation.
And why should this one lone pair which you calculate belong to N and not to one of the F?
Because the least electronegative element is placed in the center. :)
I know that this number method is only applicable in finding out the hybridisation but it does not tell of which atom this hybridisation is. Therefore, we need to adjust and place the atoms properly.
In my textbook its stated:-
"A discussion of the valence bond theory is based on the knowledge of atomic orbitals, electronic configuration of elements, the overlap of elements, the overlap criteria of atomic orbitals, the hybridisation of atomic orbitals and the principles of variation and superposition. A rigorous treatment of VB theory in terms of these aspects is beyond the scope of this book. Therefore, for the sake of convenience, valence bond theory has been discussed in terms of qualitative and non-mathematical treatment only."
So maybe that's the reason my teacher didn't teach us the way you are talking about. :)
Bump :(
Did your teacher show you this strange calculation or is it from the book?
I had hoped that you understood that it gives the wrong number of lone electron pairs.
In NF3 there is one lone pair at N and 3 at each F.
It is taught by my teacher and in some of the refreshers and supplement books available in market here shows this method.
I already said that this method is not correct, we have to arrange the bonds and lone pairs accordingly. Can you please tell me your way? :)
On an elementary level it is not difficult to work out the number of bonds and lone pairs in a given molecule. Just make sure that every main group element has 8 electrons around at least in "normal" compounds eventually introducing some formal charges on the atoms.
The hybridisation which is preferably to be used to describe a molecule depends not only on the number of electron pairs but also on the geometry, that's why you are having probably problems with carbon compounds. Finally, your hhybridization paterns 5 to 7 don't appear at least in main group compounds, although this is still repeated in old or bad books.
A still very readable introduction to the principles (which however still contains d orbital contribution in main group elemental compounds) is the classic book by Linus Pauling, General chemistry.
Thanks for the book suggestion. I will definitely look into that. :)
Coming back to the original question, how many possibilities does the C atom to form covalent bonds ?
I don't understand your question. :confused:
At the most it can form 4 sigma bonds.
And these sigma bonds are they identical ?
No idea. :)
Wouldn't that depend on hybridisation?
Carbon forms compounds simply to complete its octet and so finding out the hybridisation in organic compounds is not much of a hassle. Count the number of sigma bonds and lone pairs of the atom whose hybridisation you need to find. 2,3 and 4 correspond to sp, sp2 and sp3 respectively. The lone electron in a free radical exists in and unhybridised orbital so for example a CH3 free radical would be sp2.
I don't understand your last statement. :confused:
A Free Radical contains an unpaired electron. So after counting the number of sigma bonds you wouldn't count that electron if it is a free radical.
Can you elucidate it further using an example? :)
I am really poor at chemistry. :P
Btw, are you accessing PF from a mobile because you seem to have given a mobile wiki link. :)
Assume PCl4 exists (neutral). The it would have sp3 hybridisation.
Yes sorry forgot to remove the 'm' from the url, I was accessing from a mobile device.
1. What is hybridisation and why is it important in carbon compounds?
Hybridisation is the concept of combining atomic orbitals of different energies in an atom to form new hybrid orbitals. In carbon compounds, hybridisation determines the geometry and bond angles, which in turn affects the physical and chemical properties of the molecule.
2. How do you determine the hybridisation of a carbon atom in a molecule?
To determine the hybridisation of a carbon atom, you need to first calculate the number of valence electrons it has. This can be done by adding the number of valence electrons from all the atoms in the molecule and subtracting the charge. The number of hybrid orbitals is then equal to the number of electron pairs around the carbon atom, and the type of hybridisation is determined by the number of sigma bonds and lone pairs.
3. What are the different types of hybridisation in carbon compounds?
The most common types of hybridisation in carbon compounds are sp, sp2, and sp3. In sp hybridisation, one s orbital and one p orbital combine to form two sp hybrid orbitals. In sp2 hybridisation, one s orbital and two p orbitals combine to form three sp2 hybrid orbitals. In sp3 hybridisation, one s orbital and three p orbitals combine to form four sp3 hybrid orbitals.
4. How does hybridisation affect the properties of carbon compounds?
The type of hybridisation in a carbon compound affects its bond angles, bond lengths, and overall shape. This, in turn, affects the polarity, reactivity, and stability of the molecule. For example, sp2 hybridisation in alkenes results in a planar structure and double bonds, making them more reactive compared to sp3 hybridised alkanes.
5. Can hybridisation change in a molecule?
Yes, hybridisation can change in a molecule due to the process of resonance. In resonance, electrons are delocalised, and the bonds between atoms become intermediate between single and double bonds. This results in a combination of different types of hybridisation, such as sp2 and sp3, in the same molecule.
  • Chemistry
