Preventing Tornadoes: Myth or Reality?
  • Thread starter SpaceGuy50
In summary, tornadoes are a chaotic process that is difficult to predict and prevent. However, with better early warning systems, more lives may be saved.
  • #71
It appears you're saying the best counter against a tornado is to cool it, or at least the air feeding it. Since it's usually heavily laden with moisture, an aerosol of water wouldn't be very effective.
Obviously, the application of heat would simply strength it, right? If so, detonating a nuke would only add energy to the system, although it may can enough disruption to stop one.
I doubt that, though.
The electric perspective might have merit, but again, I doubt we could afford to generate any sort of counter-current of that magnitude. Tornadoes much generate/use massive amounts of energy. What would it take? The output of the entire Eastern Seaboard?
  • #72
It appears progress in radar and computers might effectively accomplish the same goal as tornado prevention, at least to some degree. If you could predict with extreme accuracy and lead time when a tornado happened, this would reduce the need to prevent it (which might not be possible, anyway).
A big limitation to current tornado warnings is the slow 5 minute update cycle on the WSR-88D doppler system. This limits warning time, plus limits data needed for vortex signature analysis.
Currently tornado warnings are issued only on visual sightings or radar-indicated features combined with human analysis. There's a fairly high false detection rate. You normally want more than a single radar frame before calling a warning, which would take 10 minutes for two frames. A rapidly developing storm can slip between such slow updates.
Phase array radar (like used on Navy Aegis ships) could increase the update rate to 60 sec for a total volume coverage pattern, maybe faster. In weather reflection tests, the Navy Aegis SPY-1 radar already exceeds the temporal and angular resolution of the NexRad WSR-88D, despite the latter using 750,000 watts output. See graphic.
The National Weather Service has a single phased array weather radar test installation, called MPAR (Multi-mission Phased Array Radar). The optimum scan pattern is still being researched. Also, because the beam is electronically (not mechanically) steered, a severe storm region could be selectively painted every few seconds without sacrificing less-frequent 360 deg. coverage. This could increase the update rate for a given storm cell by a factor of 50 over the current WSR-88D system.
If MPAR is ever funded and deployed nationwide, the additional data from the high update rate could be combined with new computer models to issue high-confidence warnings much further in advance. At least that's the theory. The goal is "warn on forecast", vs the current "warn when tornado is detected".
If that happens and the lead time, accuracy and confidence level of tornado warnings greatly improve, people can just get out of the way.
http://celebrating200years.noaa.gov/magazine/phased_array_radar/welcome.html#intro
http://www.nssl.noaa.gov/research/radar/mpar.php [Broken]
http://www.nssl.noaa.gov/research/forewarn/ [Broken]
http://www.youtube.com/watch?v=R6Nrcsu2Rk8&feature=related
  • #73
shadrach said:
But that is getting ahead of things. Could the properties of the water molecules in a supercell be changed enough by an aerosolized soap-like substance to prevent (or lessen) a tornado?
Ben Schainker
I also thought about soap-like or foam-like substance that can help to damp tornado/storm/hurricane and moreover to harness theirs energy (a part of). It must appear when a wind achieves a certain speed, and disappear when a wind weaken. I want also for mentioned substance to be built of existed resources without artificial matters and other expensive components. Ideal result: to get desired effect without expenses and without intervention in nature.
  • #74
propalo said:
to get desired effect ... without intervention in nature.
Not split hairs but this is contradictory by definition. The desired effect is to intervene in nature.
  • #75
You are right.
Use the contradiction as a tool in the solution process
  • #76
What "new models" are under consideration?
Recent research demonstrated that even with fine-grain in situ data (such as numerous anemometers under the storms, and dual Doppler radars less than 15 km away), and given plenty of time to post-process the data, supercells that produce tornadoes are difficult to distinguish from those that do not, given the existing understanding of the dynamics of such storms.
Markowski, P., Majcen, M., Richardson, Y., Marquis, J., and Wurman, J., 2011: Characteristics of the Wind Field in a Trio of Nontornadic Low-Level Mesocyclones Observed by the Doppler On Wheels Radars. E-Journal of Severe Storms Meteorology, North America
If bi-directional in situ radars don't yield more accurate predictions in after-the-fact analyses by the leading experts in tornado science, why would we expect single-station MPAR data from a greater distance away to help in operational (i.e., real time) forecasting by staff meteorologists? Without advances in tornado theory, MPAR is just going to turn into a huge embarrassment for the meteorological community, because they will have spent a whole lot of money and the quality of the warnings still will not have improved.
joema said:
If the lead time, accuracy and confidence level of tornado warnings greatly improve, people can just get out of the way.
Just getting out of the way is not terribly realistic in major population centers. Even when rural areas are evacuated due to approaching hurricanes, it takes hours to get everybody out, due to traffic jams. The value of higher-quality warnings is that more people will find better shelter nearby, and that will save lives.
