Register to reply
Special substance (adhesive or paint)
by lawrence
Tags: adhesive, paint, special, substance
Share this thread:
lawrence
#1
Apr2-14, 05:10 PM
P: 2
Hi !
Can you recommend me a glue or paint or other chemical substance with the following properties:
- should be transparent
-should have a refr. index less than 1.6
-could be easily peeled off from glass
- should not dissolve in the same substance after drying (I want to make a thin film, peel it off and then stick it with the same substance to an optical device, but the film should not destroy)
-it is preferably but not mandatory that it should not dissolve in water
Thank you!
Phys.Org News Partner Engineering news on Phys.org
Comfortable climate indoors with porous glass
Crash-testing rivets
Customized surface inspection
Baluncore
#2
Apr29-14, 03:09 AM
Sci Advisor
Thanks
P: 1,788
Maybe clear epoxy resin. RI = 1.5x
http://www.ntt-at.com/product/hl_resins/
The clear part of a two part epoxy can make a good optical grease.
Baluncore
#3
Apr29-14, 07:47 AM
Sci Advisor
Thanks
P: 1,788
More data;
http://www.eoc-inc.com/optical-coati...capsulants.htm
You may need to use a film or release agent when casting on a glass surface.
Register to reply
Related Discussions
Does exposure to a radioactive substance make another substance radioactive? General Physics 5
Waterproof adhesive or glue, how to make a glue/adhesive Waterproof! Urgent Please! Materials & Chemical Engineering 1
Waterproof adhesive or glue, how to make a glue/adhesive Waterproof! Urgent Please! General Engineering 6
Waterproof adhesive or glue, how to make a glue/adhesive Waterproof! Urgent Please! Chemistry 1
Adhesive tape Introductory Physics Homework 0
