Is there a Conceptual problem here? (Pressure in the Kinetic theory of gases)
In summary: L/v...Δt3So you are still doing two different calculations, one for Δp and one for Δt. I think there is a problem with the whole assumption that the pressure of a gas is proportional to the mean square speed of its molecules.
Dyon
30
I have reviewed recently the demonstration of the formula for the pressure of a gas by using the kinetic theory and it seems that there is a terrible flaw in it, which I will describe below. Can anyone comment on it, please?
In all textbooks, the pressure of a gas is proven to be proportional to the mean square speed of its molecules. The demonstration starts with the observation that the pressure of a gas is due to the ellastic collision of molecules with the walls of the container. Therefore, it calculates the change in the momentum arising from the elastic collision of one molecule with the wall, which is
Δp = 2mv (where v is the component of the molecule velocity perpendicular to that wall)
Nothing wrong up to here.
However, when calculating the force produced by this collision, instead of dividing this change in momentum to the time during which this collision takes place (Newton's second law), the authors divide the change in the momentum by the time taken by the particle to travel to the opposite wall and back 2L/v (where L is the length of the box perpendicular to the wall). They write
F = change in momentum / time taken = 2mv / (2L/v)
I contend that there is a serious problem here because the two time intervals obviously refer to different things.
You can see this here http://en.wikipedia.org/wiki/Kinetic_theory but is in fact in every textbook.
Don't you think that there is something wrong with this derivation?
Waiting for your comments. Thanks
No, the derivation is fine.
What you refer to is the force per collision, so to say. However, this is not the quantity of interest here. For calculating the pressure you want the mean (time-averaged) force of the particle on the walls. This is the force per collision divided by the waiting time between subsequent collisions and equivalent to the change in momentum per collision divided by the time the particle takes to reach the wall again.
There still seems to be a problem... doesn't the equation treat all atoms/molecules simply by count and not distinguish them by their different masses, and thereby momentums?
A box of H2 at the same pressure as a box of O2, both boxes with the same volume?
Now I am puzzled and do not know what you mean. How can a term poportional to 2mv and therefore directly proportional to mass not take mass into account?
Once you get to the point change in momentum per collision = 2mv an alternative way to get an expression for the force on the wall is to say Force = change in momentum per second (ie force = rate of change of momentum)
Therefore Force = 2mv x number of collisions with the wall per second.
The time for the molecule to return to the wall is 2L/v seconds therefore the number of collisions per second by this molecule = 1/(2L/v) = v/2L
Therefore force due to this molecule = 2mv x v/2L = mv^2/L
Therefore the force due to N molecules = N/3 X mv^2/L = Nmv^2/3L
Thereore the pressure = F/Area = F/(axb) (a, b are dimensions of end wall)
P = Nmv^2/3(lab)
hope this helps
The derivation has stood the test of time.
However, a more phenomenological way of looking at gas pressure is as the simple product of the mean number of molecular impacts per unit area per second and the mean impulse per impact; that is as the mean flux times the mean impulse. For non-standard notation, let's say, P=FI.
The mean frequency of impact is the simple product of half the number density times the mean molecular speed along any single axis of movement. F=van/2.
The mean impulse per impact is the simple product of the molecular mass and twice the mean impulse speed. I=m2vb
The result is P = nmv2, the standard molecular definition of pressure.
Thanks for your reply. But I am afraid that the problem still remains.
Even if you calculate the average force, you will still have to divide the change in momentum in an elastic collision of a molecule (Δp = 2mv ) by the total time (Δt) taken until the next collision with the same wall takes place.
This total time (Δt) is made up of: the time of the collision of the molecule with the initial wall (δt), the time taken by the molecule to travel to the opposite wall (L/v), the time of the collision with the opposite wall (δt), and the time taken by the molecule to arrive at the initial wall (L/v) ; only after the elapse of these intervals does the next collision begin. So the total time between collisions is not just 2L/v but Δt = δt + L/v + δt + L/v, that is Δt = 2(δt) + 2(L/v).
Therefore the average force would be F = Δp / Δt = (2mv) / [2(δt) + 2L/v] and this becomes equal to (2mv) / (2L/v) only if you neglect δt and put it equal to zero.
So now I came to think that probably the demonstration of the formula for pressure should include a reference to the fact that the collision time of the molecule with the wall is negligible. Still, I do not know if such an approximation is realistic.
There are many assumptions in the kinetic theory.
