- #71
lookbehindu
- 10
sophiecentaur said:Hi - you have put me on the spot!
Remember that a hologram is just a diffraction pattern, made by combining the light reflected from an object with a reference beam. It is easiest to describe the early types of hologram which are 'transmission holograms'. This is arranged using half silvered mirrors which split laser light so that one part illuminates the object and the other acts as reference beam (there are loads of diagrams around which show this basic setup). This will produce a very complicated diffraction (interference) pattern between the two components of the laser light but any area of the pattern can be recorded on a piece of film placed there. In practice, of course, you use clever optics to get a bright enough image where you want to put the film so that you get adequate exposure. The interference pattern is very fine and you need a long exposure [Edit:and] to avoid getting a blurred image on your film (the hologram). When you shine light on the developed piece of film, you will see a diffraction pattern, caused by the hologram, which will be the same as the original object, as viewed from that direction. Different areas of the hologram contain information about the view from different directions - hence the 3D appearance. But you don't get something for nothing. The resolution of the hologram is limited so that limits the actual quantity of information that can be stored. It is totally magic, though.
The basic principle is much the same as the two slits experiment - one slit can be looked upon as the object and the other as the reference. The interference pattern can be recorded on film and, if you illuminate the film from behind and look through this pattern, you will actually see two slits. The simplest hologram you could imagine. Another simple precursor of the hologram is the zone plate, which is like a photograph of the Newton's rings you get with a convex surface resting against a plane surface. That zone plate will produce a 'focussed' point image when a wide beam of light falls on it - just like a convex lens will do.
The reason that holograms work is that the diffraction pattern is a Fourier transform of the object and the Fourier transform of the hologram looks like the original object. This wiki link discusses how holograms can be constructed without using light beams and it may help you.
Once the reference and object beam reach the plate haven't they undergone spreading (similar to incoherent light). Also when both beams reach the plate aren't they not in phase anymore? So what was the point of keeping them in phase until that point? Also I'm having a hard time understanding the divisibility principle (how can a tiny piece contain the entire image minus perspectives).
