New Reply
Variations in the strength of gravity throughout the earth
Share Thread Thread Tools
Apr27-12, 04:23 AM   #1
Which parts of the earth is gravity stronger than usual, at higher points on the earth is the gravity stronger or weaker than the lower points and why?
PhysOrg.com
PhysOrg
earth sciences news on PhysOrg.com
>> NASA sees Cyclone Mahasen hit Bangladesh
>> Satellite sees Tropical Storm Alvin's life end quickly
>> The genome sequence of Tibetan antelope sheds new light on high-altitude adaptation
Apr27-12, 06:58 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
hello elijah18259! welcome to pf!
see the explanations and pictures at http://en.wikipedia.org/wiki/Gravity_of_Earth
(particularly the rotating http://en.wikipedia.org/wiki/File:GR..._animation.gif )
Apr27-12, 05:09 PM   #3
As a contributer to physics forums and a teacher interested in hearing the opinions of others can I say that it is very disappointing to find a query being directed straight to Wikipedia.
I thought this was against the standards expected here.
Apr27-12, 05:21 PM   #4
Recognitions:
Quote by truesearch View Post
I think the "standards expected here" are that folks will make some attempt to do their on at least modest research before asking questions that such modest research would answer.
It is QUITE common (and I think absolutely appropriate) in such situations to point someone to something they could have found on their own with little or no effort.
Apr27-12, 05:25 PM   #5
D H
Mentor
You're right. tiny_tim's answer wasn't quite appropriate. He should have answered "This sure looks like a homework question. What do you think? What have you found on your own to answer this question?"
Apr27-12, 08:20 PM   #6
Recognitions:
Quote by phinds View Post
I agree completely, phinds. Too many questions posted on this Forum could have been answered quite easily by a little research. Where a Wikipedia or similar entry was found, but the questioner still does not understand, the ideal would be for the questioner to cite the found reference, identifying where possible the exact place where puzzlement arises. That would avoid a lot of to-and-fro where the questioner supplies insufficient information or a reference to some obscure textbook.
Where such preliminary research has not been done, replying on this forum by link to a good reference is an excellent response. It shows the questioner appropriate methods for getting a rapid resolution and, probably, a more authoritative answer.
Jul20-12, 01:05 PM   #7
Evo
Mentor
If a source exists that contains accurate information, it is very appropriate to refer someone instead of re-typing all of the information. Why re-create the wheel? Also, tt's source contains visual aids.
And it does sound like homework.
Jul20-12, 01:16 PM   #8
Recognitions:
Not sure if I understand the question right, and we have seen it in regular intervals. One possible answer is that Earth gravity is strongest at the core mantle boundary.
Laurent Hodges 1991, "Gravitational field strength inside the Earth", American Journal of Physics -- October 1991 -- Volume 59, Issue 10, pp. 954-955
Aug11-12, 03:49 AM   #9
Recognitions:
Quote by Evo View Post
i'd like to add that sometimes it isn't obvious what title to look up in wikipedia … there can be more than one page on the same subject, and the best one isn't always the one with the most obvious title
so indicating the page not only helps the OP, it also helps other readers studying the same topic
also some wikipedia entries are very good , and it is helpful to draw attention to them!
Aug23-12, 09:15 AM   #10
Thank you everyone.
Aug23-12, 10:42 AM   #11
Recognitions:
Quote by elijah18259 View Post
Thank you everyone.
It was wise of you to change the original of the above:
Okay, thank you <sarcasm mark>. Oh, sounds like a homework question. Wat rubbish.
since such comments will not get you far here. In fact, even posting them and then quickly changing them is not a good idea since they go out in emails to everyone subscribed to the thread.
Aug23-12, 11:45 AM   #12
Effective gravity varies with latitude due to the centrifugal force caused by the earths spinning.
It also depends on the density of the mantle and crust beneath a surface. Measurements of the gravity of the earth is called gravitational tomography”. Measurements have been made and analyzed.
One approximate “rule of thumb” is that the continental rock has on average less density than deep sea floor rock. The continents are basically floating on the mantle, while the deep sea floor is mantle. However, the surface of the continent is further from the center of the earth than the sea floor. So the gravitational pull of the earth is less on the surface of a continent then above the deep sea floor. Similarly, the gravitational pull on top of a mountain is less than the gravitational pull on the surface next to it.
This rule isn’t exact. Therefore, lots of measurements have been made to find out exactly how the density beneath the surface varies.
Here are two links on gravimeter measurements.
http://scintrexltd.com/downloads/GRAVGUID.pdf
“A GUIDE TO HIGH PRECISION LAND GRAVIMETER SURVEYS
by H.O. Seigel
The formula for the general increase of g with latitude , based on the most
recently accepted spheroid approximation, is given by (Moritz, 1984).
in Gals
(6) <see reference>
This equation includes both the Newtonian attraction of the Earth as a
spheroid and the centrifugal force caused by its rotation about its axis.
http://www.gmat.unsw.edu.au/ablos/AB...per2-Greku.pdf
“Abstract
An outer edge of the continental mass is established by the foot of the continental slope in accordance with the UN Convention on the Law of the Sea (UNCLOS, article 76). It can be "visible" with the help of echo-sounding and seismic surveys. It is obvious that the real continental margin extends under upper layers of the abyssal ocean floor more seaward than the visible foot. The gravimetric tomography method [1] developed by us allows scientists to reconstruct the Earth’s internal geological structure with the satellite altimeter and geoid data to determine the real outer edge of the continental mass and the breadth of the territorial sea along the coastal countries.”
Aug23-12, 02:35 PM   #13
Recognitions:
Quote by Darwin123 View Post
Yes but also from the Geoid shape, the difference with a pure spherical shape does matter, for instance on the poles versus the equator you're closer to the center of the earth, hence you have less r but also there is less mass right beneath you, as it is more to the side.
See what Grace found for gravity:
source
Sep8-12, 01:04 PM   #14
Gravity varies based on altitude. The higher the altitude, the farther away from the center of the Earth. So Mt. Everest has less gravity than Grand Canyon. But the difference isn't too consequential.
New Reply
Tags
earth gravity, wikipedia
Thread Tools
Similar Threads for: Variations in the strength of gravity throughout the earth
Thread Forum Replies
Earth's Gravity if the Earth rotated the opposite direction Astrophysics 4
Electric Field Strength- variations Classical Physics 26
Earth has inner core surface property variations at 1km scale Earth 4
gravity on mass on earth's surface vs sun-earth gravity Introductory Physics Homework 2
Gravity variations General Physics 3
