The effects of the alpha, beta and gamma radiation on humans
In summary: Most of which do a terrible job of explaining the science behind it.In summary, radiation damages the body by knocking protons and nucleons out of atoms, causing them to decay, breaking molecules, knocking electrons off cells, and ionizing water and air in the body.
Steve143
I have had a great deal of trouble finding sources that are specific as to how exactly radiation damages the body, it usually just says what damage radiation causes but not how it causes it, so I have compiled what I have found and I want to know if it is accurate and to fill in sequence of events that happens when radiation causes damage.
So Alpha particles can physically collide with atoms and molecules inside the body:
1) Knocking protons and nucleons out of atoms, making them unstable, causing them to decay. No information on why this is a bad thing. Can't cells just be repaired?
2) Causing physical damage to molecules by breaking them apart which causes problems if the dna of the cell is damaged because it can not always be repaired properly
3) knock or attract electrons away from cells, ionizing them (why is this a problem? somehow causes cancer, cells are made of trillions of atoms)
4) ionze water and air in the body (why is this a problem?, ionized oxygen molecules are called free radicals, nothing specific as to how how they cause damage, not sure why ionized air molecules are bad)
Due to their large size they cannot travel very far without colliding with many things, which drains their energy giving them a very small range - typically a few centimetres in air.
Their positive charge makes them more effective at ionizing atoms than other fast moving particles as they attract electrons away from atoms, but do not take the electrons for themselves when moving at high speed. All fast moving particles can cause the type of damage mentioned above.
Beta particles
When a beta particle passes an atom, it tends to push electrons off the atom ionizing cells , water and oxygen in the body, no mention on how this is achieved. Do they collide with the electrons, pushing them off?
Beta particles have much less mass than alpha particles, so they collide with less objects when moving through the atmosphere, so lose less energy during travel and thus have a longer range - typically a few metres in air. They are not as effective as ionizing as alpha particles because alpha particles have a positive charge which attracts electrons away from atoms, beta particles do not.
Gamma waves
ionizes and somehow damages cells, can't find anything specific on how it causes damage. Doesn't ionize atoms directly but does something to atoms which causes them to expel electrons (how does it do this?)
Is an electromagnetic wave, has infinite range but it is blocked by something which can absorb it like lead.
Science news on Phys.org
google "biological radiation damage". You will get a whole slew of articles.
1. What are the differences between alpha, beta, and gamma radiation?
Alpha, beta, and gamma radiation are all types of ionizing radiation, which means they have enough energy to remove electrons from atoms. Alpha radiation consists of helium nuclei, beta radiation consists of high-speed electrons or positrons, and gamma radiation consists of high-frequency electromagnetic waves.
2. How do these types of radiation affect the human body?
Alpha radiation is the most harmful to the human body because it has the highest ionizing power and can cause extensive damage to cells. Beta radiation is less harmful because it has lower ionizing power and can be stopped by a thin layer of clothing or skin. Gamma radiation is the least harmful because it has the lowest ionizing power and can only cause damage to cells if exposed to high levels for a long period of time.
3. Can exposure to alpha, beta, or gamma radiation cause cancer?
Yes, exposure to any type of ionizing radiation can increase the risk of cancer. Alpha radiation is the most likely to cause cancer because it can damage DNA, which can lead to mutations and the development of cancerous cells. Beta and gamma radiation can also cause cancer, but they are less likely to do so because they have lower ionizing power.
4. How do scientists measure exposure to alpha, beta, and gamma radiation?
Scientists use different units to measure exposure to different types of radiation. For alpha radiation, the unit used is the rad, which measures the amount of energy deposited by the radiation in a material. For beta radiation, the unit used is the rem, which takes into account the effectiveness of the radiation in causing biological damage. For gamma radiation, the unit used is the gray, which measures the amount of energy absorbed by a material.
5. What safety precautions should be taken to minimize exposure to these types of radiation?
To minimize exposure to alpha, beta, and gamma radiation, it is important to limit the amount of time spent near a source of radiation, increase the distance from the source, and use shielding materials, such as lead or concrete, to block the radiation. It is also important to follow proper safety procedures and wear protective gear when working with radioactive materials.
  • Thermodynamics
  • Thermodynamics
  • Thermodynamics
9K
  • Thermodynamics
