| New Reply |
Question about electric generators |
Share Thread | Thread Tools |
| Jan18-13, 08:20 AM | #18 |
Question about electric generatorshttp://physicsforums.com/showpost.ph...1&postcount=16 It turns out to produce so many complications and inefficiencies that it is just not practical. Things would actually work more efficiently with the current electrical generation methods. Besides an induction alternator has an efficiency of up to 97% and a transformer has an efficiency of >90% so the grid is already very efficient as it is. In conclusion, what you said about using the conventional induction electromagnetic generator to give the electrons a steady nudge is better and more controlled than forcing the charge distributions to change and letting the distribution equalize then repeating the process which is inefficient and produces an output that is unstable and difficult to control. |
| Jan18-13, 09:17 AM | #19 |
What's in a name?
which is the abbreviation for Electro Motive Force", a good name for it which should be thought of backwards: Force that Motivates Electrons (to move). Then one can introduce the concept of potential, absolute and differential, with finger on the table, and from that it follows naturally that work = Force X Distance... Some people need that kind of visual aid in order to gain confidence in the equations. Not lecturing you guys, just i've seen this method help struggling newbies. Hope it helps you help someone. |
| Jan18-13, 09:34 AM | #20 |
It now seems we have 2 threads in one ....
Back to the OP to clarify "Generators in Power Stations" - to be large scale > 100MVA, this is where the issue of a step up transformer is most relevant. The issue of practical energy harvesting from static - is a completely different topic. -- really should not be in the same discussion. |
| Jan19-13, 07:30 AM | #21 |
Alright, my questions have been completely satisfied. Thank you very much for the advice. If ever I have more questions about this, I will post it here or in a different thread.
| Jan21-13, 03:32 PM | #22 |
I am not positive about the origin of the term "emf", but it is not at all a real force. In the early days before Lorentz force was known about, "emf" was coined and it stuck since then although we now know that the force acting on electrons is indeed Lorentz force. Just thought it should be mentioned. BR. Claude |
| Jan21-13, 06:29 PM | #23 |
Thanks Claude
i was never quite sure whether Lorentz included both magnetic and electric fields - so just now i looked at hyperphysics and it appears that it does, just as you said. http://hyperphysics.phy-astr.gsu.edu...ic/magfor.html From a thread earlier this year: http://www.physicsforums.com/showthread.php?t=588037 old jim |
| Jan22-13, 09:40 AM | #24 |
Hi Jim,
I would say that just as "emf" is not an actual force, it is equally true that "mmf" is also not an actual "force". The term "mmf" is "magneto-motive force". As I said, neither is actually a force, but generators, motors, & transformers were examined prior to 1890-91, which is when Lorentz published his force equation. Induction was measured & the terms "emf" & "mmf" were coined. Based on known mAcroscopic laws, it was postulated at the mIcroscopic level, that induction must involve forces acting on charged particles. So the terms were coined. We still use emf & mmf when describing xfmrs, motors, & generators, without a problem since it is understood that the "f"'s in emf/mmf are not true "forces". Anyway, this is an interesting discussion. Thanks Jim, for your contributions. Claude |
| Jan22-13, 10:12 AM | #25 |
Isn't all this a bit 'speculative'?
Magnetic induction is a very good way (tried and tested) to generate electric power at useful AC voltages which can be conveniently transformed up and down, to suit - and at enormous powers. Electric induction can be used to pump charge into a circuit but the system is not "electrostatic" if it is supplying 'current' electricity. The area involved in making what would be, in effect, a massive Whimshurst Machine would be in the order of Football pitch size if you wanted to produce any significant power. Something like the London Eye perhaps? |
| Jan22-13, 01:00 PM | #26 |
Hmmm i always stumble a bit when learning something new. Please forgive.
An electron moving in a magnetic field assumes a curved trajectory, as in a CRT with magnetic yoke, Does not its acceleration away from the straight line result from one term of "Lorentz Force Law" , QV cross B ? How should i conceive of it if not a force? Is Lorentz Force Law misnamed? http://hyperphysics.phy-astr.gsu.edu...magfor.html#c2 not being argumentative here, just i'd like to step up to next level of understanding. Guess i'm stuck in the(18)90's. Been reading Sylvanus P Thompson... old jim |
| Jan22-13, 01:24 PM | #27 |
This happens elsewhere as well. We use the term "centrifugal force". Is it really a true "force". Inside the rotating reference frame it is valid. It's inclusion maintains Newton's laws in that rotating frame. But in an inertial reference frame, if we draw free body diagrams of all forces acting on the body in circular motion, there is no "centrifugal force" at all. It is merely a math construct employed when viewing circular motion while inside the rotating frame of reference. We use the phrase "centrifugal force" knowing how it should be construed. There is no need to acknowledge the nature of said quantity every time it is mentioned, so we don't. Likewise, emf & mmf are understood as being related to volts/turn & ampere-turns. When summing forces acting on charges, we use Lorentz forces due to E & B fields with velocity taken into account. A free body diagram of the forces acting on a charge carrier does not include "emf or mmf", because they are not actually forces. I hope this helped. Best regards. Claude |
| Jan22-13, 02:09 PM | #28 |
Claude - it helped far more than you know.
Thank you. old jim "Science is but language well arranged" - Lavoisier |
| Jan22-13, 03:27 PM | #29 |
Shame about the term 'emf'. It's really hard to think in terms of fields (volts per metre) producing force on a charge when the wires connecting the two terminals of a source of emf are taken round the room and back again. Where's yer volts per meter then? This hypothetical field is shared out all over the geometry of the circuit.
| New Reply |
| Thread Tools | |
Similar Threads for: Question about electric generators
| Thread | Forum | Replies | ||
| Electric Generators | Electrical Engineering | 30 | ||
| Electric Generators | General Physics | 4 | ||
| Electric Generators | Electrical Engineering | 8 | ||
| Electric generators | Classical Physics | 2 | ||
| Question about Electric Generators (and Black emf) | Introductory Physics Homework | 1 | ||
