Calculating the number of steps in an escalator
  • Thread starter viren_t2005
In summary, the number of steps in an escalator is calculated by dividing the total vertical height by the height of each step. The average height of an escalator step is typically 7 inches, but can vary. There is no standard number of steps in an escalator and it can vary depending on the height and design. The speed of an escalator does not affect the number of steps, but can affect travel time. The number of steps in an escalator can be changed, but it is a complex process that should only be done by professionals.
viren_t2005
There is a escalator and 12 persons move down it. A takes 50 steps and B takes 75 steps while the escalator is moving down.Given that the time taken by A to take 1 step is equal to time taken by B to take 3 steps. Find the no.of steps in the escalator while it is stationary
I think I am correct. Let x be the number of steps covered by A in the given time and let y be the steps escalator sailed. then
x + y = 50
3x + y = 75.
Thus we will get the answer y as to be 37.5
To calculate the number of steps in an escalator, we first need to determine the time it takes for each person to take one step. From the given information, we know that A takes 50 steps and B takes 75 steps while the escalator is moving down. We are also given that A takes the same amount of time to take one step as B takes to take three steps.
Based on this information, we can set up the following equation:
50 steps / (time taken by A to take 1 step) = 75 steps / (time taken by B to take 3 steps)
Simplifying this equation, we get:
50 / x = 75 / (3x)
Where x represents the time taken for A to take one step.
Solving for x, we get x = 2.5.
This means that A takes 2.5 seconds to take one step while B takes 7.5 seconds to take three steps.
Now, if we assume that the escalator is stationary, the time taken by A and B to take one step will be the same. Therefore, we can set up another equation:
50 steps / (time taken by A to take 1 step) = 75 steps / (time taken by B to take 1 step)
Substituting x = 2.5 in this equation, we get:
50 / 2.5 = 75 / y
Where y represents the time taken for B to take one step.
Solving for y, we get y = 3.33.
This means that B takes 3.33 seconds to take one step while the escalator is stationary.
Now, to calculate the number of steps in the escalator, we can use the formula:
(Number of steps taken by A) * (Time taken by A to take one step) = (Number of steps taken by B) * (Time taken by B to take one step)
Substituting the values, we get:
50 * 2.5 = (Number of steps) * 3.33
Solving for the number of steps, we get:
Number of steps = 125 / 3.33 = 37.5
Therefore, the number of steps in the escalator while it is stationary is approximately 37.5. However, this is an approximation and the exact number may vary slightly
1. How is the number of steps in an escalator calculated?
The number of steps in an escalator is calculated by dividing the total vertical height of the escalator by the height of each step. This will give you the total number of steps in the escalator, including both the upward and downward sections.
2. What is the average height of an escalator step?
The average height of an escalator step is typically around 7 inches. However, this can vary depending on the manufacturer and design of the escalator.
3. Is there a standard number of steps in an escalator?
No, there is no standard number of steps in an escalator. The number of steps can vary depending on the height and design of the escalator. Some escalators may have more steps to accommodate a steeper incline, while others may have fewer steps for a more gradual slope.
4. How does the speed of an escalator affect the number of steps?
The speed of an escalator does not affect the number of steps. However, it can affect the time it takes to travel the full length of the escalator. A faster escalator may have a higher number of steps to cover the same distance as a slower escalator.
5. Can the number of steps in an escalator be changed?
Yes, the number of steps in an escalator can be changed. However, this would require significant modifications to the escalator, including adjusting the height and angle of the steps. It is not a simple process and should only be done by trained professionals.
