- #1
ditto_299
- 7
- 0
c = 1mol/dm3
v = 25cm3
would i have to keep the units constant, as in multiply the 25cm3 by 1000??
Thanks!
v = 25cm3
Thanks!
ditto_299 said:...as in multiply the 25cm3 by 1000??
ditto_299 said:i forgot whether M x cm^3 equaled to some other unit?
"N= cv keeping unit constant" is a scientific concept that refers to the relationship between variables in an experiment. It means that the number of units (N) is directly proportional to the constant value (c) and inversely proportional to the variable (v).
Keeping the unit constant in an experiment is important because it allows for accurate and consistent measurements. It ensures that any changes in the outcome of the experiment are due to the manipulation of the variable, rather than differences in the units used.
To keep the unit constant in an experiment, it is important to use the same measuring tools or instruments, calibrate them regularly, and use the same units of measurement throughout the experiment. It is also important to control any external factors that could affect the unit, such as temperature or humidity.
Experiments that involve measuring and comparing quantities, such as physics experiments or chemistry experiments, typically involve keeping the unit constant. This ensures that the results can be accurately compared and analyzed.
Keeping the unit constant in an experiment allows for more accurate and reliable results. It also makes it easier to replicate the experiment and compare results with other studies. Additionally, it eliminates the possibility of errors due to differences in units and helps to ensure the validity of the conclusions drawn from the experiment.
