Combined translational and rotational motion of a rigid body
In summary: In the example of the triangular bicycle wheel the direction of the velocity of the center of mass with respect to the road is in the direction that the wheel is rolling. The direction of the velocity of point P with respect to the center of mass is perpendicular to the side of the triangle that P is located on. These two velocities could not possibly be equal.In summary, the velocity of a point P on a rigid body can be calculated by adding the velocity of the center of mass and the velocity of P with respect to the center of mass, but this only works if the body is not rotating and the frame of reference is not rotating or moving with respect to the center of mass. In the general case, the velocity of the
avistein
48
The velocity of any point P of a rigid body in rotation plus translation is [itex]\vec{}v[/itex]p=[itex]\vec{}v[/itex]COM+[itex]\vec{}v[/itex]p,COM.
Now |[itex]\vec{}v[/itex]COM|=v and [itex]\vec{}v[/itex]p,COM =rω .
But v and rω are same thing as v=rω ,so velocity of the particle every time will be √2 v.Then what is the difference between [itex]\vec{}v[/itex]COM and [itex]\vec{}v[/itex]p,COM?
avistein said:
But v and rω are same thing as v=rω ...
You may want to reconsider this statement.
The short answer to your question is that v=rω makes some assumptions about your frame of reference, specifically that it's not rotating and that is isn't moving with respect to the CoM. If the body is moving or the FoR is rotating, you have to adjust accordingly.
The velocity of the center of mass ([itex]\vec{}v[/itex]COM) could be given by v=rω in the case, for instance, of a bicycle wheel rolling along the road. However, in the general case it will be completely independent of the rotation rate of the rigid body.
Suppose, for the sake of argument that we are considering the case of a bicycle wheel so that the velocity of the center of mass with respect to the road is given by rω. It will also be true that the velocity of a point on the treads of tire will have a velocity with respect to the center of mass that is given by rω. Will it be the case that these two velocities will sum to √2 v? Decidedly not. Unless those two velocities are at right angles, their sum could be anywhere between 0 and 2v. Only if the two equal velocities are perpendicular will their sum be √2 v.
The cases where the velocity of a particular point on the treads of a bicycle tire has a velocity equal to √2 v are where that point is level with the hub, either at 90 degrees forward of the contact patch or at 90 degrees back. At the contact patch the two velocities will sum to zero; the contact patch is at rest with respect to the road. At the top, the two velocities will sum to 2v; the top of the tire is moving at twice the speed of the bicycle.
That means as the bicycle wheel is circular so that two velocities are same,right? that is, the r is distance between centre of mass and the Point P and also the radius of the wheel.But if it is of irregular shape,then will →vCOM and →vp,COM be equal? In that case →vCOM will not be rw ?
Take, for example, a triangular bicycle wheel that is rolling on the road without slipping. If you define "r" as the distance from the center of mass to one of the points on the triangle then the velocity of the center of mass with respect to the road will be rω. If you define "r" as the distance from the center of mass to a point P in the middle of one of the sides then the velocity of point P with respect to the center of mass will also be given by rω.
But if you try to argue that the two velocities are equal because they are both given by "rω" then you will have committed two errors:
1. The fallacy of equivocation -- you will have used the expression "rω" in the same context with two different meanings for the letter r.
2. The error of treating a vector as if it were a scalar and ignoring its direction.
Likes 1 person
1. What is combined translational and rotational motion of a rigid body?
Combined translational and rotational motion of a rigid body refers to the movement of an object in which it both translates (moves in a straight line) and rotates at the same time. This type of motion is typically exhibited by objects such as wheels or spheres rolling on a surface.
2. What causes combined translational and rotational motion?
The combined translational and rotational motion of a rigid body is caused by a force applied to one point on the object, causing it to both rotate and translate. This is known as a torque, which is the product of a force and the distance from that force to a pivot point.
3. How is the motion of a rigid body calculated?
The motion of a rigid body can be calculated using the principles of mechanics, specifically Newton's laws of motion and principles of rotational dynamics. These laws and principles can be applied to determine the forces, torques, and resulting motion of a rigid body.
4. What is the difference between translational and rotational motion?
Translational motion refers to the movement of an object from one point to another in a straight line, while rotational motion refers to the movement of an object around a central axis. In combined translational and rotational motion, the object exhibits both types of motion simultaneously.
5. What are some real-life examples of combined translational and rotational motion?
Some common examples of combined translational and rotational motion include rolling objects such as a ball, a wheel, or a rolling pin. Another example is the motion of a spinning top, where it both rotates and translates as it spins. Other examples can be seen in the motion of gears, propellers, or a spinning coin.
  • Mechanics
