Maximizing Distance on a Slope: Tips for Designing a Winning Car
In summary, the speaker is a beginner in physics, currently at A Level, and is seeking help for a house technology project involving building a small car that will be released from rest at the top of a slope and travel the furthest on a ramp. They are looking for equations and tips to achieve maximum distance, and are at a disadvantage compared to others in the project. The speaker also mentions the importance of considering friction, weight, and inertia in the design of the car. They suggest making the car heavier to reduce friction, and using a flywheel to store energy and overcome drag.
Jonnyc0213
Hi guys new to the forum - sorry if I'm not as advanced as you lot :tongue2: I'm currently only at A Level in my adventures of Physics!
(I didn't think this would fall under homework help, I apologize if it does)
Anyway, tomorrow in school there is a house technology project, and I've been entered without doing this as a subject. I think I'll do it anyway since I do Physics.
Anyway - we have to build a small car, it is then released from rest, at the top of a slope onto a ramp. The car that goes the furthest wins. (I'm going to assume the angle is 30°)
Does anyone have any equations that could help me work out how to achieve the maximum distance? Or even any tips on the structure of the car?
I know how to do projectile motion of course, but how can I maximize the velocity at the end of the ramp?
Any help will be greatly appreciated - I'm at a huge disadvantage tomorrow and I want to make a good account for myself! Thanks guys!
If you ignore inertia of the wheels, the speed at the bottom of the ramp will only depend on friction/weight ratio. Less friction/weight, more speed. That simple. So you need to either make your car heavier or reduce friction. Drag will depend only on shape of the car and speed, while friction in wheels will depend primarily on weight.
All in all, heavier car will probably do better, because it will help you ignore air resistance.
Now onto inertia of the wheels. It will slow your car down at the bottom, but all that energy doesn't disappear. It is still stored in rotation of the wheels. So the car will carry extra distance afterwards thanks due to the same inertia. Since your car is moving slower overall, you would have less drag. So I would recommend making wheels as massive as possible, keeping in mind that you want the weight nice and balanced. If you have time to get creative, you might even consider building a flywheel that spins at higher RPM than the wheels. That will let your car go really slowly, build up a lot of inertia in the flywheel, and use that to travel the distance, while other cars waste energy on fighting drag. Of course, if you build too much resistance into your belt/gear system, that will cost you all of the advantage, so simpler might be better here.
1. What is the formula for calculating the velocity of a body on a slope?
The formula for calculating the velocity of a body on a slope is v = √(2ghsinθ), where v is the velocity, g is the acceleration due to gravity, h is the height of the slope, and θ is the angle of the slope.
2. How does the angle of the slope affect the velocity of a body?
The angle of the slope directly affects the velocity of a body. As the angle increases, the velocity also increases. This is because a steeper slope will result in a greater acceleration due to gravity, therefore increasing the velocity of the body.
3. What is the difference between velocity and speed on a slope?
Velocity and speed are often used interchangeably, but they have different meanings. Velocity is a vector quantity that includes both speed and direction. On a slope, both the speed and direction of the body are important in determining its velocity. Speed, on the other hand, is a scalar quantity that only measures the rate of motion without considering direction.
4. Can the velocity of a body on a slope ever be negative?
Yes, the velocity of a body on a slope can be negative. This would occur when the body is moving in the opposite direction of the slope, such as when it is slowing down or moving downhill on a slope that is angled upwards.
5. How does the weight of the body affect its velocity on a slope?
The weight of the body does not directly affect its velocity on a slope. However, the weight of the body does affect the force of gravity acting on it, which in turn affects the acceleration and therefore the velocity of the body on the slope.
  • Mechanics
10K
