00152
- 5
Could you make a fluorescent lamp with krypton instead of neon or mercury? The wavelength doesn't really matter its just if its actually possible and if it is what pressures and voltages should be used.
Vanadium 50 said:You can buy a krypton discharge lamp commercially. They are extremely expensive - as is krypton.
00152 said:Could you make a fluorescent lamp with krypton instead of neon or mercury? The wavelength doesn't really matter its just if its actually possible and if it is what pressures and voltages should be used.
Yes, krypton gas can be used to make a fluorescent lamp. It is one of the noble gases that can produce a visible light when an electric current is passed through it.
In a fluorescent lamp, krypton gas is excited by an electric current, causing its electrons to move from a lower energy level to a higher energy level. When these electrons return to their original energy level, they release photons of light, producing the glow of the fluorescent lamp.
Krypton is a very efficient gas for producing light in a fluorescent lamp. It also has a longer lifespan compared to other noble gases, making it a more cost-effective option. Krypton also produces a bright, white light, making it suitable for various lighting applications.
The main drawback of using krypton in a fluorescent lamp is its cost. Krypton is a rare gas and is more expensive than other noble gases, making it a less economical choice. Additionally, krypton gas is not as readily available as other gases, making it more difficult to obtain.
Yes, krypton can be mixed with other gases, such as argon and mercury vapor, to create a more efficient and cost-effective fluorescent lamp. The combination of these gases allows for a longer lifespan and a brighter, more consistent light output.
