The Twin Paradox: Triplets Edition
In summary, Charles has a paradoxical experience in which he simultaneously observes his brother Adam and his brother Bob travel away in rocketships and return a year later. Adam and Bob are the same age, but Charles perceives Adam to be older because he is in a reference frame in which time dilation has already taken place.
  • #71
greswd said:
The same amount of aging still applies, if it actually does apply.
was kinda just poking fun at the triplets thing.
  • #72
greswd said:
@ghwellsjr so are you saying that UNSW got it wrong?
Yes, that's what I said, wrong and ridiculous. Don't forget the ridiculous part.
I said their first diagram is close to being right but their second diagram is wrong.
If they had used their second diagram to show just the messages coming from Joe to Jane they would have made a diagram that was more like the one DrGreg made in post #39. Note that he is only showing the messages going from the inertial twin to the traveling twin. That part of the diagram, as I already stated, is fairly good.
But the part that is completely wrong is where they also try to show the messages going from Jane to Joe. If you look at their first diagram, you can see that Joe receives these messages at two different rates. The first three messages take over two years each for him to receive, then in his last year he receives all the rest of them. They show this pretty close to being right and it's important that a diagram show that the inertial twin receives half of the messages at a slow rate and half of the messages at a fast rate and it's important to show that the time interval over which he receives those message is not evenly spaced. He spends way more of his time receiving the low rate messages and only a short time near the end receiving the high rate messages.
It's also important that a diagram show that the traveling twin spends exactly half her time receiving the low rate messages during the outbound portion of her trip and the other half of her time receiving the high rate messages during the inbound portion of her trip. They do a good job of showing this aspect in both diagrams.
However, if you look at their second diagram, you see that Joe does not receive any messages until half way through the diagram at which point he receives all the messages from Jane equally spaced in time. It's the correct spacing in time for the last messages but not for the first three. It's faster than it should be. This is wrong and it's a ridiculous concept to try to show on a combined diagram like this. In fact, I have no idea how to correctly show Joe receiving the messages from Jane at the correct rates and to show the transmission of the signals traveling at c between the two twins. I'm not saying it can't be done, just that I don't know how to do it.
And again, I ask you, why do you feel compelled to combine portions of two perfectly good Inertial Reference Frames into one ridiculous monstrosity? Why not just show everything in each one of the Inertial Reference Frames like I did in post #67?
  • #73
Just an attempt to visualize it from the space twin's perspective. Guess you could take it up with them Aussie bastards.
  • #74
What more can the space twin visualize beyond what any other IRF already tells us?
  • #75
He can visualize that "ridiculous" diagram. Doesn't that explain the time gap objection, and also the visual description that you gave earlier on?
Another interesting fact is that if your three diagrams are transformed using Galilean methods, they produce something that looks somewhat similar to the "ridiculous" diagram.
  • #76
Yes, it does explain the visual description that I gave earlier on but it's exactly the same visual description. I asked you "what more can the space twin visualize".
(Keep in mind, I only applied the term "ridiculous" to the part of the second diagram that is supposed to illustrate what Joe visualizes. I said they did a fairly good job of showing what Jane visualizes. With that in mind, let's continue.)
Look at the diagram from the website:
Look at the diagram on the left. You will see that Jane only sees one message from Joe during the outbound leg of her trip shortly after her second anniversary. Then during the inbound leg, she sees the remaining seven messages equally spaced in time.
Now because the webpage does not show you complete IRF's I want to take you to my diagrams in post #67. The first one is virtually identical to theirs that we just looked at. But now look at my second diagram. During the outbound leg, Jane sees one message from Joe slightly after her second anniversary and then all the rest of them equally spaced during the return leg--exactly like in the first IRF. Same for the third diagram. And notice that none of these diagrams have any time gaps in them.
So now we get to the webpage's second diagram. They say in the text that this is the combination of two IRF's, the two that I show completely that we just considered. Now they chop up those two IRF's and combine them on one diagram and in the course of doing that, they introduce a time gap which they duly explain. But note that this time gap is not anything that Jane can see or visualize. I'm just asking the question, why create the problem in the first place?
