Sask.watch
- 3
Hi all, this is my first post. I was wondering if it would be possible to use a deflatable/inflatable bladder inside a housing with an air valve at the top and bottom of said bladder secured through the housing. The housing material would be heavy, placticised metal or stainless steel. This housing would travel up and down jnside a guide. The guide would be part of a complete frame secured under water either inside a container or in a body of water ie: ocean. The frame structure would have a compressed air chamber with air lines running to the top and bottom. When the bladder is deflated it would sink traveling down the guide to the bottom of the frame docking onto the bottom air line with the valve in the bladder housing. The airline would release compressed air into the bladder inflating it. The docking mechanism would release the bladder housing allowing it to rise through the guide to the top of the frame structure again docking with the top airline. Here the bladder housing would be deflated and the docking mechanism would release allowing the bladder housing to sink. The bladder housing would have magnets attached and the guide would have a wire coil attached around it.
I am not very educated and there are many questions of this idea I can not answer as how compressed air acts under water, How long/tall could this structure be, could the deflated air be saved and reintroduced to the compressed air tank? I know the magnet and coil principle is used to produce electricity but would this idea be workable? I appreciate your comments and if it is bunk i accept the views of you learned lot and hope to learn a little more on this topic. Thanks
