Why we only consider ''group'' symmetry but not general symmetry?
In summary, the author is asking why we only consider symmetry groups (Lie group and Lie algebras) in quantum field theory, but not general symmetry (the transform that keeps Lagrangian invariant). He suggests that groups and algebras based on commutators rather than anticommutators is why this is the case. He goes on to say that often the only way to discover the symmetry of an equation is to search for groups that let it invariant. He also says that there are cases where it makes sense to discuss generators (in case of Lie groups and algebras) and that general symmetry structures like the diffeomorphism or mapping class group for GR, infinite dimensional
ndung200790
519
Please teach me this:
Why do we only consider symmetry group(Lie group and Lie algebras) but not general symmetry(the transform that keeps Lagrangian invarian) in QFT?Is it because the symmetry group is more simple and more beautiful and in reality the forces of Nature obey the symmetry U(1)xSU(2)xSU(3)?
Thank you very much for your kind helping.
Why do we only consider symmetry group(Lie group and Lie algebras) but not general symmetry(the transform that keeps Lagrangian invariant) in QFT?
Which "transform that keeps Lagrangian invariant" do you mean? Can you give an example? Many of these transformations do indeed form a group. Perhaps you're thinking of dynamical groups instead of just symmetry groups?
Or are you asking why we use groups and algebras based on commutators rather than anticommutators?
Sometimes people use semigroups (group without the requirement for an inverse).
An example is the theory of time-asymmetric phenomena such as formation and decay of resonances.
He might also be asking why we spend so much time studying Lagrangians with "groups of symmetries" rather than just "symmetries". ndung200790, you may have to explain what you meant.
One reason why groups of symmetries are interesting in quantum theories is that Stone's theorem says (roughly) that for any group homomorphism U from a 1-parameter commutative group into the group of unitary operators on a Hilbert space, there's a self-adjoint operator A such that [itex]U(t)=e^{iAt}[/itex] for all t. (Click the link if you want to see a more exact statement of the theorem). The operator A (or is it -A?) is called the generator of this representation.
Pretty much all the interesting observables in quantum theories are generators of a representation of some symmetry group.
You have to define what a symmetry is and apparently the only way to do it consistently and generally leads to the semigroup condition for the transformations you're looking for.
I think there would be a transformation that the generators do not form a group,meaning that if we combine two generators,the result is not coresponded to any generator we considering.So can we demontrate that any transformation which remains Lagrangian invariant is a group(e.g.satisfying the closed characteristic of a group)?
In the case of discrete symmetry operations like charge conjugation, parity or time reversal you don't have any generator at all which does not mean that the operations don't form a group.
What do you mean by "combine two generators"?
If the commutator of two generators always yields another generator then you've probably got a Lie algebra, which can (usually, but not always, iiuc) be exponentiated to form a Lie group.
OTOH, if a commutator of two generators [A,B] yields something (call it C) which is not in your set of generators, then you must calculate higher commutators like [A,C] and [B,C] and try to determine whether this higher order commutator algebra eventually closes. If it doesn't then you've got an infinite-dimensional Lie algebra (probably better thought of as a noncommutative Poisson algebra).
[Edit: I wish Arnold Neumaier wasn't so busy with other things right now. He could give a much better answer to this.]
The combination of two generators means the product of two elements in group theory.
ndung200790,
everything you said so far can be understood as a symmetry operation represented by a (finite or infinite or even continuous) group.
In some cases it makes sense to discuss generators (in case of Lie groups and algebras), in some other cases (like C, P, T or crystallographic groups) not.
There are rather general cases of symmetry structures like the diffeomorphism or mapping class group for GR, infinite dimensional Kac-Moody algebras (as generalizations of finite dimensional Lie algebras) with central extension in string theory, supersymmetry / supergravity / graded algebras, quantum deformations of U(1), SU(2), dynamical symmetries (ordinay symmetry groups like SU(n) for the n-dim. harmonic oscillator) and perhaps many more which I am not aware of. I haven't seen anything else that does not belong to such a (generalized) symmetry structure.
The reason is rather simple.
