Bumps on PET Bottles: Why & How?
  • Thread starter abhiroop_k
In summary, the bumps on the bottom of a PET bottle help improve stability and prevent the bottle from tipping over.
abhiroop_k
42
why does the bottom of any average PET bottle have those 'bumps' instead of being flat?
does it have something to do with improving the balance, if so how?
What's a PET bottle?
i meant any plastic (other than glass) bottle generally used for storing cold-drinks, water etc.
For stability during production, filling, and end-user use. The factory uses the feet to position the bottles in the factory for various purposes, the end-user relies on them so the bottle doesn't tip over easily. You'll see them in bottles which have internal pressure as the legs are much more rigid than a large flat surface and will remain fairly constant in their shape, making the bottle more stable when unopened, even after a long, bumpy transport.
thanks.
how are multiple curved surfaces more suitable for balance as compared to a single flat one?
is it because they account for a larger contact surface area?
Also, condensation along with a single flat surface would create a suction to the table which is not desirable.
ahh nice hadn't thought of that! :)
Well,
1) The bottles are plastic and so a flat bottom surface would, if unsupported, deflect under pressure creating a bubble on the bottom which would be horrible for stability. Not to mention it would be a pretty poor design as far as pressure vessels are concerned.
2) The legs have less overall surface area touching the table, but they are consistent in shape.
3) There are bottles which do not have the legs, but instead have a round rim along the bottom with the center recessed (so only the rim touches the table or other surface). This is for the same reason. A rigid area to stand the bottle on which will not deform under pressure.
the pressure argument makes sense!
i meant more contact area when a bottle tips over!
1. What causes bumps on PET bottles?
There are several potential causes of bumps on PET bottles, including improper cooling during the molding process, contamination of the plastic resin, and excessive pressure during the molding process.
2. Are bumps on PET bottles a safety concern?
In most cases, bumps on PET bottles are not a safety concern. However, if the bumps are large or affect the structural integrity of the bottle, it is important to dispose of the bottle properly and avoid using it for food or beverage storage.
3. Can bumps on PET bottles be prevented?
Yes, bumps on PET bottles can be prevented by ensuring proper cooling and pressure during the molding process, as well as using high-quality, uncontaminated plastic resin. Regular maintenance and cleaning of molding equipment can also help prevent bumps from forming.
4. Are bumps on PET bottles common?
Bumps on PET bottles are not uncommon and can occur in various industries that use PET bottles, such as food and beverage, pharmaceutical, and cosmetic industries. However, with proper manufacturing processes, they can be minimized or eliminated.
5. Can bumps on PET bottles be fixed?
Unfortunately, bumps on PET bottles cannot be fixed once they have formed. The only solution is to properly dispose of the affected bottles and ensure that future bottles are manufactured with proper processes to prevent bumps from occurring.
  • Biology and Medical
  • General Engineering
