New Reply
Stochastic calculus: [itex] \int_0^td(e^{-us}X(s))=\sigma\int_0^t e^{-us}dB(s)[/itex]
Share Thread Thread Tools
Nov9-12, 08:55 AM   #1
Why does:
[itex] \int_0^t d(e^{-us} X(s)) = \sigma \int_0^t e^{-us} dB(s)[/itex]
for stochastic process [itex]X(t)[/itex] and Wiener process [itex]B(t)[/itex]?
Also, why is the following true:
[itex] \int_0^t d(e^{-us} X(s)) = e^{-ut}X(t) - X(0)[/itex]
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Nov9-12, 09:36 AM   #2
Mentor
Quote by operationsres View Post
Why does:
I'll answer the second part.
I assume the limits of integration are for the variable, s, and not for the differential quantity, [itex]\displaystyle d(e^{-us} X(s))\ .[/itex]
We can write that differential as [itex]\displaystyle \ \ d(e^{-us} X(s)) = \left(\frac{d}{ds}\left(e^{-us} X(s)\right)\right)ds\ .[/itex]
So that [itex]\displaystyle \ \ \int_{s=0}^{s=t}d(e^{-us} X(s)) = \int_{0}^{t}\left(\frac{d}{ds}\left(e^{-us} X(s)\right)\right)ds\ .[/itex]
Nov9-12, 09:43 AM   #3
Quote by SammyS View Post
Working with this, we have that:
[itex]\int_{0}^{t}\left(\frac{d}{ds}\left(e^{-us} X(s)\right)\right)ds = \int_{0}^{t} \left( -ue^{-us}X(s) + e^{-us} \right)ds[/itex]
[itex]= -u \int_0^t e^{-us}X(s)ds + \int_0^t e^{-us}ds[/itex]
So I'm still not sure how I can get to the identity based on what you've provided?
Nov9-12, 09:48 AM   #4
Mentor
[itex]\int_{0}^{t}\left(\frac{d}{ds}\left(e^{-us} X(s)\right)\right) = \int_{0}^{t} \left( -ue^{-us}X(s) + e^{-us} \right)ds[/itex]
Use the Fundamental Theorem of Calculus to evaluate the definite integral [itex]\displaystyle \ \ \int_{0}^{t}\left(\frac{d}{ds}\left(e^{-us} X(s)\right)\right)ds\ .[/itex]
What is the anti-derivative of [itex]\displaystyle \ \ \frac{d}{ds}\left(e^{-us} X(s)\right)\ ?[/itex]
Nov9-12, 09:55 AM   #5
Recognitions:
Homework Helper Homework Help
Why does:
Presumably because that is the solution to some stochastic differential equation, maybe something like
$$dX_t = -uX_t dt + \sigma dB_t.$$
(Ito interpretation)
(I believe that is not actually the correct stochastic differential equation for that integral; it was just a first guess. Look up Ornstein-Uhlenbeck process for more information and the actually stochastic differential equation. )
The important point is that a different stochastic differential equation would yield a different integral-form solution.
Nov9-12, 10:05 AM   #6
[itex]\displaystyle \ \ \frac{d}{ds}\left(e^{-us} X(s)\right)\ = \int_0^t \frac{d}{ds}\left(e^{-us} X(s)\right)ds[/itex]
[itex]\displaystyle \ \ = d(e^{-ut}X(t))[/itex]
It seems I've gone in a circle (obviously I didn't do what you were asking for).
Nov9-12, 10:06 AM   #7
Quote by Mute View Post
A differential stochastic differential equation would yield a different solution.
In fact it is. Nice!
Nov9-12, 10:10 AM   #8
Recognitions:
Actually, I think the SDE I guessed in that post was not quite correct, as it may ignore a drift term. The full SDE is likely the one corresponding to the Ornstein-Uhlenbeck process, as I just mentioned in an edit to my previous post.
Nov9-12, 10:12 AM   #9
Dear Mute,
Since you know about the OU process, can I ask if this is an accurate representation of a mean-reverting OU?
[itex] dX(t) = (m-X(t))dt + \sigma X(t) dB(t)[/itex]
where m is the mean-reversion term, B(t) is standard Brownian Motion.
I ask because (i) This is what's in my tutorial question list, (ii) Wikipedia and all other external sources I've seen state this process without X(t) in the latter part of the expression (e.g. Wikipedia et al.).
Nov9-12, 10:41 AM   #10
Recognitions:
You need to avoid things like (d/dt)[exp(-ut) X(t)], because, typically, X(t) is a seriously non-differentiable function, and the usual calculus rules do not apply. Instead, we need to deal with stochastic differentials (essentially, the opposite of stochastic integrals), and we need to use Ito's Lemma or similar results to evaluate things. For example, if B is a standard Brownian motion, we have d(B(t)^2) = 2 B(t) dB(t) + dt, and d(exp(B)) = exp(B) dB + (1/2)*exp(B) dt, etc.
RGV
Nov9-12, 11:00 AM   #11
Mentor
The anti-derivative of [itex]\displaystyle \ \ \frac{d}{ds}\left(e^{-us} X(s)\right)\ [/itex]
is [itex]\displaystyle \ \ e^{-us} X(s)\ .[/itex]
So that
[itex]\displaystyle \ \ \int_{0}^{t}\left(\frac{d}{ds}\left(e^{-us} X(s)\right)\right)ds=\left(e^{-ut} X(t)\right)-\left(e^{-u0} X(0)\right)\ .[/itex]
Nov9-12, 11:10 AM   #12
nice, I understand, well done Sammy!
Nov9-12, 12:14 PM   #13
Recognitions:
Why does:
I don't think the expression in this thread's title is correct; however, the second one you wrote is OK (and is, basically, equivalent to the notion of a stochastic differential as an anti-stochastic integral---almost the opposite of how it is done in ordinary calculus). If we have dX = σ dB, and we let f(x,t) = exp(-ut)*x, then
[tex] f_x(x,t) = e^{-ut},\: f_{xx}(x,t) = 0, \; f_t(x,t) = -u e^{-ut} x,[/tex]
so Ito's Lemma gives
[tex] d[f(X(t),t)] = \left( 0 f_x + \frac{1}{2} \sigma^2 f_{xx} + f_t \right) dt
+ \sigma f_x dB = -u e^{-ut} X(t) dt + \sigma e^{-ut} dB,[/tex]
so
[tex] \int_0^t d\left(e^{-us} X(s) \right) = \sigma \int_0^t e^{-us} dB(s)
- \int_0^t u e^{-us} X(s) ds.[/tex]
RGV
New Reply
Thread Tools
Similar Threads for: Stochastic calculus: [itex] \int_0^td(e^{-us}X(s))=\sigma\int_0^t e^{-us}dB(s)[/itex]
Thread Forum Replies
Strange right-arrow symbol ([itex]\mapsto[/itex]) in stochastic calculus. Precalculus Mathematics Homework 1
What's [itex]d\int_0^t s dB(s)[/itex], where B(t) is Wiener process. Calculus & Beyond Homework 1
Stopping times: [itex]\{min(\sigma,\tau) \leq t\} \in \mathscr{F}_t\}[/itex] Calculus & Beyond Homework 2
Need help with expanding [itex](\bf{x-\mu_{i}})^{t}\Sigma^{-1}(\bf{x-\mu_{i}})[/itex] Precalculus Mathematics Homework 7
[itex] \Lambda^o \Sigma^o [/itex] mass difference High Energy, Nuclear, Particle Physics 7