It makes as much sense to me as if I took my first diagram and cut it in half horizontally at the turn-around point and then rotated each half so that Jane's path was in a straight vertical line. Then I would have introduced a huge triangular shaped gap which I would need to explain and if I succeeded in doing that, do I deserve extra credit? Does it have any bearing on what Jane visualizes? If you think so, please tell me what it is.
Are you interested in continuing the analysis to include the other triplet? If so, I need you to drop this issue of the combined IRF's. Are you willing to do that?
  • #77
I think the time gap is something that Jane can visualize. And since it matches your visual description, it does have bearing on what she sees. For instance, if Jane backtracks she can find out that some photons popped out from nowhere.
  • #78
Which is a rather strong indication that something is terribly wrong with the proposed "perspective".
  • #79
I can certainly see why you believe this based on your third graph from post #30 and #37 buy you are the only one that believes this. You point me to a link in post #66 that you claim supports your graph but if you read the text, you will see that they go to great lengths to show that the Doppler explanation is correct and any idea that Jane sees anything differently because of an analysis based on jumping between her two inertial frames is wrong. Did you carefully read the text with regard to what Jane sees and experiences and concludes?
Furthermore, if you want to hang on to your chopped up graph for Adam and Charles, what are you going to do for a graph that also includes Bob?
  • #80
Why is it wrong? Its a time gap after all. I pulled that diagram from UNSW.
There's nothing wrong with your Doppler explanation.
But I can't find the part where they say that any idea that Jane sees anything differently because of an analysis based on jumping between her two inertial frames is wrong (what a mouthful :cool:) , could you highlight it?
  • #81
What I'm trying to say is that they don't support your notion of a time gap in their text. They consistently are showing that you can get into trouble by trying to marry two IRF's together. You have to understand when they say Jane is in an inertial frame they mean she is at rest in an inertial frame. They don't mean that she is not also in one inertial frame during her entire trip. She's in every IRF, including the one in which Joe is at rest as they show in their first diagram. Here are two quotes:
The naive interpretation--the reason why the situation is called a paradox--is to assume that the situation is competely symmetrical. If that were the case, Jane's diagram would simply be a mirror image of Joe's. But Special Relativity applies only to the relations between inertial frames of reference. In this regard, the situations of the twins are definitely not symmetrical. Joe is [at rest] in one inertial frame throughout. (We discuss the partial symmetry below.)
In these diagrams, we have resolved the paradox by pointing out that the problem is not symmetrical: Jane actually has two different inertial frames of reference [in which she is at rest], the outgoing voyage and the return. Two different clock synchronisation events are required, and the easist examples of these are at their separation (for the outward journey) and their reunion (for the return).
So they are affirming that we could analyze Jane's experience from any IRF.
Now I have to ask you where they even mention anything about a time gap?
  • #82
Hmm..I don't think they're showing that because they erm...married two IRF's together?
They didn't use that specific term, but I think the diagram definitely shows that.
  • #83
They go to great lengths to show that what Jane actually sees as indicated by the marriage of her two rest IRF's is exactly what she sees as indicated by Joe's rest IRF. But you don't agree with that. You claim that she can see a time gap. That's the problem. And you haven't given any indication of what she is seeing differently in her two rest IRF's compared to Joe's IRF.
I guess I should ask you this question: Can Joe see the time gap that you claim that Jane can see?
  • #84
They have shown that what Jane sees tallies with Joe (in terms of signals received). I do agree with that, if there is a time gap it doesn't mean I disagree.
On a side note, I don't think they have strongly asserted that any idea that Jane sees things differently based on the "marriage" is wrong. If they did they probably wouldn't have drawn the 2nd diagram in the first place.
You have also enquired about Jane being able to see anything beyond or differently than Joe's IRF, and I believe the time gap is that difference.
Other than that, the two diagrams can be considered different sides of the same events (sending signals to one another), and as mentioned above, they should tally.
The time gap is quite clearly illustrated in their diagram.
Joe doesn't notice the time gap because he is always in an IRF and from his point view Jane just ages slower due to time dilation. There is a time gap for Jane, because as mentioned in the passage, when she undergoes infinite acceleration, or switches frames:
The causes of this asymmetry are the fact that Jane reverses direction and Joe does not, and the finite time that light takes to transmit this information to Joe means that Joe doesn't get the news immediately. Jane leaves one inertial frame and joins another, and she has the effect of that change immediately. Joe, on the other hand, doesn't notice the effects of Jane being in a different inertial frame until much later because she is a long way away from him when it happens. The asymmetry is as simple as that.
