Gravity as simply being the cumulative effect of atomic particles?
In summary, the conversation discusses the relationship between electromagnetic forces and gravity, and whether gravity can be described as the cumulative effect of all the particles that make up an object. It is stated that while gravity is indeed the sum of the gravitational forces between each individual particle, it is not the same as the electromagnetic force that causes atoms to clump together to form matter. The distinction between the two forces is emphasized, with gravity being dominant on a larger scale and electromagnetism on a smaller scale. It is also noted that gravity does not emerge from electromagnetism, and that it is possible for a neutral object to exert a gravitational force. The conversation also touches on the idea of measuring the gravitational pull of different objects based on their mass, and whether
juniorcarty
If atoms clump together through the interaction of electrons, protons and neurons to form matter, why can't gravity ( of the Earth for example),be simply described as just being the wholesale cumulative effect of all those electrons, protons and neurons of which the mass of the Earth consists, pulling and attracting the the respective electrons, protons etc. of which, for instance, the moon consists?
juniorcarty said:
If atoms clump together through the interaction of electrons, protons and neutrons to form matter, why can't gravity ( of the Earth for example),be simply described as just being the wholesale cumulative effect of all those electrons, protons and neutrons of which the mass of the Earth consists, pulling and attracting the the respective electrons, protons etc. of which, for instance, the moon consists?
In Newtonian physics, the gravitational force between two bodies is indeed the sum of the (individually minuscule) gravitational forces between each and every particle making up the two bodies. We don't calculate the gravitational force that way because it would be intolerably cumbersome in practice, but there's nothing wrong with it in principle. So not only could gravity be that cumulative effect... It is.
But be aware that the force that causes atoms to clump together to form matter is not gravity. It takes a truly enormous number of atoms to generate a significant gravitational force; any chunk of matter less massive than a good-sized asteroid is going to be held together by intermolecular forces generated by electromagnetic interactions between nearby electrons and atomic nuclei. It's really hard to tear a steel sheet apart, and that has nothing to do with gravitational attraction between the atoms in the steel; that's all electromagnetic forces between them.
I am now more confused than I was previously. You recognise that the cumulative effect of a 'truly enormous number of atoms' , can 'generate a significant gravitational force'. ie. the gravitational force of the Earth for instance. 'It is... (gravity)'. However, you go on to state that the 'gravitational force between each and every particle' ie, the subatomic electromagnetic force, 'is not gravity'. This indicates that you hold with the universally accepted model which regards the subatomic electromagnetic force and the force of gravity as being distinctly separate. What confuses me is where the distinction begins?
For instance we know that the Earth initially originated and was formed from particles of dust and gas which clumped together due to the influence of the subatomic electromagnetic forces within the said particles. The first 'attractive' force in the universe was that of electromagnetism. No latter, no matter. At what point or stage in the increasing burgeoning bulk of the fledgling Earth could it legitimately be stated that local matter in space, ( be it either dust particles or asteroids), were alternatively drawn to Earth, not by the influence of the electromagnetic force, but by the force of 'gravity' ? When do we begin to describe the former as being the latter.
It always appears to me that any attempt to explain the force of gravity is always from a top down perspective instead of from the bottom up. I don't see why it would be 'intolerably cumbersome' to simply describe Earth's gravity as being the cumulative wholesale effect and outward extension of the electromagnetic force/attraction as contained within the mass of the planet ? Perhaps in doing so, particle physicists may not be required to spend as much as they do, looking for gravitons?
The point was that these are two distinct forces that act at the same time. One is much stronger than the other, but easy to cancell out, the other is weaker but always attractive.
That's why gravity dominates large-scale attraction, while electromagnetic forces dominate smaller scales(and nuclear forces take over in the >really< small scales).
Once again, electromagnetism does not emerge from gravitation, nor vice versa.
You are trying to assert that gravity is nothing more than the resultant electromagnetic force from all the constituents. This is incorrect on more than one grounds. For example, something can be neutral (no net electrostatic field), and can still assert gravitational field. So already this is something inconsistent here.
Secondly, the repulsive force that is present in electromagnetic interaction is missing in the typical gravitational field that we observe (neglecting exotica in General Relativity and Cosmology).
However, it is certainly true that the sum of all the gravity of these individual particles would be equal to the gravity of the macroscopic object. This, however, is different than equating their electromagnetic property to the gravity of the macroscopic object.
