What Are Harmonics and How Are They Created in Electrical Circuits?
  • Thread starter RozzerETO
In summary, harmonics are a mathematical concept that refers to multiplies of a fundamental frequency in a driven non-linear system. VFDs and THD are typically improved by avoiding harmonics.
RozzerETO
so, I've been doing some research on harmonics recently and i can't actually find a good explanation of how they are created or what the effect. I have a feeling that they are something to do with 'clipping' the sinusoidal waveform to get the desired voltage. VSDs?
In their purest mathematical sense Harmonics are signals or part of the waveform at multiples of the fundamental frequency. Basically ANY distortion of the pure sinusoid - will result in harmonics. ( It is interesting / important to note - that ALL signals can be broken down into a sum of wave forms - all of which are multiples of some fundamental frequency - for noise this is true within a specific bandwith...)
For VFDs - one important measure of the quality of the drive is the THD - Total Harmoinic Distortion. Ideally this should not look like clipping - but I am sure some drives end up with a waveform that looks clipped.
The typical effect of harmonics are overheating of magnetics ( Motors, Transformers etc) for "low order" harmonics, that is Harmonics between 2nd and 12th my 20th Harmonic. Another issue, more common with higher order ( Starting around the 12th upward), is increased voltage stress on the conductors and insulation systems ( also in the transformers and motors - etc). They can also cause interference with other devices ( EMI ) due to the power / frequency levels involved.
I don't know your level of knowledge, but if you're asking from a signal analysis or mathematical point of view, any non-sinusoidal waveform will have harmonics because it's non-sinusoidal. As Windadct alludes to, in order to create that non-sinusoidal waveform, you need the contribution of higher-power sinusoids (determined via Fourier Analysis):
I just wanted to post to share the animation, which probably comes from this site:
http://blog.matthen.com/post/42112703604/the-smooth-motion-of-rotating-circles-can-be-used
Sorry but I have to disagree with lolone's whole post. Harmonics can be completely understood without this info. Signal theory only, and photons- what?
Yes, please ignore lolone's post.
Harmonics is a mathematical concept, you don't need any physics to understand it.
Harmonics specifically refers to multiplies of a fundamental (for a 50 Hz system the harmonics would be 100, 150, 200 Hz etc), not just any frequency as Iolone's post would suggest.
Here is a decent article on harmonics with regards to VFD's and THD.
http://literature.rockwellautomation.com/idc/groups/literature/documents/wp/mvb-wp011_-en-p.pdf
http://support.fluke.com/find-sales/Download/Asset/1260362_6003_ENG_K_W.PDF
the second site has some handy DMM tests for harmonics although those tests won't tell you what harmonic number is involved only that harmonics are present.
thanks very much for all the replies, they have helped me grasp the subject! in reply to what my depth of knowledge is, I am currently doing a Marine electrical engineering degree! thanks very much for all your help!
I have messaged the moderator to restore the post. Harmonics is not a mathematical concept. Mathematics is used to describe a physical system, therefore harmonics is a product of the physics.
This should be obvious since you are dealing with charge carriers and photons. This is what electricity is and you cannot measure something that is not a product of these quantum particles.
I'm sure as engineers you have mathematical descriptions of what is happening, but in order to understand it fully everyone needs to understand the physics.
Firstly. I am not an engineer, I am an experimental physicist.
Secondly, harmonics is a mathematical concept (from Fourier analysis) applicable to a very wide range of phenomena, some electrical some not. You can have harmonics in any driven non-linear system, a mechanical system would be an obvious system.
Hence, trying to explain it by referring to details of charge transport (which btw were incorrect) is just silly
Finally, a physicist. Then you should really get my point here. Fourier analysis is just a transform, we are no longer looking the group (or time domain) activity, but the individual frequencies (or rates of change in direction of charged particles) that make up that group activity.
So, in the Fourier analysis, we are not looking at purely mathematical concept, we are looking at how the system really is, albeit with limited resolution. It is the "time domain" that is the mathematical concept.
In terms of describing what harmonics is, its best to look at it in terms of collisions and particle exchanges.
Actually, let me put that a little bit better:
Time Domain - Voltage - is a summation of group activity
Frequency Domain - Factorization of the voltage
In terms of harmonics, we are interested in the factorization of the voltage as it is these interactions that give rise to harmonics.
Thread closed for Moderation...
This thread will remain closed.
The OP has gotten good information about his question, and there is too much misinformation in lolone's posts to effectively clean up the thread.
lolone -- check your PMs.
What are harmonics?
Harmonics are musical tones that are produced by the vibration of a string or object. They are a series of overtones or multiples of the fundamental frequency.
How are harmonics created?
Harmonics are created when a sound wave is reflected back on itself, causing interference and producing a series of frequencies that are multiples of the original frequency.
What is the significance of harmonics in music?
Harmonics play a crucial role in creating a rich and complex sound in music. They add depth, texture, and character to a musical piece and are essential in creating different timbres and tones.
Are harmonics only present in music?
No, harmonics are present in all types of sounds, including non-musical sounds. They are a natural phenomenon that occurs whenever a sound wave is reflected back on itself.
How do harmonics affect sound quality?
Harmonics can greatly impact the sound quality of a musical piece. They can make the sound more vibrant and full-bodied or create an unpleasant and dissonant effect if not utilized properly.
  • Electrical Engineering