  • #85
OK, good, we're making progress because back in post #23 when I presented exactly the same Doppler explanation that you just quoted from the webpage at the end of your previous post, you disagreed and thought I was brilliantly and cleverly making an incorrect argument.
Yes, I agreed with that over and over again. Their two diagrams agree with what Jane sees and they agree with what Jane sees in all three of the "unmarried" IRF's that I drew in post #67.
Only if Jane looks at the "married" diagram will she can see the time gap in the diagram. If Joe looks at the "married" diagram, then he can see the time gap in the diagram. The time gap exists in that "married" diagram, not in the first diagram, and not in the three IRF diagrams that I drew. Nobody ever sees any time gaps in any IRF diagram. It's only when you take one part of one IRF diagram and marry it to another part of another IRF diagram that you have to be concerned about a time gap.
They only tally for Jane. They don't tally for Joe. I explained this over and over again. Here, let's look at their two diagrams again (or you can look at their animation):
Focus on the diagonal lines going upwards to the left like this \. Do you see how in the first diagram, Joe receives the first three spaced far apart and the last three spaced much closer together? Do you see how in the second "married" diagram, Joe receives all six with exactly the same spacing? Both diagrams can't be right. The second "married" diagram does not tally for Joe and that is why I'm trying to get you to forget about "married" diagrams. They can only work in limited situations. Unmarried IRF diagrams work in all situations.
Yes, and only in their second diagram. Jane won't actually see any time gap with her eyes looking at her own clocks or looking into space at any remote clocks. Just because someone draws a diagram of an IRF like the first one or a "married" diagram like the second one will have no bearing on what she actually sees.
Joe doesn't notice a time gap for the same reason that Jane doesn't notice a time gap. They can only notice a time gap if they take two legitimately drawn IRF diagrams in which no time gap appears and chop them up and glue them together.
Furthermore, it's incorrect to imply that Joe is always in an IRF and Jane is not, contrary to what your website implies. Joe is at rest in what we euphemistically call "Joe's IRF" and Jane is moving in that same IRF. Since he is at rest in that IRF, he and his clock tick at the same rate as the coordinate time of the IRF but because Jane is moving, she and her clock are time dilated meaning that one year according to her clock takes longer than one year of coordinate time. Please look back at the first IRF diagram in post #67 to see how this is indicated in Joe's rest IRF.
But in either of Jane's two rest IRF's, Joe is not at rest and so he and his clock are time dilated in the same way that Jane's was in his rest IRF. Time dilation is no more observable by the twins than is a time gap. These are only evident when you assign an IRF to a scenario and describe what happens to clocks in relation to the coordinate time of the IRF. No observer in a scenario is ever aware of or can have any knowledge of the IRF that we arbitrarily select to describe that scenario. Think about it--I drew three IRF diagrams that all have different time dilations for the two twins, each one being just as legitimate as the others, none of them being preferred, not even an observer's rest IRF, so how could any observer determine which time dilation was "in force"?
Again, this euphemistic terminology only means that she does not remain at rest in any IRF because she is not inertial. But it doesn't mean that we must analyze what happens to Jane or Joe or what each one can see by using only their rest frames. We can use any IRF we want, even one in which none of them is ever at rest. No IRF is preferred, not even an observer's rest IRF.
This quote is not an explanation of time dilation or of at time gap. As I said before, it is a description of the Doppler analysis that I presented to you back in post #23 and which you disagreed with in post #24 so I'm glad you are now firmly in agreement with the Doppler analysis.
I know this has been a long post but the crux of the issue is that you asked about a triplet scenario which I want to continue explaining but I cannot do it unless you are willing to accept that any single IRF is legitimate and adequate to explain everything and there is never a need to combine portions of two or more IRF's. If we can continue without regard to "married" IRF's and I can explain the triplet scenario in the same way that I explain the twin scenario, then maybe you can try to see how you would marry two or more IRF's to explain the triplet scenario.
Are you willing to concede that time dilation and time gaps appear only in diagrams and are not observable by any of the observers in any scenario?
  • #86
It is wrong precisely because it introduces time gaps and it has photons popping out from nowhere. So far, no one has been able to write the laws of physics in a way that is compatible with it. If you can figure out a way then you should publish it.