Zz.
juniorcarty said:
The first 'attractive' force in the universe was that of electromagnetism. No latter, no matter. At what point or stage in the increasing burgeoning bulk of the fledgling Earth could it legitimately be stated that local matter in space, ( be it either dust particles or asteroids), were alternatively drawn to Earth, not by the influence of the electromagnetic force, but by the force of 'gravity' ? When do we begin to describe the former as being the latter. QUOTE]
It is the combined mass of a lump of matter, ( the Earth for example), which determines it's gravitational force. The moon, (1/80th mass in comparison), has approx 1/6th gravitational force. The gravitational pull of an asteroid the size of Wales, less again than that of the moon. An asteroid the size of a mountain, less again; though still measureable nonetheless. ( The latter would still be capable of attracting particles of passing dust on to it's surface). If we take this to it's logical conclusion, could we not assume that a lump of matter the size of a football drifting through space, continues to assert a degree of gravitational force, (however small and perhaps no longer measurable), on it's immediate vicinity? How about a molecule of water? We eventually arrive at a piece of matter where the only 'attractive' force is that of electromagnetism. Given that matter would not exist without the electromagnetic force,('no latter, no matter'), we can see that Newtonian gravity is directly correlated with the electromagnetic force.
Not correct.
A neutrino is "matter". It has no electromagnetic interaction whatsoever. That is why it almost never interact with matter. It has an extremely small amount of mass (so very weak gravity), and interacts predominantly via the Weak interactions.
Zz.
So far you're right. Every particle with mass exerts an attractive force on every other particle with mass.
There is still gravity down there. As far as I know, gravity is expected to behave the same way down to the size of nuclei (beyond that realm I don't know anything) but nobody ever bothers to talk about it because the effect is incredibly small in comparison to the electromagnetic forces. It is still there, but the effect is drowned out by EM forces.
Nope. Matter can still exist without EM forces. Maybe it wouldn't clump together in quite the same way, so yes, the two completely separate forces do effect each other indirectly, but there is no (at least on the energy scales that we can observe) fundamental connection between the two forces.
Neutrinos participate only in the weak decay of nuclear particles and have no role to play in the strong force binding nuclei together.However, (and confirming your comments), Fermilab DID confirm in 2006 that neutrinos do indeed have mass. This is significant with regard to the fact that Neutrinos CAN exert gravitational effects. ( and therefore may have some significance in the formation of dark matter.)
But you are neglecting what this contradicts in your assertion that matter must have EM interaction! That's the whole point of us bringing up the neutrinos.
BTW, Fermilab did NOT confirm that neutrinos have mass. The first confirmation came out of detection at Kamiokande in Japan of neutrino oscillation.
Zz.
There is no stage that gravity 'takes over'. Gravity constantly pulled the dust together. It is only once it began to clump in large lumps that the attractive force started to have noticeable effects at a small scale. And the EM force did not bring the dust together, it merely caused it to stick together upon collisions with each other.
And no, the first attractive force in the universe was not the EM force. It was gravitation.
It's not intolerably cumbersome to describe gravitation as an extension of the EM force. It's just plain wrong. The two forces behave very differently when you look at the details.
No, we don't. And your logic doesn't make any sense. If you have less and less gravitational force when the mass of the object is reduced further and further, when do you ever hit zero? Not until you have zero mass. A single particle still has mass and exerts gravitational force on other objects.
If you believe this, then show the math.
1. What is the theory of gravity as simply being the cumulative effect of atomic particles?
The theory proposes that gravity is not a force between masses, but rather a result of the cumulative effect of the individual particles that make up those masses. This means that gravity is a fundamental property of matter, rather than a separate force.
2. How does this theory differ from traditional Newtonian gravity?
Traditional Newtonian gravity states that gravity is a force that acts between two masses. However, the theory of gravity as the cumulative effect of atomic particles suggests that gravity is not a force, but rather a result of the properties of matter itself.
3. What evidence supports this theory of gravity?
One piece of evidence is the fact that gravity is always present and affects all objects, regardless of their mass or distance from each other. This suggests that gravity is a fundamental property of matter, rather than a force between masses.
4. Can this theory of gravity be proven?
As with any scientific theory, it cannot be proven definitively. However, there is a growing body of evidence that supports this theory, and it offers a more unified understanding of gravity and other fundamental forces in the universe.
5. How does this theory impact our understanding of the universe?
This theory challenges our traditional understanding of gravity and opens up new possibilities for understanding the fundamental forces of the universe. It also has implications for areas such as cosmology and quantum mechanics, and may lead to new discoveries and advancements in these fields.
  • Atomic and Condensed Matter
  • Sticky
  • Quantum Physics
