Water Evaporation: Boiling Point & Slow Evaporation
In summary, water has a boiling point of 100 degrees Celsius at atmospheric pressure, but this does not mean that it only evaporates at this temperature. Evaporation can occur at any temperature, but boiling only occurs when the temperature reaches 100 degrees Celsius. This is because the vapor pressure of water becomes equal to atmospheric pressure, causing visible evaporation in the volume. Water will continue to evaporate until the air becomes saturated, and the saturation vapor pressure increases with temperature. At 100 degrees Celsius, the saturation vapor pressure is equal to atmospheric pressure, but at higher temperatures, water will try to create a higher atmospheric pressure in order to reach equilibrium, causing it to boil.
kur82
It is known that boiling point of water is 100C or evaporated at 100C and atmospheric pressure. why we see that water evaporates slowly at all temperature.
Temperature is defined as related to the average kinetic energy of the (in this case) water molecules. Since it is an average there will always be some that have a high enough velocity to penetrate the surface layer, thus escaping the liquid. This is evaporation.
Because the chemical potential of water is not the same for the liquid and gas phase and so the system (liquid water)+(air with water vapor) is not in a equilibrium state.
When the relative humidity is 100% it means that the chemical potential of water in the whole system is a constant. This implies that the system is at equilibrium and no more net evaporation will occur.
Here's a PDF explaining it better: http://www.inscc.utah.edu/~tgarrett/6020/Clouds/Evaporation.pdf.
Only the first part is actually known. The boiling point of water at atmospheric pressure is 100 C.
This first part does not imply that water evaporates only if the temperature is 100C. It evaporates at any temperature.
What is special about boiling point is that the vapor pressure becomes equal to atmospheric pressure. The visible effect is that evaporation happens in the volume (see the bubbles) and not just from the surface.
Water evaporates slowly at all temperatures, and the evaporation increases with water temperature increase, but the "boiling" starts at the point the water temperature reached 100 degrees Celsius at atmospheric pressure.
Evaporation only happens if the air is not saturated. Water is always evaporating until the air becomes saturated. Saturation vapor pressure increases with temperature. Water saturation vapor pressure at 100 C temperature is equal to 1 atmosphere. That means that at that temperature the atmosphere would have to be all water in order to saturate. At temperatures above 100 C water is trying to create a partial pressure larger than the total atmospheric pressure in order to saturate. That can't be done so water vapor rushes out trying to establish a higher atmospheric pressure so equilibrium can be reached - the poor thing. That rushing out is called boiling.
1. What is the boiling point of water?
The boiling point of water is 100 degrees Celsius or 212 degrees Fahrenheit at sea level. This is the temperature at which water changes from a liquid to a gas, or evaporates.
2. Why does water evaporate?
Water evaporates because of the energy provided by the sun or other heat sources. This energy causes the water molecules to move faster and eventually break apart, changing from a liquid to a gas state.
3. How long does it take for water to evaporate?
The time it takes for water to evaporate depends on various factors such as temperature, humidity, and surface area. On average, it can take anywhere from a few hours to a few days for a small amount of water to completely evaporate.
4. Does water evaporate faster at higher altitudes?
Yes, water evaporates faster at higher altitudes due to the lower atmospheric pressure. This means there are fewer molecules in the air to exert pressure on the water surface, allowing it to evaporate more quickly.
5. Can water evaporate at room temperature?
Yes, water can evaporate at room temperature, although it may take longer than if it were heated. This is because the molecules in water are constantly in motion, and some of them have enough energy to break free from the surface and enter the gas state.
32K
9K
  • Mechanics
  • Mechanics
  • Mechanics
  • Biology and Chemistry Homework Help
