Help with 2 questions quickly for exams please
  • Thread starter Conor11
  • Tags
    Exams
In summary, the conversation discusses the effects of water evaporation on the temperature of air in a kitchen and in a refrigerator. It provides equations for calculating the rate of energy transfer from the water by evaporation, the rise in temperature of the air, and the energy required to cool the air in the refrigerator. It also mentions the use of specific heat capacity and specific latent heat of vaporization in these calculations.
Conor11
. A saucepan containing water is left boiling on a cooker in a kitchen for some time. As the water evaporates from the saucepan and then condenses , the temperature of the air in the kitchen is raised. Given that the volume of air in the kitchen is 15.6m^3 and that water is evapoarting from the saucepan at a rate of 0.65 grams per second calculate. 1. the rate at which energy is transferred from the water in the saucepan by evaporation. 2. the rise in temperature of the air caused by the evaporation ad condensation after 5 mins , assuming that 10% of the transferrred energy is absorbed by the air. (specific heat capacity of air= 1.0 e^3 jk^-1k-1, density of air = 1.2kg m-3, specific latent heat of vaporisation of water 2.3 e^6 j kg-1)
2. Given that the specific heat capacity of air is 1.0 e^3 jkg-1k-1 calculate how much energy must be removed from the refridgerator conatining 0.15m^3 of air to lower the temperature of the air from 20 C to 4 C . (density of air=1.2 kg m-3) The air in the refridgerator is cooled by allowing a liquid to evaporate in a closed pipe inside the refridgerator. The vapour is the pumped through the pipe to the outside of the fridge, where it condenses again. Given that 2.3 grams of the liquid evaporate per minute how long will it take to cool the air in the fridge from 20 C to 4 C if the specif laten heat of vaporisation of the liquid is 2.5 e5 j Kg-1? (heat loss by fridge is negligble)
21 hours ago - 3 days left to answer.
1. 0.006592.3e60= 1495
not sure what to do at all next , the time it takes and the density have to be taken into account but i don't see how.
2. m=dv
therefor m=0.18
e=mcdelta t
therefore e=2880j
Dont understand how to calculate using the specific latent formula with the rest of the question.
The energy to vaporize 1 g of water is the specific latent heat of vapor...
lets call it [itex]E_{vap}[/itex]
You know the mass per time and that the above energy is in the unit J/g or J/kg:
[itex] \Delta E = E_{vap}m[/itex]
2. now you have the energy [itex]\Delta E[/itex] and you know the specific heat capacity of air, so multiply the energy found in 1 by the time and use. And remember that only 10 % goes to the air:
[itex]0.10\Delta E t = m C \Delta T=\rho V C \Delta T[/itex]
Do you get it?
1. What is the best way to prepare for exams?
The best way to prepare for exams is to start studying early and consistently. Make sure to review material regularly and create study guides or flashcards to help with retention. It is also important to get enough rest and stay hydrated during exam week.
2. How can I improve my test-taking skills?
To improve test-taking skills, it is important to practice with past exams or sample questions. This will help you become familiar with the types of questions that may be asked and the format of the exam. Also, be sure to read all instructions carefully and manage your time effectively during the exam.
3. What is the best way to manage test anxiety?
To manage test anxiety, it is helpful to have a positive mindset and remind yourself that you have prepared for the exam. Deep breathing exercises and positive self-talk can also help to calm nerves. Additionally, make sure to get enough rest and eat a healthy breakfast on the day of the exam.
4. How should I prioritize studying for different subjects?
It is important to prioritize studying for subjects that you struggle with or have a heavier weight on your grade. However, it is also important to review all material to ensure a well-rounded understanding. Create a study schedule and stick to it to make sure you cover all necessary material.
5. What should I do if I don't understand a concept while studying?
If you come across a concept that you don't understand while studying, try to break it down into smaller parts and find additional resources such as textbooks or online tutorials. It may also be helpful to reach out to a classmate or your professor for clarification. Don't be afraid to ask for help.
