New Reply
matlab or mathematica
Share Thread Thread Tools
Feb17-13, 11:01 AM   #1
I wonder which one is more accurate when solving differential equations?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Feb17-13, 04:00 PM   #2
mfb
Mentor
Accurate in which way?
Smaller numerical errors? Depends on the way you try to solve it, internal details of the programs and the accurary you need.
Less bugs? No idea
Feb18-13, 07:16 AM   #3
Recognitions:
Gold Membership Gold Member
Since both have been used extensively for a long time, the chance of "accuracy" problems is very small. I would use the one that that I was most familiar with.
Generally, software that is inaccurate or does calculations incorrectly either gets corrected by its authors or people stop using it. And users find something that does work as intended.
Feb18-13, 07:20 AM   #4
All things being equal, they're probably about the same numerically in most cases and they both have symbolic DE solvers that cover a reasonable number of physical cases ... I think you'd have to have something in mind or a set of test cases to make a comparison. If you were to hold a pistol against my head, I'd probably guess Mathematica ... but I'm rather unlucky ... I once failed an ESP test dismally (least sensitive person they'd ever seen, apparently), I got 100% wrong.
Feb18-13, 07:54 AM   #5
Thanks. I'm dealing with the restricted circular three-body problem and solving the differential equations though numerical methods, ode15s on matlab and NDSolve on mathematica.
Feb18-13, 08:21 AM   #6
Quote by ENDLESSYOU View Post
Hmm. I would have thought ode45 would be a better choice for that problem in most cases. It's the one Mathworks use in their documentation - http://www.mathworks.co.uk/help/matl...?s_tid=doc_12b
What led you to ask the question? Do you see any significant differences between Mathematica and Matlab? It doesn't address your particular case, but several years ago I partially-validated Matlab 6-dof simulation in Mathcad - the two applications gave very good agreement using a fixed 4th-order RK.
Feb18-13, 08:30 AM   #7
Quote by NemoReally View Post
They're stiff differential equations so ode15s might be a better choice. In my experience, MATLAB is more 'stable' than Mathematica. I once executed a same nb file on Windows and Ubuntu, but I got two different results.
Feb18-13, 09:10 AM   #8
Are running modified DEs or getting very close to the "mass" centres? IME, the 3-body problem isn't generally treated as still, and the adaptive rk45 solver is usually good enough. Have you compared the results of running ode15 vs ode45?
OK, that would make the Mathematica implementation a bit more suspect. Are there global parameters in the 2 versions of Mathematica that might be different? How does the Mathematica version compare to the Matlab in the same environment?
New Reply
Thread Tools
Similar Threads for: matlab or mathematica
Thread Forum Replies
MATLAB and Mathematica help Math & Science Software 0
matlab vs mathematica Math & Science Software 20
how write the 'for' loop in mathematica Math & Science Software 11
how to write matlab code in mathematica Math & Science Software 0
Matlab/Mathematica help! Math & Science Software 1