  • #87
ghwellsjr said:
OK, good, we're making progress because back in post #23 -- you disagreed and thought I was brilliantly and cleverly making an incorrect argument.
Did I? I didn't say you were incorrect, what I meant was the explanation was smooth and slick (as snake oil, nah just kidding :smile:) before careful consideration.
Hmm, I thought you brought up that point in the first place?
ghwellsjr said:
... if you read the text, you will see that they go to great lengths to show that the Doppler explanation is correct and any idea that Jane sees anything differently because of an analysis based on jumping between her two inertial frames is wrong.
The lack of automatic "quoteception" is making discussion a little long winded. Perhaps you could ask the IT guys to put it in?
I believe that's an error on their part. The world line of a photon "fired" by Jane is not continuous after she switches frames.
Let's say Jane keeps time and she knows the relative velocity between her and Joe, thus she knows the distance between them.
Based on the Doppler analysis, Jane sees Joe's signals as pop-ups on her computer screen, telling her how old Joe is and all the cool stuff he did on his birthday like getting wasted.
Considering everything from her frame, be it inertial or not, and knowing that Joe's signals always approach at the speed of light, Jane can thereby conclude that she received signals that contradict with Joe's known positions. Sort of figuring out there's a time gap.
There isn't any time dilation "in force", what I meant was due to John always being in a single inertial frame he did not notice any time gap.
Well, I still consider it an explanation of a time gap that is also in line with the Doppler analysis. But since the passage has been ambiguous so be it.
Now you sound quite forceful but at least we can iron out all the confusion.
If you've read through and don't have anything to add then we can proceed and all this time gap stuff won't form part of the discussion. :wink:
  • #88
Yeah that was my initial argument. lol
But I do remember John Baez using it.
  • #89
Can we use a GR explanation instead of a time-gap?
  • #90
You don't need GR unless there is significant gravitation involved, which is traditionally not considered part of the twins scnario.
All you need is to make sure that you always use legitimate coordinate systems.
  • #91
It's my understanding that the standard GR resolution also gives a time gap, and it is the SAME time gap that is given by gravitation-free (SR) analysis that uses the momentary co-moving inertial reference frames. See, for example, the Wikipedia page on the Twin Paradox, and in particular, their section on the traveler's perspective.
  • #92
Except that it's not the time gap that you spoke of earlier due to Jane turning around. This "time gap" is present all the time prior to her turning around and is equally observable by Joe as it is by Jane. But let's pursue this and see where it leads us. However, I want to go back to the scenario involving Adam and Charles because it will be easier to illustrate what I want to show you. After that I will pick up with Joe and Jane.
If you look back at post #65 at the top of page 5 you will see the third diagram showing Adam, in black, traveling at 0.6c away from Charles in blue for 12 months and then he turns around and returns in another 12 months to find that Charles has aged by 30 months. Please reread that post for background. I have redrawn the third diagram here with the axes in the more normal configuration for spacetime diagrams. They are not so wide this way. Note the monthly yellow signals sent by Charles and the monthly black signals sent by Adam:
Now if we focus on how Charles would actually measure the position of Adam as a function of time (as opposed to simply calculating his position based on his speed and the elapsed time), he would make use of the radar method. This works as follows. At some point in time, he sends a signal to Adam with the time the signal was sent. When Adam gets the signal, he sends a signal back, including the original time the signal was sent and the time on his clock when he sent the response. When Charles receives this signal, he takes the difference between the received time and the sent time and divides that by two and interprets that as a distance (because we are using c=1) and applies it to the midpoint (or the average) between the two times.
So let's see how that works on the diagram. At the first dot after Adam's departure, Charles sends a signal indicated by the yellow line which Adam receives at his clock time of 2. He sends the signal back to Charles who gets it at his time of 4. So Charles calculates (4-1)/2 = 1.5 light-months and applies that distance to the average of 1 and 4 which is 2.5 years. So we can see that at 2.5 years into the trip, Adam has traveled a distance of 1.5 light-months. (We can also verify that Adam's speed is 1.5/2.5 = 0.6c.) The "time gap" you spoke of is that Adam says that the time was 2 months when he received the signal from Charles and when he was 1.5 light-months away, not the 2.5 months that Charles calculates.
