New Reply
deriving equation for minimum height in projectile motion with two give me's :)
Share Thread Thread Tools
Jan10-13, 10:55 PM   #1
1. The problem statement, all variables and given/known data
A ball is launched at a 45 degree angle and lands 152.4 m away. What is the maximum height the ball will reach during its flight. I Know the answer, what I need is to find a way to derive an equation [itex]Δy = {\frac{Δxtan(ϴ)}{4}}[/itex] I have played around for hours working backwards and forwards with the equations below. Its miserable.
2. Relevant equations
[itex]Δy = {\frac{gt}{2tan(ϴ)}}[/itex]
All kinematic equations
3. The attempt at a solution[itex]Δy = {\frac{gt}{2tan(x)}}[/itex] was the best i got - with the help of the internet. Though with it i have no idea how to solve for t. Help:(
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Jan10-13, 11:52 PM   #2
What does the maximum height depend on?
What does the horizontal displacement depend on?
Jan11-13, 05:00 PM   #3
sorry the equation in the bottom is tangent of thetaθ, I'm not sure what you are asking, they are both dependent on time, assuming gravity is constant, apparently one is able to derive an equation and calculate max height using only the three kinematic equations.but the only known variables are angle of elevation and Δx, which is the final displacement from the origin.
Jan11-13, 05:40 PM   #4
Recognitions:
Homework Helper Homework Help
Quote by Ceeerson View Post
Where θ is the launch angle and Δy and Δx stand for ...?
Jan11-13, 06:27 PM   #5
oh, Δy indicates the maximum height achieved by the ball, which is achieved at half the total time since the balls starting y position is negligible, Δx indicates the total distance covered in the x position of the coordinate system, so making the ball's starting position the origin, the coordinates for the ball at max height are ((Δx/2),Δy) and the coordinates for the ball after it lands are (Δx,0)
Jan11-13, 06:35 PM   #6
and yes, θ is launch angle above the horizontal
Jan11-13, 09:07 PM   #7
Recognitions:
Ok, so assume some launch speed u and write the equations for x and y as functions of time. Assuming level ground, what will x be when it lands?
Jan11-13, 11:15 PM   #8
Δx = utcos(θ), Δy = ut/2sin(θ) - 1/2g(t/2)^2 Δx = 152.4m
Jan11-13, 11:18 PM   #9
and (usinθ)/2g = Δy
Jan11-13, 11:20 PM   #10
Recognitions:
Δx = utcos(θ), Δy = ut/2sin(θ) - 1/2gt^2 Δx = 152.4m
I meant the generic equations that apply throughout the trajectory, but never mind. In the above, t is the total flight time, right? If so, the second term in the expression for Δy is wrong.
Write another equation for the height at time t.
Jan14-13, 05:24 PM   #11
ok so im going to start this problem over. ok so
in the y direction, Δy = (vsinθ)t - (1/2)gt^2; Vf = Vsinθ - gt; vf^2 = v^2sinθ^2 - 2gΔy
in x direction, Δx = Vcosθt
so im guessing i rearrange for t using the x equation, so t = Δx/v(cosθ)
then i plug it into the first equation? lets see Δy = vsinθ(Δx/v(cosθ)) - (1/2)g(Δx^2/v^2(cos^2θ))
if i simplify it, Δy = (Δx)tanθ - (1/2)gΔx^2/cos^2θ
am i in the right direction ?
Jan14-13, 07:43 PM   #12
Recognitions:
Those equations are all correct, but you need to think about the specific points in the trajectory at which to evaluate them. For which instants do you have data?
Jan14-13, 10:10 PM   #13
i just have the final displacement in the x direction, i was just guessing that since the launch starts and ends on the ground that half the time wouldd be at max height, neglecting air reistance
Jan15-13, 12:50 AM   #14
Recognitions:
No, you have more than that. What is the final y displacement? What is the x displacement when at max y displacement?
New Reply
Thread Tools
Similar Threads for: deriving equation for minimum height in projectile motion with two give me's :)
Thread Forum Replies
Projectile Motion- Deriving equation Introductory Physics Homework 1
Deriving minimum escape height and velocity Advanced Physics Homework 5
projectile motion/ Half projectile motion (falling from height with horizontal veloc) Introductory Physics Homework 1
projectile motion, deriving equation Introductory Physics Homework 3
Deriving a Launch Angle Equation -- Projectile Motion -- Please Help Introductory Physics Homework 5