One assumption is that the time for a collision is zero.
The fact that the theory is good for a wide range of pressures and temperatures means that the assumptions are good
No.
The pressure on the wall is due to the force imparted by a population of particles. In steady-state with a uniform temperature and constant pressure, the particles (each of mass m) would collide with the wall at the same rate. Assuming also uniform density (no local concentration above the average/mean), some particles having recoiled from the wall will traverse back to the opposite wall and return in Δt=2L/v, during that period some N particles will have hit the wall at some rate. Summing up the total Δv from all the particles and divide by the period over which those particles are counted.
So the force would be m Ʃi(Δvi)/Δt, i = 1, N, and Δv is the change in the velocity compoent normal to the surface being struck.
Thanks, Astronuc.
But having said that "some particles having recoiled from the wall will traverse back to the opposite wall and return in Δt=2L/v", you overlook the time spent by those particles in contact with the opposite wall (time of collision).
It is probably insignificant, but it does no harm if aware of this approximation.
In my opinion the best kinetic theory derivation of the pressure formula is that used by Jeans in The Kinetic Theory of Gases. He doesn't consider the bouncing of molecules between opposite walls, but instead with the flux of molecules approaching a patch of wall at various angles. The method is simple and convincing.
All explanations that match experimental observations are, by definition, ' good'
The best is a subjective decision based, I would say, on experience and level of study.
Kinetic theory implies dealing with a gas as a system of particles. At low temperatures this is not good enough and 'wave' properties need to be applied.
This would not be called 'kinetic' theory
Agreed. That's why I said "in my opinion". My main criterion for a good derivation is how convincing I find it. Jeans's derivation doesn't rely on a special shape of box, nor on each molecule having an uninterrupted path across the box, nor on each collision with the wall being individually elastic.
As you imply, the derivation based on molecules bouncing around in a cuboidal box delivers the right formula, and this isn't by accident; I just don't find it convincing. Put it this way: if I'd been clever enough to think of it myself, I would want someone to find a different way to do it, as a check.
I think I go along with your thought Philip.
When I taught kinetic theory the biggest problem I had was convincing the students that the derivation did not just apply to rectangular box.
But there was no doubt that considering a rectangular box was the easiest way to get the idea across. The derivation considering components of velocity in x, y and z directions was usually too mathematically challenging for some students, especially those not studying maths at that level.
technician: Did you ever come across the derivation using a spherical container? It is a lot simpler than the one for the cuboidal container because you work with molecular speeds from the outset, rather than with velocity components, so you don't have to introduce
[tex]\bar{c^{2}} = \bar{u^{2}} + \bar{v^{2}} + \bar{w^{2}}.[/tex]
What is quite astonishing is the way the factor of 1/3 appears in this derivation, compared with the way it appears in the cuboidal box derivation!
Using my how convincing? criterion, this derivation is at least as bad as the one for the cuboidal box, but I suppose if you take both together their joint impact is rather persuasive!
I want to thank you all for your comments. They were very helpful and I think I have found the answer to my issue.
1. What is the Kinetic theory of gases?
The Kinetic theory of gases is a scientific model that explains the behavior of gases based on the motion of their particles. It states that gas particles are in constant, random motion and that their collisions with each other and with the walls of their container are the cause of gas pressure.
2. How does pressure relate to the Kinetic theory of gases?
In the Kinetic theory of gases, pressure is directly related to the average kinetic energy of gas particles. As the temperature of a gas increases, the particles move faster and collide with each other and the container walls more frequently, resulting in an increase in pressure.
3. What is the conceptual problem with pressure in the Kinetic theory of gases?
The main conceptual problem with pressure in the Kinetic theory of gases is that it assumes that gas particles have no volume and do not interact with each other. In reality, gas particles do have a finite volume and do interact with each other, which can affect the overall pressure of the gas. This can lead to discrepancies between the predicted and observed values of pressure.
4. How do scientists address this conceptual problem?
Scientists have developed modifications to the Kinetic theory of gases to account for the volume of gas particles and their interactions. These modifications, such as the van der Waals equation, take into consideration the size and attractive forces between gas particles, resulting in a more accurate prediction of gas pressure.
5. Why is it important to address this conceptual problem?
Addressing this conceptual problem is important because it helps us better understand the behavior of real gases and make more accurate predictions about their properties. It also allows us to apply the Kinetic theory of gases to a wider range of conditions and systems, making it a more versatile and useful scientific model.
14K