You can repeat this process for any point along the way of Charles's time line. It will correctly indicate the position of Adam, including the turn-around point and the trip back, according to Charles's IRF. I have made a list of all the points along Charles's time line that show signals going from Charles and with a response back from Adam. Each line shows a distance that Charles measures at the time it is applied:
0.00 @ 0.00
1.50 @ 2.50
3.00 @ 5.00
4.50 @ 7.50
6.00 @ 10.00
7.50 @ 12.50
9.00 @ 15.00
8.25 @ 16.25
7.50 @ 17.50
6.75 @ 18.75
6.00 @ 20.00
5.25 @ 21.25
4.50 @ 22.50
3.75 @ 23.75
3.00 @ 25.00
2.25 @ 26.25
1.50 @ 27.50
0.75 @ 28.75
0.00 @ 30.00
And you can repeat this process for Adam sending a similar signal to Charles and getting a response back from Charles. The situation between them is symmetrical, at least for the first four measurements (counting the one at zero) and they both see the other one as having a "time gap". However, the above diagram does not support Adam's measurements because he is not at rest in it. For that, we need to transform all the events in IRF displayed in the above diagram to an IRF moving at 0.6c to show Adam at rest. Here is the diagram depicting Adam's IRF for the outbound portion of his trip:
Notice that it correctly supports his first four measurements of the distance that Charles is moving away from him:
0.00 @ 0.00
1.50 @ 2.50
3.00 @ 5.00
4.50 @ 7.50
Adam receives the response back from Charles for this last measurement at the point he turns around so his measurement for the next one doesn't comport with the diagram.
So let's go to the IRF in which he is at rest for the return part of the trip to see how things work out there:
If we pick up the measurement he makes when he sends the signal at his turnaround point, we get the following list of distances and times for the last part of his trip. Please note that we are using his Proper Times signified by the black dots and not the Coordinate Time of the diagram. They go from 12 months to 24 months while he is at rest in this IRF. Here is the list of distance as a function of time that Adam measures for Charles at the end of his trip:
4.50 @ 16.50
3.75 @ 17.75
3.00 @ 19.00
2.25 @ 20.25
1.50 @ 21.50
0.75 @ 22.75
0.00 @ 24.00
Now if you look at what Adam measures for any of the times where a signal is sent while he is at rest in his first IRF and received from Charles while he is at rest in his second IRF we see that he always measures a distance of 4.50 light-months. It doesn't matter which one of the above three diagrams you use to trace out the signals, they all indicate the same measurement of distance but none of them support that distance in the diagrams. Since I am limited to three diagrams per post I will make a new diagram on the next post to correctly show this.
  • #93
Here is the complete list of distances as a function of time that apply for the traveling twin measuring the distance to the home twin:
0.00 @ 0.00
1.50 @ 2.50
3.00 @ 5.00
4.50 @ 7.50
4.50 @ 8.50
4.50 @ 9.50
4.50 @ 10.50
4.50 @ 11.50
4.50 @ 12.50
4.50 @ 13.50
4.50 @ 14.50
4.50 @ 15.50
4.50 @ 16.50
3.75 @ 17.75
3.00 @ 19.00
2.25 @ 20.25
1.50 @ 21.50
0.75 @ 22.75
0.00 @ 24.00
Here is the diagram that correctly shows the measurements that Adam makes of Charles's distance and in which Adam is always at rest. Note that this is for a non-inertial reference frame but it does correctly show the propagation of all the signals (something which I had previously claimed would be impossible, such as in post #67):
Now this is a very satisfying composite diagram that takes portions from the two IRF's in which Adam is at rest and then fills in the details that covers the "time gap" that is apparent in other "marriages" of the two IRF's but without any time gap. Everything is as smooth as it is in any IRF. I like it, I hope you do too.
It might be helpful to understand how I arrived at this type of diagram. I was trying to see how to combine two "married" IRF's for a different scenario. Here is the first of those two diagrams:
Note that the above diagram showing the signals going from the home twin to the traveling twin is similar to the one that Dr Greg provided in post #39 of this thread.
