New Reply
How do you join metal and metal (steel to aluminum)
Share Thread Thread Tools
Aug23-12, 01:56 PM   #1
hi there, i want to connect two pieces of metal together one is i think a piece of steel capable of being attracted by a magnet and the other piece an aluminum piece, or maybe another metal, but not magnetic at all anyway they're both solid pieces and need to be joined. is brazing or using silver solder a good option here? what am i gonna need to buy?
thank you
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> NASA: Austin, calling Austin. 3-D pizzas to go
>> Research suggests modular design competence can benefit new product development
>> Army ground combat systems adopts tool for choosing future warfighting vehicles
Aug23-12, 02:11 PM   #2
Epoxy resin
Aug23-12, 07:52 PM   #3
Mentor
Quote by stinkingbowel View Post
thank you
Can you say more about the application? Obviously you need to worry about corrosion with those two different metals. Looking around the web, it looks like an option is to use galvanized rivets or bolts and a spacer between the two pieces...
Aug23-12, 10:07 PM   #4
no it has to be welded
it's a piece that i am trying to attach to the bar clamp. let me see what i can do as far as pictures.
Aug23-12, 10:14 PM   #5
Aug23-12, 10:20 PM   #6
now i want a different grip for it like this, or a different caul
Aug24-12, 10:50 AM   #7
Make it out of aluminum (or steel, whichever the main clamp is made of) and TIG it
Aug24-12, 01:22 PM   #8
Quote by Travis_King View Post
well i don't have a welder, dude. i can buy a Brazing Kit. $30.
i wanted to know if that could do.
Aug24-12, 01:45 PM   #9
Brazing steel is pretty easy. Brazing aluminum is a mysterious art for someone who has never done it. But if you have a desire to learn, you can get good information from your welding supplier, or search the web. The trick is to match the right materials, rod material, and temperatures. You may also need to heat treat afterwards.
But for something like this, it is hardly worth the effort unless you are looking for a learning exercise that is likely to include several iterations, especially since you don't know which alloy you are dealing with.
I would use epoxy backed up with mechanical fasteners.
Edit: you can weld aluminum to steel, but that is far beyond the scope of your project. I've seen it done on rare occasions via friction inertial welding.
Aug24-12, 05:25 PM   #10
Quote by Pkruse View Post
right
like i don't have a garage or space to start welding lol
and again i am guessing it's aluminum. it might be a different metal.
Aug24-12, 05:39 PM   #11
they're actually zinc. i was way off-base.
so zinc to steel? weldable? can they be brazed possibly? what do you think?
Aug24-12, 05:55 PM   #12
The boiling point of zinc is below steel's melting point. Are you sure they are fully zinc, or zinc-coated? Also Zinc contains volatiles that are released when burned and are pretty hazardous. You aren't going to get a good connection between these two materials.
My suggestion (though I know you don't have access to a welder) would be to weld threaded rod onto locations on the clamp, drill holes in the zinc piece, and then bolt.
As Pkruse suggested, epoxy might be your friend for this one. I'd drill some inserts to fit the threaded rod into, epoxy them into place and go from there.
Aug24-12, 11:13 PM   #13
they're actually zinc...
Are you certain? I would bet on them being cast-iron.
I also recommend a bolt-on solution. Without the proper equipment and experience, attempting to weld or braze dissimilar metals is just going to give you headaches.
Aug27-12, 10:45 AM   #14
Quote by pantaz View Post
Literally...
I just wanted to re-stress the point that burning zinc releases toxic fumes.
Aug27-12, 11:44 PM   #15
they're cast and they have different finishes as in they're finished with either brass, pewter dark bronze or satin nickel.
Aug27-12, 11:46 PM   #16
Literally...
so would you still go with epoxy that is a LePage Epoxy Steel as your #1 method?
Aug28-12, 07:50 AM   #17
The epoxy will be more effective if you heavily scuff up the surfaces you want to join. Epoxy also works best with a fairly thick glue line, so I would not clamp them together too tightly. Tape can usually provide enough clamping force.
New Reply
Tags
brazing, soldering, welding
Thread Tools
Similar Threads for: How do you join metal and metal (steel to aluminum)
Thread Forum Replies
Air leak rate through metal-to-metal seal General Engineering 0
Would metal hitting metal or metal hitting glass make more noise? General Discussion 3
Potential energy vs. fermi level in metal-metal junction under applied field Atomic, Solid State, Comp. Physics 0
Why does CO generally not bind to a metal that is not a transition metal? Chemistry 1
Which catalyst is the best for the reaction betweeen Aluminum metal and HCl? Biology, Chemistry & Other Homework 1
