Fate of relict radiation patterns
In summary, relic radiation has spatial fluctuations in the form of hot and cool spots that are of modest amplitude but detectable. It is possible to observe these patterns evolve into galaxy clusters or voids over time, but this is complicated by the accelerating expansion of the universe. The relic radiation we see now will eventually cool and become transparent, and we will be able to continue observing it through other means such as the 21 cm line. The redshift of these patterns will decrease until it reaches a minimum and then increase again. Currently, the higher redshift objects have decreasing redshifts while lower redshift objects have increasing redshifts. However, due to limited observation time, we have not yet been able to see this change in redshift
snorkack
2,190
477
Relict radiation has spatial fluctuations: hot and cool spots. Of rather modest amplitude, but yet detectable.
Have these patterns undergone any change?
Galaxies are supposed to form a few hundred million years after big bang.
If you watched a given hot spot of relict radiation, would it eventually be seen to evolve into a galaxy cluster, and cold spots into voids, or vice versa?
And how long would it take in order to watch an object visible as a relict radiation pattern as of now to evolve into a young galaxy?
Astronomy news on Phys.org
Without accelerated expansion, you could do this. The cosmic microwave background is redshifted by a factor of ~1100 - everything we observe there is slowed down by that factor. The factor changes with time, so you cannot just multiply it with the time it took for stars to form, but it should give a rough estimate how long we would have to wait.
This is not the world we live in, however. Expansion is accelerating. Assuming this will continue, you can never observe how the currently visible patterns evolve into stars or galaxies. Those objects are too far away, their light will never reach us.
Neglecting observational issues (there is no light emitted in this period), you would see that light from this matter gets more and more redshifted, and correspondingly the passage of time appears slower and slower to us.
After relic radiation, atomic hydrogen would have emitted mainly 21 cm radiation, right? Which, at the relic radiation end, has been redshifted to 230 m, and smaller wavelengths at later times?
Right. The detection of this radiation is one of the goals of LOFAR.
If we look at an object of a specified age:
Would we see that object for a finite time, or infinite time, here?
Would our observations from now on span a finite time at the said object, or infinite time there?
For objects gravitationally bound to us, you can observe them as long as you like (both with their and our clock).
For other objects, you can keep watching them as long as you like, but the intensity will drop so much that it becomes impractical after a while (up to the point where you get "the last photon"). The total evolution of those objects that will be visible to us is finite, similar to the matter that emitted the CMB we see today.
The answers to these questions are fairly subtle. For example, if we watch in real time the redshifts of a high redshift object, we see its redshift decrease.
I hope to do some fairly realistic calculations, and, sometime in the next few days, I hope post some graphs.
Relic radiation was said to have been emitted over a period of about 115 000 years.
Since it was emitted at redshift 1100, it would seem that over a period of about 120 million years, all relic radiation patterns now visible ought to recombine and be extinguished - revealing completely new relic radiation patterns beyond, at (slightly) bigger redshifts.
Is that correct?
The same correlations we see in space are present in time as well, that makes the analysis more complicated - but the main point is right, the fluctuations will change in time.
Another issue is the integrated Sachs-Wolfe effect. Subtracting that from the cmb is a problem.
The temperature of relic radiation decreases with time.
The temperature of relic radiation at its origin patterns is unchanged - it is determined by the temperature where hydrogen recombined long ago.
Say that in a hundred million years or so, the redshift of relic radiation seen on Earth increases from 1100 to 1110.
It will be completely new patterns - but originating at the same temperature, further behind the patterns we see now.
The relic radiation patters we see now will in a hundred million years be seen in galaxies a hundred million years behind us - and these will also be at redshift 1110 there.
So, we see the new and further relic radiation patterns at redshift 1110. But what will have happened to the old relic radiation patterns we saw now at redshift 1100?
They will have cooled and become transparent. Well, we can continue observing them in other manners, like the 21 cm line. They will be in the foreground of the relic radiation, and they will have redshift now smaller than the 1110 of background relic radiation.
Will their redshift be still 1100? Something bigger than 1100 but smaller than 1110, like 1105? Or something smaller than 1100, like 1090?
The observed redshift will decrease until it reaches a minimum, and then it will increase. I haven't yet calculated by how much and how long the redshift will decrease.
At anyone time, are the redshifts of specific objects all decreasing, or some decreasing and some increasing?
Some are decreasing, and some are increasing. Right now, the higher redshift objects have redshifts that are decreasing, and lower redshift objects have redshifts that are increasing.
George Jones said:
As Aimless said, observation time have been too short to see redshift change. We are close to being able to do this, but, for economic and other reasons, such a project won't start for several decades. Once started, the project would take a couple of decades to start to get good results. See
http://arxiv.org/abs/0802.1532
Also, redshifts don't necessarily increase with time. Figure 1 from this paper plots redshift versus time. The three red curves are for objects in our universe. As we watch (over many years) a distant, high redshift object, A, we will see the object's redshift decrease, reach a minimum, and then increase. If we watch a much closer, lower redshift object, B, we see the object's redshift only increase.
Roughly, when light left A, the universe was in a decelerating matter-dominated phase, and when light left B, the universe was in the accelerating dark energy-dominated phase.
I wanted to do the analysis myself in different way, but it doesn't look like this is going to happen before I go on holiday on Monday.
What is the redshift that is staying constant, right now?
1. What is relict radiation?
Relict radiation, also known as cosmic microwave background (CMB), is the residual radiation left over from the Big Bang. It is the oldest light in the universe and can be observed in all directions in the sky.
2. How does relict radiation relate to the fate of the universe?
Relict radiation is an important piece of evidence in determining the fate of the universe. Its properties, such as temperature and distribution, provide information about the overall structure and evolution of the universe.
3. What are the main patterns observed in relict radiation?
The main patterns observed in relict radiation are the anisotropies and fluctuations in temperature. These patterns are believed to be the result of density variations in the early universe, which have been stretched over time due to the expansion of the universe.
4. How do scientists study the fate of relict radiation patterns?
Scientists study the fate of relict radiation patterns through various methods, including mapping the temperature fluctuations using telescopes, analyzing the polarization of the radiation, and studying the power spectrum of the radiation.
5. What can the fate of relict radiation patterns tell us about the future of the universe?
The fate of relict radiation patterns can provide insights into the future of the universe, such as whether it will continue expanding forever or eventually collapse in a "Big Crunch." It can also help us understand the amount and distribution of dark matter and dark energy, which play a crucial role in the fate of the universe.
  • Astronomy and Astrophysics
  • Other Physics Topics
  • Cosmology
  • Beyond the Standard Models