As concerns tornado prevention, I agree that it's a long shot, but only a more accurate model will tell us whether or not it's possible, or if it is, whether or not it's feasible. The bottom line is that both prediction and (possible) prevention beg the same question: what causes destructive vorticity at the ground level? Existing science cannot answer that question, and progress with existing strategies is past the point of diminishing returns. It's time to try something new. See this for what appears to be a far more realistic model of mesocyclones and tornadoes:
http://charles-chandler.org/Geophysics/Tornadoes.php
  • #77
Astronuc said:
I've wondered if it would be feasible to fly 2 or more jets (capable of supersonic speed) into the critical region of a tornado and use the shock wave(s) to disrupt the vortex (i.e., the jets would 'break' the sound barrier in the vortex generating region). But there is perhaps a risk to the jets from debris and strong fluid dynamics.
I think "a risk" is serious understatement. A sonic boom is a very puny thing compared to the kinetic energies of a tornado. I suspect that you would have many more jets flying into that tornado than flying out of it.
  • #78
Rumor has it that Navy pilots stationed at Key West used to fly through waterspouts just for the kick of it. Supposedly they could come out with a 90° course change if they hit it just right. Navy brass frowned on the practice, as the extreme G's put the pilot and plane at great risk. I don't know if they ever lost a plane this way, but I think that they don't do this anymore.
Regardless, a sonic boom isn't going to change much. A sound wave pushes, and then it pulls. When all is said and done, nothing has changed, except for a slight increase in temperature.
  • #79
Agreed. You can't just hand wave away the shear magnitude of energy stored in a tornado.
  • #80
In a general lay man terms what i know about tornadoes is that it occurs due to a sudden difference in the temperature leading to formation of vortex which soon engulfs the area around it. I don't think it is possible to stop tornado, but i think it is possible to prevent it.
  • #81
An only halfway tongue-in-cheek response: It would probably be more efficient to improve the social net and urban planning so we have less people living in trailer parks.
  • #82
The answer to the simple question posed in the OP is 'no'. Can we prevent runaway threads?
  • #83
Rather then waiting for the tornado to form and then trying to stop it, why not research a way to prevent the circumstances that may produce a tornado?
  • #84
And what would that be? Tornadoes form mostly in North America because of its geography. The major mountain ranges run north to south and a vast plain runs from the Arctic Ocean to the Gulf of Mexico. This provides excellent conditions for clashing humid warm air and dry cold air masses. Without going into the physics, these are prime conditions for violent weather, including thunderstorms and tornadoes. To prevent tornadoes you would need to change the geography or change the physics. This thread is full of very speculative posts which would appear to violate the rules of these forums. As I said in my previous post, the answer to the OP's question is no. I posted a source, earlier in this thread, from the US Weather Service which said as much. Ideas regarding seeding of thunderstorms with various chemicals to prevent tornado formation have been discussed for years and for various reasons have been discarded as impractical or possibly dangerous. The latest outbreak produced over 50 tornadoes, but there's no known way to even identify exactly when or where they might form. Research is continuing however. These studies are aimed mostly at being able to make more precise predictions and give more specific warnings.
  • #85
Has anyone thought about this? The Army has a "oxygen depleting" weapon? What about Airforce using global-positioning, via lasers fired from law enforcement at the tornado, dropping a "oxygen depleting" devise(upper atmosphoere). It eliminates the tornados abiltity to develop energy, thereby no tornado. Upper atmosphere, so that there is no harm to people. What do you think?
  • #86
so many weird things in that post...
least of which is the upper atmosphere thing.
dont really think tornadoes need oxygen to flourish
Tornadoes form in the LOWER atmosphere usually within the first 1000 metres give or take a bit
If you have ever seen tornadoes form you would realize that
The only way to stop a tornado from forming would be to stop the storm cell from forming.
Considering the energy involved in a major storm cell it would require the energy release of a respectable nuke/or equilivelent to disperse it.
Unfortunately that is going to do just as much if not more human, property and enviromental damage as what the storm/tornado would do anyway
Dave
  • #87
Among the host of reasons it's flawed, is a simple one. Depleting oxygen from a tornado would have no effect on it. Not sure why you think it would.
  • #88
Tornados are hot and cold air! Air is oxygen! If we eliminate its ability to create this energy, there is no tornado. The key is to sto it from generating more of it early!
  • #89
you mis-understand
tornadoes will form in any atmosphere, doesn't have to be oxygen/nitrogen as with our atmosphere. Their formation has nothing to do with the basic makeup of the atmosphere.
Dave
  • #90
For example, tornadoes (dust devils) form quite happily on Mars, whose atmosphere contains no oxygen at all.