And here is the other one that shows the signals going from the traveling twin to the home twin:
I printed both these diagrams out and laid the printouts one on top of the other and held them up to the light so I could see through both of them. I aligned the rest positions of the traveling twin and then marked the intersections of the blue and black signals that matched the "path" of the home twin on a normal IRF diagram. I was surprised to see that they formed a straight line between the last reasonable point on the first diagram with the first reasonable point on the second diagram. Here is the composite diagram:
I then took your suggestion for the traveling twin to keep track of the positions of the home twin as a function of time and rediscovered this type of composite non-inertial reference frame based on radar measurements of distance.
Finally I want to show you the similar non-inertial diagram for Joe and Jane:
Does this satisfy your desire for a diagram showing the traveling twin at rest? It does for me because it also maintains the correct depiction of the signals traveling between the twins.
  • #94
As usual, I was busy with work, hence I've taken a long time to reply. Sorry bout that.
Anyway, what software did you use to draw those diagrams? Also, I think it would be better if you displayed the full images in your post. I'm used to viewing time as the horizontal axis too. Yeah, the high school method.
http://img600.imageshack.us/img600/6065/triplets10.png
Thanks for taking the time to come up with this creative and somewhat bizarre diagram. I admit that I've never seen something like that before.
Firstly, for some duration of time Jane is an inertial frame moving away from John. (or Adam-Charles for that matter)
In that inertial frame, which occupies half of the above diagram, the closely spaced photon world lines do not exist. So marrying the frames would look like the original time-gap diagram.
What you've done is to try to make the world lines continuous, I do understand how your diagram ended up like that.
Secondly, in the original scenario John and Jane are never in the same frame, but in this case they are for some duration. I don't think that's what I meant when I spoke of a time-gap.
Using my suggested method for Jane to figure out John's position, it can't produce your diagram.
Your method works fine, initially you posted (4+7=) 11 sets of data. But I'm not sure how you managed to produce the other 8 sets.
Lastly, if John and Jane are in the same frame, why is John sending out pulses at a much higher frequency?
I also found this on Wikibooks, which clearly talks about a time gap. (not written by me LOL :rolleyes:)
_____________________________________________________________________________
A bit of history:
By the time I read your Doppler explanation in this thread, it was the 4th time I had come across this.
The first was in an online exercise. It said that Jane starts receiving signals at a higher frequency when she turns around.
I thought to myself this, "When I left, my twin was the same age. When I returned, he was older. What happened in between?"
So I drew a diagram and arrived at the time-gap explanation.
The second and third times were identical, one was from some guy on another forum, one was from Paul Hewitt's Conceptual Physics.
Anyway, some people have already acknowledged this time-gap explanation too.
  • #95
It is a bizarre diagram because it is a bizarre thing to do. Trying to draw the traveling twin's perspective is itself bizarre, the diagram is a correct representation of that bizarrness.
That is correct. There is a period of time in which radar pulses from the traveler are sent before the turnaround and received after the turnaround. All of those radar echoes take the same amount of time, as measured by the traveller's clock, so the distance is constant during that time.
Because the frame is non-inertial. Wierd things like that happen in non-inertial frames. You can consider it to be gravitational blueshift, as Einstein would.
  • #96
Well, bizarre is it then.
I don't know how both of you arrived at that conclusion, but I'm afraid to ask.
Would he? Oh well, I haven't learned GR yet.
  • #97
It is actually pretty easy. Just start with the diagram for the inertial frame for the stay at home twin. Then you just draw radar pulses that go from the traveling twin, to the inertial twin, and back (here I have drawn a red, purple, and green one). Then count how many of the black dots there are from sending out the pulse to getting the echo back (9 months in each case). The radar distance is just 1/2 of the round trip time (4.5 light-months).
  • #98
Actually, you can start with any inertial frame and do the same thing. Not only that, but if you are careful to apply the distance at the midpoint of the dots, you can construct the entire rest frame for the non-inertial twin.
Furthermore, you can do the same thing for the inertial twin. You can start with any other inertial frame and construct the stay at home twin's rest frame. Not only that, but you can start with the traveling twin's non-inertial rest frame and reconstruct the stay at home twin's rest frame.
  • #99
Interesting, I'll experiment with that. What software do you guys use?
Also, I find it confusing because some have already acknowledged the time-gap explanation.
  • #100
I use Mathematica for calculations and plots directly based on calculations, but I typically use PowerPoint or Paint for drawing.
