| New Reply |
Confusion with units for Power Required Formula |
Share Thread |
| Sep14-12, 07:27 AM | #1 |
Hi all,
I'm having trouble with the power required formula for steady level flight. Here's the formula: Preq = 4/3*W*sqrt(W/S*2/ρ*sqrt(3*CD0/(π*ε*A))) I'm using this for a small indoor RC fixed wing. The values I'm using are as follows: Weight, W = 0.3924N Wing Area, S = 0.073 m^2 Density, ρ = 1.226 kg/m^3 Zero lift drag, CD0 = 0.03 Span efficiency, ε = 0.9 Aspect Ratio, A = 15 These values are giving me a power required of 0.051 W, which is almost exactly 1000 times less than what I know the electric motor uses, since it holds SLF at half throttle and the max power rating for the motor is 100W. Where am I going wrong? I know I've gotten my units mixed up but I can't work out where. Help! :/ |
| Sep14-12, 08:16 AM | #2 |
Recognitions:
Your weight of 0.392N corresponds to a mass of about 40 grams or 1.5 ounces.
An electric motor producing 100W with a mass as small as that (plus the mass of the battery to power it) doesn't seem very plausible to me. |
| Sep14-12, 09:05 AM | #3 |
I agree with AlephZero. Also, there is something to say about your formula and calculations. When you plug in the numbers into the formula given, it doesn't return 0.051 W. But it does with this one:
Pmin = (1/2 * (4/3)¾ + 1 / (1/2 * (4/3)¼) ) * sqrt(W³/ρ/S * sqrt(CD0/(π*ε*A)³)) This represents the minimum power required (Preq) for SLF. It happens only at a certain velocity Vminimum power. At any other velocity, it will take more power. You can find the formulae for both here and combine them to obtain the previous equation. |
| Sep14-12, 09:41 PM | #4 |
Confusion with units for Power Required FormulaPreq,min = 4/3*W*√(W/S*2/ρ*√(3*CD0/(π*ε*A)3)), which is equivalent to what you are using. The reason I'm confused is that a power drain of 0.051W would take 70.8 hours to deplete the battery I'm using (500mAh or 13 000 J), whereas 51W depletes it in 4.24 minutes, which is about the flight time of this aircraft, give or take. Here's the motor I'm using: http://www.hobbyking.com/hobbyking/s...dProduct=17591 Max Current= 14A, Max Voltage = 7V, therefore max power consumption is 98W ~ 100W It produces about 0.4N thrust with the GWS prop i'm using. |
| Sep15-12, 08:15 AM | #5 |
You're missing the point. According to the hobby site and the wing dimensions you gave, your plane mass is easily between 2 and 3 kg, which represents a weight between 19.62 and 29.43 N (W = mg).
Putting that in the equations gives: For W = 19.62 N, Pmin = 18.05 W @ V = 15 m/s; For W = 29.43 N, Pmin = 33.17 W @ V = 18.3 m/s. At any other speed (slower or faster), the power consumption will increase. |
| Sep15-12, 10:14 AM | #6 |
| Sep15-12, 12:08 PM | #7 |
You will have to describe your airplane in more details because something doesn't add up.
Your motor weight is 23 g. A 500 mAh battery, 7.4 V (it is the voltage you use for your calculations) weight around 30 g. That is already 53 g. Even using a 450 mAh, 3.7 V battery, the weight is still 11 g, which combined to your motor gives a total of 34 g. With the wing area (0.073 m²) and aspect ratio (15) given, your wingspan should be 1046 mm. The only airplanes I found that are close to your specs are these one: Micro F4 jet: 100 g, 7.4 V-500 mAh battery, 540 mm wingspan; Micro 3D Piaget: 50 g, 100 mAh to 200 mAh battery, 418 mm wingspan; Freeflight P-26: 41 g, rubber band powered, wingspan 466 mm. All of these airplanes seem to be about half the size of yours. Another point about the motor specs. The maximum efficiency is 78% @ about 7.5A, which give an output of 43 W @ 7.4V. The efficiency will be lower at 14 A, so you will never obtain an output of 98 W. Finally, with the specs you gave, the speed for minimum power should be 2.11 m/s, which is slightly faster than a person walking. How do you evaluate your speed? |
| Sep15-12, 05:54 PM | #8 |
Recognitions:
So at least we have SOME numbers that make sense. |
| Sep16-12, 04:04 AM | #9 |
I've been using approximations up until now, but no approximation should knock my power required out by 100x... Mass: 23g(motor) + 36g (battery) + 10g(airframe) + 20g(All other electronics) = 89g (more than twice what I quoted) Wing Area: 0.09m^2 Aspect Ratio: 4 (much much lower than what I quoted) Span efficiency: ~0.7 (assumed) CD0: ~0.03 (assumed) density: 1.226 kg/m^3 (Sea Level Conditions) Battery capacity: 500 mAh (~13 000 J) Average flight time: 4-5 mins Average loiter speed: 2-3 m/s (d/t measured at an indoor basketball court) With these values, I get Preq of 0.4966 W, which is still too small! |
| Sep16-12, 11:19 AM | #10 |
I don' t think 0.5 W is too small. If you use the equation for the power required at a speed of 2.5 m/s, you get 0.65 W (because with the new data, the speed for Pmin is now 4.2 m/s).
You said in an earlier post that your propeller produced 0.4 N of thrust. Combined with a speed of 2.5 m/s, it gives a power of 1 W for your airplane. So we are still in that region, far from the 50 W you are expecting. Is your battery OK? Rechargeable batteries can have problems if they are not cared for properly (example). From Wikipedia about LiPo batteries: |
| Sep22-12, 07:21 AM | #11 |
| New Reply |
| Tags |
| mav endurance power |
Similar discussions for: Confusion with units for Power Required Formula
| Thread | Forum | Replies | ||
| Linear momentum confusion(help required) | General Physics | 7 | ||
| Units of Force Confusion lb/in | General Physics | 5 | ||
| Fluid pressure problem and units confusion | Introductory Physics Homework | 1 | ||
| Thermodynamics question - does power required mean same as power output? | Introductory Physics Homework | 3 | ||
| Units confusion in calculations | General Math | 9 | ||