Consider you have a Lagrangian L[x]; now you do something with it and get L[x'] where x has been transformed using something called 'g', but L is invariant (b/c it's a symmetry ;-). No you do something else with it called 'h' and get L[x'']. You can now write formally
x'= g*x
x''= h*x' = hg*x
which automatically results in a group structure!
I have no idea how to talk about a symmetries or transformations which do not form to a group.
Please have a look at
http://en.wikipedia.org/wiki/Group_(mathematics)#Definition
Which property can be relaxed?
Closure: you have a symmetry transformation, a second symmetry transformation, but both transformation together are not a symmetry ?
Associativity: OK, perhaps one could play around with Octonions, non-associative algebras ...
Identity element: having no identity element would mean that it's not possible to do nothing!
Inverse element: having no inverse means that certain transformations cannot be undone; I have no idea how this would look like
Please give me a hint what you have in mind
I owe all your helping very much.As Mr Tom.Stoer pointed,now I understand under transformations the Lagrangian to be invariant,the transformation ''group'' has closure characteristic(that I had wondered).
How would you define a symmetry? A reasonable definition is that a symmetry transformation of the Lagrangian is a transformation that doesn't change the equations of motion. With this definition, to do nothing to the Lagrangian is a symmetry transformation. Let's denote it by 1. If S is a symmetry transformation, then it must be invertible and S-1 must be a symmetry transformation. So {1,S,S-1} is closed under composition of functions, and is therefore a group.
Exactly!
Indeed. Every symmetry transformation set is a group.
Does the equation of 4-divergence of Noether conserved current equaling zero be a ''type of motion equation''(and the equation does not change under the symmetry(Frederik's definition)?
By the way,please teach me what is ''dynamical group''?
Afaik it's a symmetry group acting in phase space, not in position space.
Consider the 1-dim. harmonic oscillator. In position space there is no obvious continuous symmetry, but in phase space you can define a SO(2) rotation in the (p,x) plane via a canonical transformation which leaves the Hamiltonian H ~ p² + x², i.e. the length of the vector (p,x) invariant.
For the N-dim. harmonic oscillator you get the SU(N) symmetry in phase space.
https://www.physicsforums.com/showthread.php?t=548773
The generators in a "symmetry algebra" commute with the Hamiltonian.
The generators in a "dynamical algebra" do not necessarily commute with the Hamiltonian, however such a commutator preserves the set of such generators.
More explicitly, suppose the set [itex]\{ g_1, g_2, g_3 \}[/itex] spans a Lie algebra [itex]{\mathbb g}[/itex]. Then if [itex][g_i,H] = 0[/itex], the [itex]g_i[/itex] are said to span a "symmetry algebra". However, if the commutator between the Hamiltonian H and [itex]\mathbb{g}[/itex] stays in [itex]\mathbb{g}[/itex], i.e., if
[tex]
[g_i,H] = \dots ~\mbox{linear combination of the}~g_i \dots
[/tex]
then the [itex]g_i[/itex] are said to span a "dynamical algebra". In other words, the action of the Hamiltonian transforms any element of the dynamical algebra into some other element of the dynamical algebra.
Thus, if one can find the maximal dynamical algebra for a given Hamiltonian (and a convenient representation thereof), then one has almost solved the whole problem since elements of the dynamical algebra evolve in time only amongst themselves.
BTW, in classical mechanics, one has Poisson brackets. We then try to "quantize" the system by modifying this classical dynamical algebra and representing it somehow as operators on a Hilbert space.
Then my example of the N-dim. harmonic oscillator is not the most general case of a dynamical group b/b H is the the generator of the trivial U(1) factor and commutes with all SU(N) generators, i.e. we have U(N) = U(1)*SU(N).
Is there a simple example where one can see explicitly [H, gi] = f(gi)?
(I am thinking about the constraint algebra in canonical LQG - but this is definately not a simple example)
By the way,now I have known the very difference between Lie group and Lie algebra.(The confusing leads me to this question)
That sentence is a bit confusing. Are you asking what the difference is? Start with the first paragraph of the indented text in this post. (Note however that the short "definition" of "Lie group" in that post is incomplete. There are some additional requirements).