"Some" will also tell you that the world is flat.
  • #101
Cool, time for me to get my free copy of Mathematica.
Haha, no one will ever tell me that the world is flat.
Cranks have progressed to higher stuff these days. There's this guy who claims to be the Flat Earth Society president but he's most probably trolling.
However, I have met some bible thumpers who told me that evolution cannot be true because the world is only 6000 years old.
  • #102
Can't say about that specific guy, but the Flat Earth Society actually exists and has for decades. Here's their website:
http://theflatEarth'society.org/cms/
  • #103
I wrote my own program using a general purpose language called LabVIEW. I did this last November after you posted some graphs that I thought were quite interesting, not the normal kind of spacetime diagram, so I thank you for providing me the inspiration and motivation to do it.
I don't know what you mean by this. I thought I was displaying the full images.
Me too, but showing them rotated does have the advantage that they don't get too wide which otherwise makes the whole page wide and makes reading other posts difficult if you don't have a wide monitor.
You're welcome. I have never seen one that looks just like mine before either.
The time-gap is an artifact caused by insisting the Jane is always at rest in an Inertial Reference Frame and that after she accelerates, she has to jump to a new IRF. If you will simply realize that both Jane and Joe (not John) are always in all IRF's and use just one IRF for the whole scenario, then there won't be any time-gaps. But even if you want to use the very common time-gap explanation, the time-gap is never observable by Jane or Jim. It's merely a calculation based on an arbitrary definition of an IRF.
I'm glad you understand how I produced the diagram.
No, but it won't produce any diagram you provided either. My diagram is based on actual measurements that Jane makes, not on speculation about what Jim must be doing. If you can produce a diagram according to your suggested method, I'd like to see it. The diagram I produced was inspired by your request and I appreciate your motivating and inspiring me to produce it.
I'm lost here, can you point me to the post number where I did this?
No matter what inertial or non-inertial frame or even if you don't want to analyze this scenario according to a frame, Jane will see Jim sending out pulses out a higher frequency during the last half of her trip and a lower frequency during the first half of her trip. If your diagram doesn't show that, then it is either wrong or incomplete.
Furthermore, Jim will see Jane sending out pulses at that same higher frequency during a shorter portion of the end of the scenario and at that same lower frequency during a longer portion of the beginning of the scenario. All my diagrams show exactly the same thing in this regard. If you produce a diagram that doesn't show this, then it is either wrong or incomplete.
Yes, they do talk about a time gap, but it's not clearly talked about. Maybe you can explain what they mean when they talk about the 4.5 secs and 8 secs interval. Where did those numbers come from, what do they mean, and why is this so different from the other explanations of the time gap?
A bit of history:
Yes, in an attempt to provide the traveling twin with a rest frame, the time-gap explanation (or objection) is very popular. However, now that I know how to provide the traveling twin with a rest frame that doesn't have a time-gap, I plan to show this in the future when the subject comes up again.
  • #104
But who should I follow? :confused: Everyone online has got about equal standing.
Last time you were a golden boy, but now you've gone green, so I guess that ups your standing. Anyway, congrats on being made a mentor.
EDIT: Your diagram looks very similar to ghwellsjr's, as though they came from the same program. Coincidence?
You're welcome, though I'm far from inspiring. :smile:
LabVIEW is mainly for professionals right? I'm curious, are you guys currently students, educators etc?
Anyway, I'm still busy so it'll be a while before I reply.
  • #105
I decided who I should follow by examining how effective they were in convincing others and how I could understand their arguments. Until you understand the subject matter, you cannot tell who to believe. That's why I avoid discussions about gravity and GR. I'm just glad that you don't have to understand GR in order to understand SR. SR is simple, GR is complex. SR only requires a little bit of high school algebra. GR requires an understanding of tensors which stops me right in my tracks. I'm content to help others with SR. I'll leave the GR tutoring to others.
DaleSpam just copied my diagram, opened it in Paint, added some extra lines of different colors, and then uploaded them to his post. He didn't start from scratch.
If you want to buy it, you'd probably only do that as a professional since it's quite expensive. However, you can try it for awhile if you are interested. I'm a professional engineer. Didn't learn much as a student. Learned most of what I know about SR right here on this forum (mainly from DaleSpam and JesseM years ago) by reading the long threads before ever even joining.