  • #91
Do some reading up on the formation of thunder storm cells --- most important to understand that! :)
Then carry that reading on to the next stage as to the reasons why some thunder storm cells produce tornadoes and some dont. The conditions required within the stormcell that need to be just right to produce a tornado
on a side note... I also really don't think you grasp the magnitude of what you are suggesting about depleating a "gas" from a given sized area. How do you think you could deplete the gas of say 10 cubic kilometres ( the avg sized storm cell) without all the surrounding "gas" in the area rushing into fill the void... that in itseld if going to produce very strong winds into that void
Dave
  • #92
nice example ... dave :)
D
  • #93
I've read through this thread, and I wonder if some people might be going about this the wrong way. As some have pointed out, the amount of energy involved is huge; direct intervention will probably not be feasible for at least quite some time. However, there are other ways to minimize damage caused by tornadoes. The most obvious ones have already been mentioned: better warning systems, and making infrastructure more 'tornado-resistant'.
Something else I've been thinking about is this: how about redirecting the tornado to a less populated area? (Preferably, a completely unpopulated area.) I suspect this would be much easier than trying to weaken a tornado directly, for the same reason deflecting a flying object is easier than stopping it (although a tornado is admittedly much more complex). If the local weather (in the path of the tornado) significantly affects it's direction and force, trying to affect the tornado indirectly seems conceivable.
Unfortunately, most of what I said is only blabbering because, as has also been said, we don't know that much about how tornadoes work. And let's not forget that redirecting a tornado to less populated areas doesn't exactly make everyone happy :uhh: and those unhappy people would likely want compensation, which makes this more expensive.
  • #94
Makes sense so far.
Too bad you couldn't stay on the rails. How in the world do you redirect a tornado? Do you put on your orange and yellow uniform and point to the right (or left you're in the UK where these things are pretty rare.)?
Unfortunately, most of what I said is only blabbering because, as has also been said, we don't know that much about how tornadoes work. And let's not forget that redirecting a 0tornado to less populated areas doesn't exactly make everyone happy :uhh: and those unhappy people would likely want compensation, which makes this more expensive.
Bold mine.
Yes indeed. Let us not forget.
  • #95
I don't know how to do such a thing specifically, that was sort of the point. :wink: I think it might be easier to try to change the direction/force of a tornado by modifying some variables in its path, instead of directly trying to affect the tornado. Obviously, I haven't tried any of this out on any tornadoes nearby, nor do I even know whether we even have the equipment to try any of this right now (I think not).
  • #96
Again as I commented to the other poster...
read up on how thunderstorm cells are formed and what conditions are required within a storm cell to allow it to produce a tornado. Once you have some of those basic understandings you will realize the massive energy releases are involved in a large storm cell and how futile our attempts would be to try and dissapate the storm without doing severe damage in the process.
Altho the total ins and outs of tornado formation may not be completely understood, they are understood well enough to predict which storm cells are likely to produce a tornado. That can be and is done relatively successfully. Us storm chasers do it every spring and summer in the mid-west USA and other countries.
It really still boils down to building structures that can either withstand the tornado onslaught ( probably easier to build structures to withstand big earthquakes!) or try to improve warning times for people to get to shelters for their protection.
But unfortunately good warning times for tornadoes are the same as for earthquakes ...
ie. when the tornado/quake is some distance from an urban area, early warning can be good. But if the tornado forms within a few km's or over (likewise with a quake right under) an urban area there can be no early warning.cheers
Dave
  • #97
What I don't understand is why buildings in areas prone to tornadoes are not required to have underground shelters?
I live in Kansas, and moved from a house with a basement with a concrete sheltered space only a few feet wide that would provide the most safety, to an apartment that doesn't even have a basement. We have an excellent tornado warning system, but most of the buildings have no basement shelter. What good does a tornado siren do if I have no shelter to go to? Why isn't there a law that makes at least one shelter per apartment complex mandatory? If a tornado hit here, I'd be toast. The same for most small businesses. There is no place to go.
  • #98
I guess they figure you can ride it out in your clothes dryer. I've never heard of anyone that was killed that sought out the clothes dryer refuge.
<h2>1. What causes tornadoes to form?</h2><p>Tornadoes are formed when warm, moist air collides with cool, dry air. This creates instability in the atmosphere, leading to the formation of a rotating column of air.</p><h2>2. Can tornadoes be prevented?</h2><p>No, tornadoes cannot be prevented. The conditions that lead to their formation are complex and cannot be controlled by humans.</p><h2>3. Are there any methods or technologies that claim to prevent tornadoes?</h2><p>There are no proven methods or technologies that can prevent tornadoes. Some people believe that seeding clouds with substances such as silver iodide can prevent tornadoes, but there is no scientific evidence to support this.</p><h2>4. Is it possible to predict when and where a tornado will occur?</h2><p>While it is possible to forecast the general conditions that are favorable for tornado formation, it is currently not possible to predict the exact time and location of a tornado. Weather forecasting technology and techniques continue to improve, but tornadoes are still unpredictable events.</p><h2>5. What can be done to minimize the damage and impact of tornadoes?</h2><p>While we cannot prevent or predict tornadoes, we can take steps to minimize their impact. This includes having a plan in place for shelter and evacuation, staying informed about weather conditions, and building structures that are designed to withstand strong winds and debris.</p>
  • Earth Sciences
  • Earth Sciences
  • Earth Sciences
15K
  • Earth Sciences
66K
