What does Activity mean in terms of radioactive decay?
In summary, "activity" in terms of radioactive decay refers to the number of nuclei in a sample that decay within a given time. It is defined as the decay constant multiplied by the number of nuclei of that type. Activity is a rate and can be measured in decays per second, minute, or hour. It is often graphed over time and may show fluctuations, but the overall trend is a decrease as the number of decaying nuclei decreases.
kraphysics
41
What does "Activity" mean in terms of radioactive decay?
I came across this term "activity" in text regarding radioactive decay and half lives. It is defined as "number of nuclei in a sample that decay within a given time."
That definition if fine but then when presented in a graph life format, various activities were listed along with time in x axis, y-axis format. To me, it doesn't make any sense because it's saying the activity at 0min is 8, activity at 10 min is 5, activity at 20 min is 3.17 etc.. I don't understand what this means.
Does it mean that for ex. by 10 min, 3 nuclei have decayed? if so, why would 4 nuclei have decayed by half life? I thought the decay rate could fluctuate and it doesn't have to follow a trend except by a certain half- live, number of nuclei left would be half of original?
Wouldn't this be less confusing to list "number of nuclei left vs time"?
The activity always diminishes. It is defined at decay constant times the number of nuclei of that type. The number of nuclei is not a fixed number. When a number of nuclei decay, there are less nuclei that can decay. In formula it looks like this:
[tex] N = N_0 \exp{-\lambda t}[/tex]
[tex]\lambda N = \lambda N_0 \exp{-\lambda t}[/tex]
[tex]A = A_0 \exp{-\lambda t}[/tex]
with N_0 the number of nuclei at t=0 and A_0 the activity at t=0
Activity is a rate: number of decays per second, or decays per minute, or decays per hour, etc. Your example might mean:
t = 0 min, A = 8 decays/sec
t = 10 min, A = 5 decays/sec
t = 20 min, A = 3.17 decays/sec
Obviously, you can't have a fraction of a nucleus decaying, so the 3.17 must come from counting the number of decays during a longer period and then dividing by the time to get a rate. One possibility would be 19 decays / 6 sec which would give 3.17 decays/sec after rounding off to two decimal places.
1. What is activity in terms of radioactive decay?
Activity in terms of radioactive decay refers to the rate at which a radioactive substance decays, measured in units of disintegrations per second (dps) or becquerels (Bq).
2. How is activity related to half-life?
The half-life of a radioactive substance is the amount of time it takes for half of the initial amount of the substance to decay. The activity of a substance is directly proportional to its half-life, meaning that a substance with a shorter half-life will have a higher activity compared to a substance with a longer half-life.
3. How is activity measured?
Activity is measured using a device called a Geiger counter or a scintillation counter. These devices detect the radiation emitted by a radioactive substance and convert it into a measurable electrical signal, which is then displayed as the activity in units of dps or Bq.
4. What factors affect the activity of a radioactive substance?
The activity of a radioactive substance is affected by several factors, including the type of radioactive decay, the amount of the substance present, and the half-life of the substance. Additionally, external factors such as temperature and pressure can also affect the activity of a substance.
5. How does activity relate to the danger of radiation exposure?
The activity of a radioactive substance is directly proportional to the amount of radiation it emits. Therefore, substances with a higher activity pose a greater risk of radiation exposure. However, other factors such as the type of radiation and the duration of exposure also play a role in determining the danger of radiation exposure.
