What's left over after particle collisions, like LHC?
In summary, the discussion revolves around the outcomes of particle collisions at sites like the LHC. While a variety of exotic particles are produced, they are short-lived and eventually decay into more stable particles like photons, muons, and kaons. The conservation of charge, energy, and baryon number is emphasized in these experiments, with the possibility of creating new matter like antihydrogen. However, the overall goal is to understand the existence of potential neutral stable particles like axions or neutralinos. It is not possible to create more stable baryonic matter than what was initially present, but the composition of the matter can be altered through nuclear reactions.
Herbascious J
165
I'm curious to know what tends to be 'left over' after particle collisions at sites like LHC. I realize that many different particles may arise, depending on the types of particles used for collision, as well as the kinetic energy put into the experiments. Despite the amazing diversity of outcomes these experiments produce, many of these exotic particles are short lived, and most decay almost immediately. What tends to be left over after the decay process has ceased? Are photons the most likely end-result, or is it electrons and protons, etc? Have we truly created new matter that is stable? I know certain things are supposed to be preserved, but I've never heard a good estimate, of what tends to be 'lying around' after everything happens. Particularly, I am wanting to know if we are creating or destroying matter in the end. Thanks!
Hello,
Indeed you end up with a lot of photons.
Baryon conservations tells you that you must end up with 2 stable baryons. Since you started with two protons.
Then other than that you have an overall 2+ charge in the form of pions, muons, photons, kaons (i.e. the more stable particles}, of course these end up decaying shortly after or in the detector down to electrons and neutrinos..
The important thing is that charge, energy-momentum, baryon number etc. are all conserved before and after. In reality it can be complicated if 1 proton collision interacts with another proton collisions. But same rules apply overall.
Uhh well, we created antihydrogen at CERN. It was stable. The problem is that it is difficult to keep it away from matter, and it ends up being annihilated. But it indeed was stable and can be called 'new matter', considering the fact there is no antimatter on Earth.
At the end of it all you're left with two protons to match the two original protons plus lots of photons, neutrinos, and anti-neutrinos. The photons are absorbed by the medium warming it up and the neutrinos and anti-neutrinos scape. Potentially, other neutral stable particles might be produced (axions?, neutralinos? Other dark matter candidates?) but we don't even know if those particles actually exist. The main point of those experiments is to find that out.
Hi All, Thanks for the great replies... So, does it ever happen that we are left with more stable baryonic matter than when we started?? I'm curious because I would like to know if sites like LHC can actually produce matter (like hydrogen). I'm wondering if it's possible to ultimately make atoms from energy. Maybe electrons can be created, which escape, along with the original protons. Thank you!
No. You can change the type a bit - there are nuclear reactions happening in the detector, so you change its isotopic composition. You can even convert protons to neutrons, bound in nuclei to be stable, or neutrons to protons. But the total number of baryons is conserved*. If you create new hydrogen, you have to kill baryons somewhere else (via annihilation of antiprotons and antineutrons).
New electrons are created, and if that happens via a weak process you can produce them without an positron, increasing the total number of electrons on earth. Charge conservation then tells us that you have to convert a neutron to a proton to keep the balance. The reverse process (kill an electron, convert a proton to a neutron) can happen, too.
The detector material gets activated and some of those isotopes have very long lifetimes, so the final product (as in: when you shut down the LHC) is not always stable.*there are searches for baryon number violation, but they were not successful so far.
1. What are the leftover particles after a collision at the LHC?
After a collision at the Large Hadron Collider (LHC), there can be a variety of particles that are produced. These particles can include photons, electrons, protons, neutrons, and other subatomic particles. The specific particles that are produced depend on the energy of the collision and the particles that were collided.
2. How are the leftover particles detected at the LHC?
The LHC has a series of detectors that are specifically designed to detect the particles that are produced after a collision. These detectors use sophisticated technology, such as magnetic fields, to track the movement of particles and identify their properties. The data collected by these detectors is then analyzed by scientists to understand the results of the collision.
3. Can the leftover particles be used for anything else?
Yes, the leftover particles can be used for various purposes. One example is the production of new particles that can help us understand the fundamental properties of matter. The LHC also produces large amounts of data that can be used for research in fields such as particle physics, cosmology, and astrophysics.
4. Are the leftover particles dangerous?
No, the leftover particles at the LHC are not dangerous. The energy of the collisions is carefully controlled and the particles themselves are too small to cause any harm. Any radiation produced during the collisions is also carefully monitored and kept at safe levels.
5. How do leftover particles contribute to our understanding of the universe?
The leftover particles after a collision at the LHC provide valuable information about the fundamental building blocks of our universe and their interactions. By studying these particles, scientists can gain a better understanding of the laws of nature and the origins of the universe. This knowledge can also lead to advancements in technology and medicine.
  • High Energy, Nuclear, Particle Physics
16K
12K
