Why is my equation of motion different from the correct one?
In summary, the conversation discusses finding the equation of motion for a system involving a rope attached to a cylinder and a mass that creates a pendulum with a maximum angle \theta. The length of the rope while \theta = 0 is \ell, and the weight of the rope is neglected. The correct equation of motion is (\ell + r\theta)\ddot{\theta} + r\dot{\theta} + g sin\theta = 0, but the steps taken to reach this solution are different from the correct one. The conversation also discusses the potential energy of the system and clarifies the coordinate system used.
TheDestroyer
402
Sorry for that title, but what can I say, I'm going to be mad to get the motion equation for some systems but always failing
system 1:
a rope rounded to a cylinder, the rope ends with a mass m and creating a pendulum with a maximum angle creating on a vibration [tex]\theta[/tex], the length of the rope while [tex]\theta = 0[/tex] is [tex]\ell[/tex], the wight of the rope is neglected
find the equation of motion using lagranges equation..
Here is the CORRET answer:
[tex](\ell + r\theta)\ddot{\theta} + r\dot{\theta} + g sin\theta = 0[/tex]
here are the steps i took, i didn't get the same result, i want some body to give me step by step,
As we know the lagrangian is:
[tex]L = T - u[/tex]
and lagranges equation of motion is:
[tex]\frac{d}{dt} \frac{\partial L}{\partial \dot{q}} - \frac{\partial L}{\partial q} = 0[/tex]
T is kinetic energy of the system,
u is potential energy of the system
q is a generalised coordinate
Now to find the equation of motion, we will use polar coordinates, we first find that r is constant, and the change is only in the angle so:
[tex]T = \frac{1}{2} mr^2 \dot{\theta}^2[/tex]
and the potential energy is the mgh while h is the length of the rope plus the length added with the angle [tex]\theta[/tex]
[tex]u = -mg(\ell + r\theta)[/tex]
and now differentiating:
[tex]\frac{d}{dt} \frac{\partial L}{\partial \dot{\theta}} = \frac{d}{dt}mr^2 \dot{\theta} = mr^2 \ddot{\theta} [/tex]
[tex]\frac{\partial L}{\partial \theta} = -mgr[/tex]
finally, the equation of motion is:
[tex] mr^2 \ddot{\theta} + mgr = 0[/tex]
[tex] \ddot{\theta} + \frac{g}{r} = 0[/tex]
And this answer is very different to the correct one, WHY? Any one can explain? and give me the correct steps?
I'm going to give other systems later, Please anyone try GIVING ME the way to understand this mechanics .. and thanks
Does the length of the rope not change as the pendulum swings? Perhaps I'm just not understanding the situation.
edit: could you maybe include a diagram?
No, the length doesn't change, but the hight is changing due to the angle
The cylinder is stationary, the mass swinging is the pendulum. The potential is not just [tex] mgr [/tex] but [tex] mgr \cos(\theta) [/tex]. As the mass swings from side to side, teh rope will change length giving the other term for the kinetic energy.
No man, I didn't say it's (mgr), potential energy depends on the hight, I wrote the length of the rope plus the rope rounded around the cylinder because of the angle theta:
Will you exaplin more, explain everything please !
The first step is to define your coordinate system. What does [itex] \theta [/itex] mean? Where is 0?
0 is in the center of the cylinder
Have you tried including the rotational kinetic energy of the cylinder into T?
Pete
I though [itex] \theta [/itex] was an angle?
Your drawing seems to indicate that the cylinder is rotating? I think the problem is for a pendulum which swings off of the cylinder. Please explain your coordinate system. What is [itex] \theta [/itex] ?
I've found a solution which is very near, ideas please:
if we made:
[tex]T = \frac{1}{2} mR^2 \dot{\theta}^2 = \frac{1}{2} m(\ell+r\theta)^2 \dot{\theta}^2[/tex]
[tex]u = mgr(1-cos(\theta))[/tex]
[tex]L = T - u = \frac{1}{2} m(\ell+r\theta)^2 \dot{\theta}^2 - mgr(1-cos(\theta))[/tex]
Then substitute:
[tex]\frac{d}{dt} \frac{\partial L}{\partial \dot{\theta}} = \frac{d}{dt}m(\ell+r\theta)^2 \dot{\theta} = 2m(\ell +r\theta)r\dot{\theta}^2 + m(\ell + r\theta)^2 \ddot{\theta} [/tex]
[tex]\frac{\partial L}{\partial \theta} = m(\ell + r\theta)r\dot{\theta}^2 - mgr sin(\theta)[/tex]
then the equation of motion:
[tex]m(\ell + r\theta)^2 \ddot{\theta} + 2m(\ell + r\theta)r\dot{\theta}^2 - m(\ell + r\theta)r \dot{\theta}^2 + mgr sin(\theta) = 0 [/tex]
deviding by [tex]m[/tex] and [tex](\ell + r\theta)[/tex]
[tex](\ell + r\theta) \ddot{\theta} + r\dot{\theta}^2 + \frac{gr}{(\ell+r\theta)} sin(\theta)=0[/tex]
WELL, the difference now is only the [tex]\frac{r}{(\ell+r\theta)}[/tex]
Can anyone explain?
