Binary star system and Apparent magnatudes
In summary: This has been a great help.In summary, the apparent magnitude of a binary star system is equal to the product of the magnitude of the two stars and their luminosities.
AstroPhys
[SOLVED] Binary star system and Apparent magnatudes
I was asked this questing in my tetbook and can't figure out how to do it.
Suppose there is a binary system made up of two identical stars, each with an apparent
magnitude of +4.1. However, from our 40 cm telescope they appear as one star, i.e.,
they are unresolved. What would be the apparent magnitude of this ``star?"
I figure that the two stars apparent magnatudes must add together to get this magnatude somehow but I am not quite sure how, because 100 magnitude 6 stars = a magnitude 1 star. is there some simple formula to figure this out.
There should be a formula for relating N stars of different magnitudes to one effective magnitude.
Yes, you would think so, just that i can't find any thus far.
If you can relate intensity to magnitude, that's a start. The two stars in a binary system are at the same distance. Do you have a formula for intensity and magnitude, or size and intensity with magnitude?
If two stars have the same magnitude, then together they would have twice the intensity as either one. If you had one star that doubled in intensity, what would happen to the magnitude?
Also, there should be a formula relating apparent and absolute magnitude.
There are a couple of ways to do this (I say a couple they are the same way effectively). One could remember that a difference in magnitude of 5 is the same as a factor of 100 in brightness. So you can work from there to find what difference in magnitude gives double the brightness. Surely you have been given some sort of formula in your notes relating to apparent magnitude?
by intensity do you mean brightness or luminosity??m-M = 5 logd -5
m2-m1 = 2.5 log (b1/b2)
That one will do.
It isn't magnitudes that add, but rather luminosities (the power of the star) or intensities (the power/detector area at the observation point) that will add.
You need to convert magnitude at least into relative intensity first. You have the absolute magnitude of a star given by
M = -2.5 log (L / L_sun) + 4.8 , where M is the absolute magnitude of the star, L is its luminosity and L_sun is the Sun's luminosity (the +4.8 is approximately the Sun's absolute magnitude, but the exact value isn't important at the moment, since it's going to drop out).
The difference between the absolute magnitude of two stars is then
delta-M = M1 - M2 = [ -2.5 log (L1 / L_sun) + 4.8 ] - [ -2.5 log (L2 / L_sun) + 4.8 ]
= -2.5 log (L1 / L_sun) + 2.5 log (L2 / L_sun) = -2.5 log (L1 / L2) = 2.5 log (L2 / L1) .
We can rearrange this to get
L2 / L1 = 10^(delta-M / 2.5) .
If the two stars you are comparing are at the same distance, then the difference in their absolute magnitudes is exactly the same as the difference in apparent magnitudes, so we can write
L2 / L1 = 10^(delta-m / 2.5) .
[Note: if you use the same instrumental set-up to observe both stars, the ratio of luminosities will be the same as the ratio of intensities, so we also have
I2 / I1 = 10^(delta-m / 2.5) .]
For convenience, we can pick as a reference value the luminosity or intensity of a zero-magnitude star, making our equation
Io / I1 = 10^( {m1 - 0} / 2.5 ) or I1 / Io = 10^( -m1 / 2.5 ) .
One of the stars in the binary system has m = 4.1 , so
I = 10^( -4.1 / 2.5 ) · Io .
So what is the intensity of two such stars together? Take this result and put it into the intensity equation to solve for the apparent magnitude of the system.
This really ought to be in your text someplace, but maybe the course hasn't reached it yet...
brightness as it relates to magnitude. Brightness is the luminosity we 'see', i.e. it's visual perception.
Wow, thank you very much for all your help.
1. What is a binary star system?
A binary star system is a system in which two stars orbit around a common center of mass. These stars are held together by gravity and appear to be close together in the sky, but in reality they may be separated by vast distances.
2. How are binary star systems formed?
Binary star systems are formed from large molecular clouds of gas and dust. As the cloud collapses due to gravity, it breaks up into smaller clumps of material. Some of these clumps become individual stars, while others become binary systems.
3. What is the difference between an optical and physical binary star system?
An optical binary star system is one in which the stars appear close together in the sky, but are actually far apart and not gravitationally bound. A physical binary star system, on the other hand, is one in which the stars are close enough to be gravitationally bound and orbit around a common center of mass.
4. What is the apparent magnitude of a star?
The apparent magnitude of a star is a measure of its brightness as observed from Earth. It is affected by the star's distance from Earth, as well as its size and temperature. The lower the apparent magnitude, the brighter the star appears to us.
5. How is the apparent magnitude of a star in a binary system affected?
The apparent magnitude of a star in a binary system can be affected by several factors. If the stars are close enough together, they may appear as a single point of light to us and their combined apparent magnitude will be different from their individual magnitudes. Additionally, if one star is much brighter than the other, it may dominate the overall apparent magnitude of the system.
  • Astronomy and Astrophysics
