Accelerating magnet and electromagnetic induction
In summary: This is the equation for magnetic induction, which states that the emf (voltage) is proportional to the change in magnetic field. When you accelerate the magnet, the magnetic field changes (increases) and this causes the emf to increase as well.
spidey
213
hi..i know the faraday's electromagnetic induction e=-dФ/dt...supposing there is an coil of wire and i am accelerating magnet through the coil of wire and this will produce emf because accelerating magnet results in change in magnetic field...my question is how to relate this acceleration a and change in magnetic field dФ/dt...i think these two should be proportional...anybody help me..
You would have to know details of the magnet's field strength as a function of location.
As long as the magnet's field varies with position (i.e. is not constant), the magnet just has to be moving. It need not be accelerating.
Yes as long as magnet's field varies, emf is generated..but if i vary the magnet's field by acceleration then can we relate the change in the magnet's field with acceleration...i think
e = -∂Ф/∂t α ∂v/∂t
-∂Ф/∂t α ∂v/∂t
is this correct?..do we have to introduce constant in the right hand side to make the two sides equal?..
No, not correct. It's proportional to v, not ∂v/∂t.
Hi Redbelly,
Actually,
e = -∂Ф/∂t α A(Acceleration)
therefore,
-∂Ф/∂t α ∂v/∂t [ A=∂v/∂t]
How it is proportional to v?..it should be proportional to ∂v/∂t..if this is wrong,please give correct solution and also do we have to add constant to remove proportionality?
spidey said:
Hi Redbelly,
Actually,
I see no basis for saying -∂Ф/∂t α acceleration here.
I wonder if you are confusing something, either:
A=acceleration vs. A=area of loop?
v=velocity vs. v=voltage?
Let x = position of the moving loop.
The loop experiences a changing B-field, which is
dB/dt = (dB/dx) (dx/dt)
Since v = dx/dt, there it is.
Do you have a book to look at that explains induced emf? They usually have some sample problems involving moving loops or magnets. Acceleration never comes up.
Thanks for clearing my doubt...can you suggest me any good book for electromagnetism? i am not physicist but interested to learn.
I like the book Physics, by Douglas C. Giancoli. It's a non-calculus based textbook. I've seen it used for both AP high school physics, and college physics for non-physics majors.
This stuff is in chapter 21 of the 5th edition.
For $24, you can get a used, paperback copy from amazon.com -- but this is a special edition that begins with Chapter 16. It contains all the electricity and magnetism chapters from the full book.
https://www.amazon.com/gp/product/0130352578/?tag=pfamazon01-20
Or, you could search on "induction" here:
And start reading at p. 622
dx/dt = v but what dB/dx = ?
I understand this is the change in magnetic field for distance dx... is there any term for db/dx like v=dx/dt.
Nope, just leave it as dB/dx. All it really says is B should not be constant (in space) in order to generate a change in flux this way.
A physics book will explain it much better, using figures, than I can.
Hi Redbelly,
I gone through "Electromagnetism and optics" An introductory course book. In that i find the motional emf which i was referring to. Below derivation was given there
l and x are dimensions. i.e. l*x is area.
Ф = Blx
dФ = Bldx
dФ = Blvdt
dФ/dt = Blv
e = Blv
but this holds for only constant velocity i think...but what happens if we accelerate i.e. if the v is increasing. Even for increasing v also the magnetic field changes. does for increasing v also the above equation holds good? Or do i have to differentiate v again like this.
d/dt (dФ/dt) = Bl dv/dt
d²Ф/dt² = Bla . here a -> acceleration.
but e = dФ/dt and e != d²Ф/dt²
what is this d²Ф/dt²? is this also changing magnetic field?
i am going somewhere.help me.i think i am confusing you.what i want is.in the book it is given for constant velocity.can we use that for increasing or decreasing v also? if so,no problem. but if it is not,how to include that increasing or decreasing v?
spidey said:
Ф = Blx
dФ = Bldx
dФ = Blvdt
dФ/dt = Blv
e = Blv
dФ/dt is the changing magnetic field, or more precisely, the changing magnetic flux.
Ф = Blx
dФ/dt = d(Blx)/dt = Bl(dx/dt).
In the last step, I assumed B and l were constant in this problem, and only x was changing. For a magnet moving at constant velocity or accelerating in some weird way, x will be a function of time, so we write it as x(t). You can find dx(t)/dt for any function x(t) you wish, and then find the corresponding dФ/dt.
spidey, it works fine for when v is changing too.
e = Blv (in your example) still holds true.
