Limit of x^x^x as x->0 from right
  • Thread starter emilkh
  • Tags
    Limit
In summary, you solved lim ln x * (x^x) by switching it to lim ln x / (1/x) and taking derivatives. You then found that e0 is not =0, but is actually 1.
emilkh
Any ideas?
lim XXX
x-> 0+
I know how to do x^x:
lim XX = lim ex * ln x = e0 = 0
lim x * ln x = lim ln x / (1/x) = lim (1/x) / (-1/x2) = lim -x = 0
Now x^x is the exponent and x is the base, so do exactly as you just explained.
Could you elaborate more? I alredy tried this method and got stuck with
lim (ln x) * (x^x), i could not solve it
Why are you stuck? You already said you knew what to do with x^x...
lim ln x * (x^x) = lim ln x * lim x ^ x = (- infinity) * 0 = 0 as X -> 0+
So you want to tell me that lim (X^x^x) = lim ex^x *ln x = e^0 = 1?
The limit suppose to be 0, .000001 ^ ( .000001 ^ .000001 ) = very very very small number (checked with calculator)
Be careful; [tex]- \infty \cdot 0[/tex] is indeterminate.
Edit: I see, nevermind.
Well great! This is where I am stuck.
lim ln x * x was solved by switching it to lim ln x / (1/x) and taking derivatives, with lim ln x * x/x it's not going to work
emilkh said:
Any ideas?
lim XXX
x-> 0+
e0 is not =0, but...1..... here is your mistake ,
hence ...limx^x=1 as x tends to 0 from the right
And lim (ln x) * lim x^x = infinity multiplied by 1 and NOT by 0
[edited for content], in my solutions it was 1, but somehow I copied formula wrong and the whole time assumes lim x^x = 0. I spend way too much time studying for finals... got to take break
1. What is the limit of x^x^x as x approaches 0 from the right?
The limit of x^x^x as x approaches 0 from the right is 1. This can be determined by evaluating the limit algebraically or using a graphing calculator.
2. How do you find the limit of x^x^x as x gets closer to 0 from the right?
To find the limit of x^x^x as x gets closer to 0 from the right, you can use the limit definition and plug in values that approach 0 from the right, such as 0.1, 0.01, 0.001, and so on. As these values get closer to 0, the limit will approach 1.
3. Can the limit of x^x^x as x approaches 0 from the right be graphically represented?
Yes, the limit of x^x^x as x approaches 0 from the right can be represented graphically. As x gets closer to 0 from the right, the graph of x^x^x will approach a horizontal line at y=1.
4. Is the limit of x^x^x as x approaches 0 from the right defined?
Yes, the limit of x^x^x as x approaches 0 from the right is defined and equals 1. This can be proven using the limit definition or by evaluating the limit algebraically.
5. Can the limit of x^x^x as x approaches 0 from the right be calculated using L'Hopital's rule?
No, L'Hopital's rule can only be used to find limits of indeterminate forms, such as 0/0 or ∞/∞. The limit of x^x^x as x approaches 0 from the right is not an indeterminate form, so L'Hopital's rule cannot be applied.
  • Calculus
  • Calculus
  • Calculus
