Gravitational energy between two point masses infinite? Surely not
In summary, the two masses could get as close as the Schwarzschild radius of the smaller mass before the larger mass escapes.
bcrelling
69
If you draw a graph representing the tapering of gravitational force with respect to distance between two point masses (by the inverse square law y=x<exp-2>), the gravitational energy between two points would be the area under the graph between those points. This is my assumption.
Now the area is calculated by integrating between those points.
And the area turns out to be infinite!
Any ideas on what's going on- what am I missing here?
When integrating a function that has poles, you cannot simply integrate "normally". You have to invoke mathematical techniques such as Residue theorem, etc.
Zz.
You are not missing anything. Your observation is correct. In the Newtonian model, arbitrarily large quantities of energy can be extracted if two point masses are allowed to approach each other sufficiently closely.
This is a clue suggesting that either the Newtonian model is incomplete or that pointlike masses are impossible. As we know, the Newtonian model is incomplete. General relativity extends/replaces it. The uncertainty principle in quantum mechanics throws a bit of a monkey wrench into the ordinary notion of "pointlike".
That happens because the force goes to infinity under the inverse square law as the distance goes to zero near a point source; it really would take an infinite amount of energy to separate two point sources starting at the same point. But in real life there are no point sources of gravity; every object has some non-zero size. For example, if you're working with the gravitational force of the earth, r will never be less than 4000 miles - any less than that and the surface of the Earth would get in the way. You need to allow for this when choosing the range for your integration.
Ok, thanks guys.
Any suggestions on what the closest two masses can get to each other(in order to calculate the maximum extractible gravitational energy) in absolute terms?
A plack length or distance between two quarks perhaps?
It makes no sense to talk about "point masses" while talking about "planck length" and "quarks". The first is a mathematical abstraction while the others are real physical objects.
In any case you get the "maximum extractible energy" by making two bodies far apart, not close together.
bcrelling said:
Ok, thanks guys.
The closest thing to a point mass that actually exists would be a black hole so the greatest amount of gravitational energy release would be when 2 black holes merge. The mathematics of this scenario is fairly nasty, and a bit beyond me right now, but that's the direction you need to look for your answer.
Thanks that makes a lot of sense, and we needn't consider only defacto black holes, as technically every particle has it's own Schwazschild radius. I'll see it I can integrate between the event horizon and infinity.
I realized that calculating the energy between the event horizon and infinity is actually simpler and might not require integrating.
We know that the escape velocity at the event horizon is the speed of light- escape velocity by definition being the speed required to take a mass to an infinite distance from source.
So using a 1kg mass at speed C in the Newtonian formula for kinetic energy(MV2/2) would give us half the energy that same mass would contain at rest(from E=MC2).
However I assume that we'll have to use relativistic kinetic energy, and so the energy required to take a mass to escape velocity from the event horizon is going to be infinite. So now we're back where we started- considering that it takes a finite amount of energy to achieve escape velocity at any distance greater than the event horizon the gravitation energy of anything falling from any distance into a black hole is must be infinite.
That would suggest there is infinite gravitaional energy between any two masses allowed to fall into each others event horizons. Again, this can't be right?
I think a honest answer would be that we don't know., WHY?
Because we can't see , basically beyond the event horizon.WHY?
Because light doesn't reflect back , WHY?
Because after it reaches the EH the escape velocity gets greater than c so it can't get back even if it wanted to...
"""" However I assume that we'll have to use relativistic kinetic energy, and so the energy required to take a mass to escape velocity from the event horizon is going to be infinite.""""
According to theory this is right.
Now we know about black holes from the fact that EM radiation (visible light included) get's absorbed by a BH and everything around it greatly distorted so if you ask me I don't know what is inside of it but the fact that the force required to "suck in" mass at a greater than c speed is infinite seems legit.
What is gravitational energy?
Gravitational energy is a type of potential energy that is possessed by objects due to their position in a gravitational field. It is the energy that is required to move an object from one point to another within a gravitational field.
How is gravitational energy between two point masses infinite?
According to Newton's Law of Gravitation, the force of attraction between two point masses is inversely proportional to the square of the distance between them. As the distance between the two masses approaches zero, the force of attraction (and thus the gravitational energy) becomes infinitely large.
Is gravitational energy the same as gravitational potential energy?
Yes, gravitational energy and gravitational potential energy are often used interchangeably and refer to the same concept. However, gravitational energy specifically refers to the energy between two objects, while gravitational potential energy can also refer to the energy possessed by an object in a gravitational field.
Can gravitational energy be negative?
Yes, gravitational energy can be negative if the two point masses have opposite signs (i.e. one is positive and one is negative). This would result in a repulsive force between the two masses, and thus a negative gravitational energy.
How is gravitational energy related to gravitational waves?
Gravitational energy is the source of gravitational waves, which are ripples in the fabric of spacetime caused by the acceleration of massive objects. As these objects move, they emit gravitational waves, carrying away some of their gravitational energy. This energy is then transferred to other objects, causing a slight change in their gravitational potential energy.
  • Other Physics Topics
  • Classical Physics