Thank you Redbelly and atyy...i got it...i have another question...
Emf is generated in a wire when there is change in magnetic field..supposing i don't place any wire and i am changing magnetic field i.e. am moving or shaking magnet..now this is also changing magnetic field but there is no wire nearby,so where will the emf go or where is the electric field? is it in air?
I understand the first equation for total flux of electric field
∫ E dA = (4∏ r²) * (Q /4∏e0 r²) = Q / e0
But I don't understand the maxwell's second equation∫ B dA = 0. we can also do derivation like for electric field.
∫ B dA = (4∏ r²) * (μ m/4∏ r²) = μm
In the book, the derivation is not given and i couldn't find any derivation in websites also..all sites directly give this result...how maxwell derived this ∫ B dA = 0?
The emf is always generated in "empty space". If you happen to place a wire in the right position in "empty space", the free electrons in the wire will move in response to the emf.
∫ E dA = Q / e0
Roughly speaking, the LHS is an electric field, the RHS is charge, so it says a charge produces an electric field. Now if you place a positive and negative charge together, the RHS will be zero, and the total electric flux through any surface surrounding both of them will also be zero. So this equation requires that you can separate positive charge from negative charge.
∫ B dA = 0
Thinking in the same way, the above equation says that you cannot separate "positive magnetic charge" from "negative magnetic charge", all magnets always come with a north and south pole. If you cut the magnet into two pieces, you will generate two magnets, each with their own north and south poles. If we ever found a magnetic monopole, this equation would have to be modified.
emf in empty space is weird to me. in empty space there are no charges,then how there is motion of charges for an emf.
i understand for flux of electric field. Are you saying since magnets come with north and south combined,there is no flux in closed surface? if there is no flux then it means that there is no magnetic field,isnt it?
Emf is just electric field integrated along a line. The electric field can exist in empty space. When you put a charge in the field (eg. by putting a wire in the right place), the charge will move in response to the electric field.
Gauss's law says there is electric flux through a closed surface only if it encloses a charge. So if you imagine your closed surface for an electromagnetic wave propagating in empty space, the flux will be zero (since it's empty space), but the field is not zero (otherwise there's no wave). It just means that the geometry of the electric field is such that electric flux going into some part of the imaginary surface is balanced by electric flux coming out from some other part of the surface.
I have doubt regarding flux and field..how the flux is zero and field is not zero? what is the difference between the flux and field?
The field is an arrow at every single point in space.
The flux is the total "number" of arrows piercing your imaginary surface in space. If the "number" of arrows going in is the same as the "number" of arrows coming out, then although none of the arrows are zero, the flux can be zero.
Thanks for the info..so for magnetic field,if we place an imaginary surface around a magnet,the flux going out from north pole is also coming into south pole,so the total flux is zero...is there any theory which explains why the magnet is always dipole?
One can show that magneticically charged particles, so called magnetic monopoles, do exist in the sense that they can in principle be produced. But they must be very heavy, so they can't be produced inparticle accelerators. However, they did pose a problem for theories of the early universe, because if you go back long enough in time, the temperature of the universe was high enough for monopoles to be produced. It then turns out that so many monopoles would be produced that the universe should have collapsed a long time ago.
This problem was solved by inflation theory, http://en.wikipedia.org/wiki/Cosmic_inflation"
1. How does accelerating magnet affect electromagnetic induction?
When a magnet moves or accelerates, it creates a changing magnetic field around it. This changing magnetic field induces an electric current in a nearby conductor, according to Faraday's Law of Induction.
2. Can electromagnetic induction be used to generate electricity?
Yes, electromagnetic induction is the process of generating electricity from a changing magnetic field. This principle is used in generators and transformers to convert mechanical energy into electrical energy.
3. What factors affect the strength of electromagnetic induction?
The strength of electromagnetic induction is affected by the speed of the magnet, the strength of the magnetic field, the distance between the magnet and conductor, and the properties of the conductor such as its material and geometry.
4. How can we increase the rate of electromagnetic induction?
The rate of electromagnetic induction can be increased by increasing the speed of the magnet, increasing the strength of the magnetic field, or using a more conductive material for the conductor. Additionally, using a coil or increasing the number of turns in the conductor can also enhance the rate of induction.
5. What are some real-world applications of accelerating magnet and electromagnetic induction?
Some real-world applications of accelerating magnet and electromagnetic induction include generators, transformers, induction cooktops, electric motors, and magnetic levitation systems. These principles are also used in many modern technologies such as wireless charging and electromagnetic braking systems.
  • Electromagnetism
  • Electromagnetism