MY GOD, the cylinder is rotating i meant with 0 the center of the coordinates, [tex]\theta[/tex] is the angle creating by the cylinder rotation in the 2 sides
This is not clear to me, where is [itex] \theta = 0 [/itex] and how does it realate to the rope?
I do not think that you have a handle on the potential energy, mainly because you are misinterpreting the problem. Consider a pendulum which swings from the cylinder, [itex] \theta [/itex] is the angle from the horizontal to the point of tangency of the rope. This is consistent with the initial point given in your problem definition of [itex] \theta = 0 [/itex] means the length of the rope = L . To find your potential energy you need to find the distance the mass is lifted by moving the point of tangency through [itex] \theta [/itex] radians. This is a geometry problem.
Well, At the hight point is when [tex]\theta = 0[/tex] then potential energy is mgr, and note here, i made the beginning of the potential energy in the line containing the tangency point and the center of the cylinder, and when the pendulum moves and creates the angle [tex]\theta[/tex] we will just add or subtract the length done by the angle [tex]\theta[/tex] the it will be [tex]mgr\cos \theta[/tex] and the difference between them is:
[tex]u = mgr - mgr\cos \theta = mgr (1-\cos \theta)[/tex]
am I wrong?
Who said [tex]\theta = 0[/tex] ?
I said the start point of the coordinates is the center of the cylinder because we are using the polar coordinates ! isn't that clear man?
Clearly you do not have a grasp of the problem. The first step is to understand your coordinate system. Re read you initial post you say
a rope rounded to a cylinder, the rope ends with a mass m and creating a pendulum with a maximum angle [itex] \theta [/itex] creating on a vibration , the length of the rope while [itex] \theta = 0[/itex] is L , the wight of the rope is neglected
Clearly [itex] \theta = 0[/itex] at SOME point. Remember [itex] \theta [/itex] is an angle, how does it relate to the rope. Read my previous post again and think about it. If you do not understand the physical system there is no way to derive a meaningful expression for the potential and kinetic energies.
If the rope were simply moving up and down with rotations of the cylinder, then the change in potential energy would simply be r[itex] \theta[/itex] since this is not the case, maybe you need to make an effort at figuring out how the system is moving.
Calm down, my english is not good, the rope length is not changing, but changing only because the theta angle,
anyone found help for me on that result? (note i didn't yet select my coordinates system, everything is going random, then i proof the correct of it)
And sorry integral if i disturbed you,
can anyone work with this problem and give me the T and U?
thanks
http://home.comcast.net/~rossgr1/Math/potential.pdf and how I see the potential energy term. I have not used it to compute the equation of motion, but perhaps this will get us on the same page as far as the coordinate system goes.
Thanks integral, i'll give a try with this hight, and i'll return to tell you the result,
Thanks integral, you calculations are right, i got the answer,
EXECELLENT! :smile:
I hope that picture is of some help in undersanding where the expression for h came from. It is common in this type of problem that you must understand your coordinate system and carefully derive each expression by drawing a good diagram and aplying geometry and trigonometry.
Good luck in future problems.
BTW You may wish to contact Clausius2, he is also spanish and very knowledgeable.
1. Why does my equation of motion not match the correct one?
There could be several reasons why your equation of motion is different from the correct one. It could be due to an error in your calculations or assumptions, the use of incorrect units, or a misunderstanding of the underlying principles of motion.
2. How can I verify the accuracy of my equation of motion?
One way to check the accuracy of your equation of motion is to compare it with the correct equation and see if they match. You can also perform experiments or simulations to test the predictions of your equation and see if they align with real-world observations.
3. What factors can affect the equation of motion?
The equation of motion can be affected by various factors such as the initial conditions of the system, external forces acting on the system, and the type of motion (e.g. linear or rotational). It can also be influenced by the objects' mass, velocity, and acceleration.
4. How can I improve my understanding of the equation of motion?
To improve your understanding of the equation of motion, you can review the fundamental principles of motion and their mathematical representations. You can also practice solving different types of motion problems and seek help from a teacher or mentor if needed.
5. Can the equation of motion change in different scenarios?
Yes, the equation of motion can change in different scenarios depending on the specific conditions and factors involved. For example, if there is friction present, the equation of motion will be different compared to a scenario with no friction. It is important to carefully consider all the relevant factors when deriving or using the equation of motion.
  • Mechanics
  • Mechanics