[tex]
[/tex]
I think it goes this way: one initially has the dynamical algebra in which he looks for the symmetry operators, which are usually found in an extension of it, the universal envelopping algebra of the dynamical algebra. If the dynamical algebra is a Lie algebra, then the symmetries are Casimir elements of it. As it's well-known, for the H-atom, the maximal dynamical algebra is so(4,2).
Do you have a reference? I know the SO(4) symmetry where H commutes with all generators.
Chapter 12 of Barut and Raczka's text on group theory has a rigorous treatment, while the chapter in Wybourne on the H-atom is more algebraic than topological, but it is an extended treatment. Actually in the H-atom you have several dynamical groups and corresponding dynamical algebras, but, AFAIK, SO(4,2) is the largest one.
Usually it pops directly from its definition. If you have two symmetries, then by any definition you could give to a symmetry :) their composition would be a symmetry too since it requires leaving something invariant. Identity is certainly a symmetry whatever you have in mind. Inverses are required usually for your theory to make physical sense. All other properties follow from the operation you define on your symmetries (which is usually something like a composition of operators etc).
Again my question: is there a simple example for a dynamical symmetry where one can see explicitly [H, gi] = f(gi) ≠ 0?
In the cases SU(N) for the N-dim. harmonic oscillator and SO(4) for the hydrogen atom H commutes with all generators.
You may find this article interesting. http://prola.aps.org/abstract/PR/v139/i5B/pB1433_1
Dynamical groups have been invented by Asim Barut and most of the search in the 1960's has been done by him.
thanks; I found a hint in another paper
in case of the 1/r potential one can either multiply H by r which cancels 1/r or one can find a canonical transformation which does exactly this; then it's possible to rescale by E and find a combination of SO(4,2) generators which is equal to rH
not very systematic; as far as I can see it's better to know the result before one starts with the calculation ;-)
A simple Heisenberg oscillator algebra with [itex]a,a^*[/itex] satisfying CCRs, and a Hamiltonian such as [itex]H=a^*a[/itex].
(This example is more revealing if considered in terms of ordinary (Glauber) coherent states.)
For something less trivial, you could try looking up material on "generalized coherent states". There's a old textbook by Perelomov and a newer one by Gazeau. Also this classic review paper:
WM Zhang, DH Feng, R Gilmore,
Coherent states: Theory and some applications,
Rev. Mod. Phys. 62, 867-927 (1990).
Another relevant reference is
R. Gilmore,
Lie Groups, Lie Algebras & Some of Their Applications,
Wiley 1974, Dover, 2002
who treats the SO(4,2) description of the hydrogen atom in Exercises on pp. 427-430, both in a nonrelativistic and relativistic setting, with and without spin.
1. Why do we only consider "group" symmetry in scientific research?
Group symmetry, also known as point group symmetry, is the most commonly used type of symmetry in scientific research because it allows for easier analysis and prediction of physical properties. It also simplifies the mathematical calculations involved in understanding the symmetry of a system.
2. What is the difference between "group" symmetry and general symmetry?
Group symmetry refers to the specific symmetry operations that can be applied to a system, such as rotations, reflections, and translations. General symmetry, on the other hand, encompasses all possible symmetry operations, including those that are not applicable to physical systems. In scientific research, we focus on group symmetry because it is more relevant and useful in understanding real-world phenomena.
3. Can general symmetry be used in scientific research?
While general symmetry is not commonly used in scientific research, it can still be useful in certain contexts. For example, in theoretical physics, general symmetry may be used to explore new theories and concepts. However, in most practical applications, group symmetry is the more appropriate choice.
4. How do we determine the symmetry of a system?
The symmetry of a system can be determined by analyzing its physical properties and identifying the symmetry operations that leave those properties unchanged. These operations can then be classified into different symmetry groups, which can help us understand the overall symmetry of the system.
5. Why is symmetry important in science?
Symmetry is an essential concept in science because it allows us to simplify and understand complex systems. By identifying and studying the symmetries of a system, we can make predictions about its behavior and properties. Symmetry also plays a crucial role in the development of theories and models in various scientific fields.
  • Quantum Physics
  • Quantum Physics
  • Beyond the Standard Models
