What is happening in my circuit?
  • Thread starter PsychonautQQ
  • Tags
    Circuit
In summary, the transistor acts like a switch when given enough base current. The collector current flows through the relay, causing it to turn on. The relay turning on indicates that current is flowing through the collector and emitter of the transistor. The amount of collector current is determined by the base current and the gain of the transistor. The transistor can act as a switch or amplifier depending on the amount of base current provided.
PsychonautQQ
784
If I have a relay coil hooked up to the collector port of a transistor and have a solid signal going in the base, can somebody explain what is happening inside the transistor right when the relay turns on? (npn transistor)
The transistor is being given base current, so it causes collector current to flow. The circuit is designed so that the base current is greater than the minimum needed to cause this particular collector current, so the transistor saturates (has a very low voltage between E and C) and acts like a good switch. The collector current is the current in the relay.
the relay turning on is really just a signal that current is flowing between the collecter and emitter?
should be like that as current flow creates a mag field in the relay and turns it on (atleast most of them work that way)
Just like Nascent said , when a BJT gets a high enough base current the C E junction conducts or is open so current flows from the source you have through the relay then through the transistor to whatever is next there in your circuit.
Just like Nascent said , when a BJT gets a high enough base current the C E junction conducts or is [strike]open[/strike] closed so current flows from the source you have through the relay then through the transistor to whatever is next there in your circuit.
I recall someone being taken to task ( in a most civil PF way, of course, :smile: ) previously over the OPEN and CLOSED convention for switches. That wasn't you, Crazy, was it? :wink:
"Just a signal" isn't the best way to describe it. The current is necessary to turn the relay on.
If the circuit is working correctly then yes the relay turning on is evidence that current is flowing through the transistor.
But consider what happens if I replace your transistor with one that is faulty and has a short circuit between the collector and the emitter. The relay would still turn on. Of course it would also stay on even when there was no current going into the base of the transistor.
There are a lot of web sites with explanations of how a NPN transistor works. Most are quite complicated and assume you understand how a diode works. Is that the problem? Do you need a simpler explanation?
Basically if your circuit pushes ?mA into the base of an NPN then upto hFE * ?mA can flow from collector to emitter. hFE is the gain of the transistor and is typically around 60-200 for common transistors. Let's assume the gain of your transistor is 100.
So if your base current were say 2mA then the transistor will allow upto 2 * 100mA = 200mA to flow between collector and emitter.
I say "upto" because the actual current in your circuit might be limited by the resistance of the relay coil. If the supply voltage was 12V and the relay coil 1k Ohms then only about 12mA will flow when the transistor is on/conducting.
The answer to this question depends on the specific circuit in question. Some common things that may be happening in a circuit include the flow of current, voltage changes, and the activation of components such as resistors, capacitors, and inductors.
Why is my circuit not working?
There could be several reasons why a circuit is not working. Some possible explanations include loose connections, faulty components, incorrect wiring, or a power source issue. It is important to carefully troubleshoot and identify the root cause of the problem in order to fix it.
How can I improve the performance of my circuit?
There are several ways to improve the performance of a circuit. One option is to use higher quality components that are designed for the specific purpose of the circuit. Another option is to optimize the wiring and layout of the circuit to reduce interference and improve efficiency.
What is the role of resistors in a circuit?
Resistors are used in circuits to limit the flow of current and to control the voltage. They help to regulate the amount of electricity flowing through a circuit and protect other components from damage. Different resistors have different resistance values, and their placement and values can greatly impact the overall performance of a circuit.
How do capacitors work in a circuit?
Capacitors store and release electrical energy in a circuit. They are made up of two conductive plates separated by an insulating material called a dielectric. When a voltage is applied, one plate becomes positively charged and the other becomes negatively charged. This allows capacitors to store energy and release it when needed, making them useful for things like filtering signals and smoothing out power supplies.
  • DIY Projects
  • Electrical Engineering
  • Other Physics Topics
