How Quickly Does an Ideal Gas Expand with Temperature Change?
In summary, the ideal gas law states that PV=nRT where n is the number of moles of gas present and R is the universal gas constant. If pressure and amount of gas are held constant, the rate at which it expands is constant.
daniel3777
can anyone give me an equation for the rate that an ideal gas expands in a temperature change. like when a gas goes from 30 degrees to 50 degrees in a baloon. how quickly would it expand?
Chemistry news on Phys.org
you need to use the ideal gas law to figure it out.
Let P be the pressure of a gas, V the volume it occupies, and T its temperature (which must be in absolute temperature units, i.e., in Kelvin). Then the ideal gas law states
PV = nRT
where n is the number of moles of gas present and R is the universal gas constant, or equivalently
it would expand to the new volume as the gas temperature inccreases, there isn't a real amount of time it takes to expand, it just expands as the temperature increases. if the temperature were to suddenly increase by 20 degrees, then the gas would suddenly expand to the the new volume, but normaly it would be a gradual process because the temperture increasing is a gradual process.
Well, the ideal gas law is only valid for static systems, right? So I guess the answer would be that it would take as long as was needed for the system to re-equilibrate at the new parameters.
Maybe you can try to use diffusion alternative... Diffusion rate changes in an indirectly proportional way with the molecular mass.
It seems to me that you would have to take the partial derivative of Volume with respect to T so you would get dV/DT=nR/P. So if pressure and amount of gas is held constant, the rate at which it expands is constant.
This is basically the same thing that Guy-Lussac's law says. V=kT where k is some constant. So for example, if T doubles then volume will double (only if pressure and the amount of gas is held constant). Writing dV/dT=nR/P is just a more "sophisticated" way of stating the same thing.
1. What is the definition of rate of ideal gas expansion?
The rate of ideal gas expansion refers to the change in volume of an ideal gas per unit time. It is a measure of how quickly the gas expands or contracts in response to changes in temperature, pressure, or volume.
2. How is the rate of ideal gas expansion calculated?
The rate of ideal gas expansion can be calculated using the ideal gas law, which states that the volume of an ideal gas is directly proportional to its temperature and inversely proportional to its pressure. This can be expressed mathematically as rate of expansion = (V2 - V1) / (T2 - T1) = (P1V1 - P2V2) / (T2 - T1), where V is volume, T is temperature, and P is pressure.
3. What factors affect the rate of ideal gas expansion?
The rate of ideal gas expansion is affected by temperature, pressure, and volume. An increase in temperature or a decrease in pressure will result in a faster rate of expansion, while a decrease in temperature or an increase in pressure will result in a slower rate of expansion.
4. How is the rate of ideal gas expansion related to the kinetic theory of gases?
The kinetic theory of gases explains that gases are composed of particles that are in constant, random motion. The rate of ideal gas expansion is related to this theory because it is a measure of how quickly these particles are moving and colliding with each other, which determines the rate of expansion.
5. What are some real-world applications of the rate of ideal gas expansion?
The rate of ideal gas expansion has many practical applications, such as in the design and operation of engines, refrigeration systems, and air conditioning units. It is also important in understanding weather phenomena, such as the expansion and contraction of air in response to changes in temperature and pressure. Additionally, the rate of ideal gas expansion is used in industrial processes, such as the production of chemicals and the purification of natural gas.
  • Chemistry
  • Classical Physics
  • Classical Physics
  • Materials and Chemical Engineering
