Why do all objects fall with the same acceleration regardless of mass?
In summary, Newton's Laws of motion & gravitation explain why all objects fall at the same speed in a vacuum--due to the equivalence of inertial mass and gravitational mass. Objects that have more energy and less time to decelerate have more impact force, so gravity causes all objects to fall with the same acceleration.
themadquark
I am well aware that objects of varying masses, shapes, and surface areas will fall at different speeds and accelerations in an environment with a gas in the way such as air due to air resistance. Why is it though, that gravity causes all objects to fall with the same acceleration in a vacuum? Objects that fall further and have more energy and less time to decelerate have much more impact force, so why is it that this happens?
This happens due to the equivalence of inertial mass and gravitational mass. For inertial mass we have ##\Sigma F = m_i a##. For gravitational mass we have ##F_g=G M m_g/r^2##. If the object is in free fall then ##\Sigma F = F_g## so we have ##m_i a = G M m_g/r^2##. Then, because inertial mass and gravitational mass are the same we can set ##m=m_i = m_g## and get ##a = G M/r^2##, which is independent of ##m##.
This is an FAQ over in the General Physics section: https://www.physicsforums.com/showthread.php?t=511172
Please start by reading this FAQ entry:
Zz.
Newton's Laws of motion & gravitation give F = ma =GMm/r^2 where r is distance from center of Earth (roughly constant for dropping light & heavy objects). The mass m of the object cancels out, so its acceleration doesn't depend on its mass. Assume that air resistance isn't a factor.
Galileo showed a non-mathematical proof: Aristotle says that heavy objects fall faster than light objects. So what if we tie together a heavy object with a light object. By Aristotle's reasoning, the light object would then slow down the heavy object and at the same time, the heavy object would speed up the light object. The composite light-heavy mass would fall somewhere between the speed of the two alone, say an average. But the mass of this composite is greater than the mass of either part of the composite, so it should fall faster than either the light or heavy object. Thus, we have a problem in which we have proved that the composite both falls slower than one of its components and also falls faster than either component.
1. Why do all objects fall with the same acceleration regardless of mass?
According to Newton's Second Law of Motion, the acceleration of an object is directly proportional to the net force exerted on it and inversely proportional to its mass. This means that for a given force, objects with larger mass will experience less acceleration, and objects with smaller mass will experience more acceleration. However, in the case of objects falling due to gravity, the force acting on the objects is the same - the force of gravity. Therefore, regardless of their mass, all objects will experience the same acceleration due to gravity.
2. How does air resistance affect the acceleration of falling objects?
Air resistance, also known as drag, is a force that opposes the motion of objects through air. It increases with the speed of the object and acts in the opposite direction of its motion. Therefore, as an object falls, its speed increases and so does the air resistance acting on it. This means that the net force on the object decreases, leading to a decrease in acceleration. However, for most objects, air resistance is relatively small and does not significantly affect the overall acceleration of the object.
3. Does the shape of an object affect its acceleration when falling?
Yes, the shape of an object can affect its acceleration when falling. Objects with a larger surface area, such as a flat sheet of paper, will experience more air resistance and therefore have a slower acceleration compared to objects with a smaller surface area, such as a pencil. However, as mentioned before, the effect of air resistance on the overall acceleration of an object is usually small and other factors, such as mass and the force of gravity, have a greater impact.
4. How does the acceleration of falling objects change on different planets?
The acceleration of falling objects depends on the strength of gravitational force, which is determined by the mass and distance between the object and the planet. Therefore, the acceleration of falling objects will vary on different planets, as the strength of gravity is different on each planet. For example, the acceleration due to gravity on Earth is 9.8 m/s², while on the Moon it is only 1.6 m/s².
5. Can objects fall with different accelerations in a vacuum?
Yes, in a vacuum, where there is no air resistance, objects with different masses will fall with different accelerations. This is because, in a vacuum, the only force acting on the object is the force of gravity, and according to Newton's Second Law, the acceleration of an object is directly proportional to the force acting on it. Therefore, objects with larger masses will experience a greater force of gravity and hence a greater acceleration compared to objects with smaller masses.
  • Classical Physics
