Acid, Base, and Buffer Titration Problem
In summary, the pH of a buffer solution made with an unspecified amount of acetic acid and 0.300 moles of NaC2H3O2 was measured as 4.40 on a meter. Using the Henderson-Hasselbalch equation, it can be determined that approximately 0.43 moles of acetic acid were used in the solution.
MitsuShai
159
I missed this question on an exam and I was wondering if anyone can explain to me how to do it.
The pKa of acetic acid, HC2H3O2, is 4.76. A buffer solution was made using an unspecified amount of acetic acid and 0.300 moles of NaC2H3O2 in enough water to make 2 Liters of solution. Its pH was measured as 4.40 on a meter. How many moles of HC2H3O2 were used?
K= [products]/[reactions]
pH= pKa + log (A/HA)
Ka= 10^(-4.76) = 1.74 x 10 ^(-5)
Kb = 5.75 x 10^(-10)
pH =4.4 [H]=3.98 x 10^(-5)
pOH= 9.6 [OH]= 2.51 x 10^(-10)
moles of OH= 2.51 x 10^(-10) x 2= 5.02 x 10^(-10) moles
Base_________+____H2O -->___Acetic Acid_+_____OH +______Na
.3 moles______________________x_________________0
-5.024 x 10^(-10)__________5.02 x 10^(-10)_______5.02 x 10^(-10)
.2999 moles_______________x+ 5.02 x 10^(-10)______5.02 x 10^(-10)pH=pKa + log(A/HA)
4.4=4.76+ log (.3/(x+5.02 x 10^(-10)))
=10^-(-.36)= 10^[log (.3/(x+5.02 x 10^(-10)))]
2.29= .3/(x+5.02 x 10^(-10)))
(2.29)(x+5.02 x 10^(-10))=.3
x=.131 moles
.3 + .131= 0.43 moles
Most of what you did is irrelevant to the question, and to be honest - I don't plan to try to understand what you did and why. For some reason you decided to take into account base hydrolysis, but you ignored acetic acid dissociation (these both processes take place in the solution). But - and this is the most important hint at solving the problem - when doing buffer questions we usually ignore both dissociation and hydrolysis, assuming they are neglectable.
Start with HH equation, solve it for the concentration of acetic acid - and as you know volume of the solution, you are done.
What is acid-base titration?
Acid-base titration is a laboratory technique used to determine the concentration of an acid or base solution. It involves adding a known amount of a base or acid of known concentration to an acid or base of unknown concentration until a neutralization reaction occurs.
What is a buffer solution?
A buffer solution is a mixture of a weak acid and its conjugate base or a weak base and its conjugate acid. It helps to maintain the pH of a solution by resisting changes in pH when an acid or base is added to it.
Why is it important to use indicators in titration?
Indicators are added to the solution during titration to signal when the acid and base have reached an equivalent point, also known as the endpoint. This helps to determine the exact volume of acid or base needed to neutralize the solution.
How do you calculate the concentration of an unknown solution in titration?
To calculate the concentration of an unknown solution in titration, the volume and concentration of the known solution and the volume and concentration of the unknown solution must be known. The concentration of the unknown solution can be calculated using the equation: MAVA=MBVB, where M is the molarity and V is the volume.
What is the purpose of a standard solution in titration?
A standard solution is a solution with a known concentration that is used in titration to determine the concentration of an unknown solution. It is important to use a standard solution to ensure the accuracy and precision of the titration results.
  • Biology and Chemistry Homework Help
