Electron Affinity, Type of energy released?
In summary, the process of oxygen gaining an electron to become an anion results in the release of energy, primarily in the form of heat and light. The specifics of this process vary depending on the reaction, but it is a common occurrence in chemistry. This energy release can be explained by the exchange of potential and kinetic energy between the oxygen and electron, with the emission of photons as the electron accelerates. This process is similar to the Rydberg formula for hydrogen, but with different energy levels. Additionally, the transfer of kinetic energy to the oxygen is usually very small and can be ignored.
mishima
561
34
This might be a dumb question, but for instance when oxygen gains an electron to become an anion, energy is released equal to its electron affinity. What exactly is the form of this energy? Is there a photon of a certain wavelength emitted? Does the anion slow/cool down because of the small increase in mass? Thanks for any insight.
Chemistry news on Phys.org
It's a good question - you should be interested in the energy transformations.
Ultimately the energy is released as heat (and light) - hence the process is exothermal.
The details of the process depends on the specific reaction.
In chemistry you are not normally worried about these details.
Related concept: "free energy of binding".
Simplistically: you could imagine it as the O and e- are initially at rest close to each other.
Since conditions favor forming an anion, they initially accelerate towards each other - exchanging EM-PE for KE until the balance of PE and KE matches an available stationary state.
While the e- is accelerating, it radiates.
The end result is some, usually IR, photons from the radiation and an anion with some additional, random, KE.
That makes sense. I wasn't sure if there was something like the Rydberg formula for hydrogen that applies to oxygen.
There is - with different energy levels.
You can think of it as the extra electron is initially in a far-away orbital and decays into a lower orbital.
At each step it releases a photon - depending on the transitions.
What I did before was the quasi-classical description of the same thing - electron radiates when it is not in a stationary state.
Note: The KE transferred to the oxygen is usually very very small since the mass of O is much bigger than the mass of a single e- so we would normally ignore it. I just thought it would be nice to have a tie into something less mysterious to you :)
You can also imagine shooting (low energy) electrons at oxygen - in which case you'll get many electrons in excited states of the anion due to recoil effects from the electrons initial KE.
Indeed do many things come to pass.
I am happy to answer your question about electron affinity and the type of energy released. Electron affinity refers to the amount of energy released when an atom or molecule gains an electron to form a negative ion (anion). This energy is typically in the form of heat, as it is the result of the attraction between the incoming electron and the positively charged nucleus of the atom. However, the exact form of this energy can vary depending on the specific reaction and conditions.
In some cases, the energy released may also take the form of light, such as when an electron falls to a lower energy level and emits a photon. This is known as fluorescence or phosphorescence, and the wavelength of the emitted light can provide valuable information about the electronic structure of the atom or molecule. However, this is not always the case and the energy released may not always be in the form of light.
As for your question about the effect on the anion's speed or temperature, the small increase in mass from gaining an electron is unlikely to have a significant impact on its overall motion or temperature. The energy released from electron affinity is relatively small compared to other forms of energy, such as thermal energy, and is typically absorbed quickly by the surrounding environment.
I hope this helps to clarify the form of energy released during electron affinity and its potential effects. Keep asking questions and exploring the fascinating world of science!
What is electron affinity?
Electron affinity is a measure of the energy released or absorbed when an atom or molecule gains an electron to form a negative ion.
How is electron affinity measured?
Electron affinity is measured in units of energy, typically kilojoules per mole (kJ/mol) or electron volts (eV). It is measured by experimentally determining the energy change when an atom or molecule gains an electron.
What determines the electron affinity of an atom or molecule?
The electron affinity of an atom or molecule is determined by its atomic structure and the number of electrons in its outermost energy level. Generally, atoms with a high nuclear charge and low atomic radius have a higher electron affinity.
What type of energy is released when an atom or molecule gains an electron?
The type of energy released when an atom or molecule gains an electron is in the form of electromagnetic radiation, specifically in the form of photons. This energy is released as the electron moves to a lower energy level within the atom or molecule.
Can the electron affinity of an atom or molecule be negative?
Yes, the electron affinity of an atom or molecule can be negative. This indicates that energy is required for the atom or molecule to gain an electron, rather than being released. This is typically seen in atoms or molecules with a full outer energy level, as they are more stable and less likely to gain an additional electron.
  • Atomic and Condensed Matter
  • Electrical Engineering
