Yau's result for the Ricci curvature on Kahler manifold
In summary: I likely know less than you on this subject but it turns out Peter Bergmann had some comments in THE RIDDLE OF GRAVITATION which I just read a few days ago: The twenty components of the (Riemann-Christoff) curvature (tensor) in a four dimensional space can be group
schieghoven
85
Hi,
I've been reading through Yau's proof of the Calabi conjecture (1) and I was quite intrigued by the relation
[tex]
R_{i\bar{j}} = - \frac{\partial^2}{\partial z^i \partial \bar{z}^j } [\log \det (g_{s\bar{t}}) ]
[/tex]
derived therein. [tex]g_{s \bar{t} } [/tex] is a Kahler metric on a Kahler manifold (I'm not entirely sure what that entails... I'm working on the assumption that it's like a complex version of a Riemannian metric.) [tex]R_{i\bar{j}}[/tex] is the Ricci curvature of said metric. I find it remarkable that the Ricci curvature is so readily computed for these Kahler manifolds. I've never seen a comparably simple relation in Riemannian geometry - I don't think there is one, right? Why would this be? What's different between Kahler manifolds and Riemannian manifolds that makes this result possible in the Kahler case?
I'm also wondering to what extent Yau's result can cross over to Riemannian geometry. If I understand the paper correctly, Yau has basically solved the inverse problem of finding the Kahler metric that corresponds to a given Ricci form. In Riemannian geometry, we might pose a similar question: if R_ij is a symmetric matrix (that satisfies some criterion following from the Bianchi identities), is it the Ricci tensor for some Riemannian metric g'? Is g' unique?
To me this is a tantalising question, because at least at some level, Einstein's equations for GR are posing a very similar problem, of finding the Riemannian metric that solves for a given stress-energy field.
(1) Yau, Commun. Pure Appl. Math. 31 (1978) 339
Thanks,
Dave
The twenty components of the (Riemann-Christoff) curvature (tensor) in a four dimensional space can be grouped into two sets of ten components each, in a manner that is independent of any choice of coordinate system. One of these two sets involves the turning of vectors in the course of parallel transport...this set is usually referred to as the Ricci tensor...in a slight rearrangement the Ricci tensor may be called the Einstein vector. The..other ten components form..Weyl's tensor...the totality of of all components of curvature is called the Riemann-Christoff curvature tensor...
The author makes it sound like dealing with ten at a time is a lot simpler than dealing with twenty, especially making transformations from one coordinate system to another as the two tensors behave very differently...
hope this helps a little.
Cheers, thanks for the tip, you may well be right that the Weyl tensor and conformal transformations come into it somehow. Perhaps if I start writing things out it'll be clearer. Does anybody know offhand how the Ricci tensor changes under a conformal transformation?
Regards
Dave
Kähler manifolds are hermitian manifolds with closed Kählerform. The Kählerform looks like the metrik tensor but is antisymmetric. if you impose that the exterior derivative of the kählerform vanishes you find that the metric can locally be expressed by the Kählerpotential. So if you got a Kählerpotential, the metric follows and with this the connection and the riemann tensor. i think this is basically the idea. you can take a look at nakahara...
hope this gave you an idea
More from Peter Bergmann:
A Minkowski continuim may be conformally transformed to a curved continuium...one aspect remains unchanged by conformal transformations...that is the space like,time like or lightlike caharacter of each interval and direction...Weyl discovered that, under a conformal transformation, the Ricci tensor and the Weyl tensor behave very differently...The Ricci tensor changes in a very complicated way (which includes the possibility that it may vanish before the conformal transformation but be non zero after the transformation; the Weyl tensor remains unchanged.
I have no idea what that means, but it doesn't sound encouraging! good luck...
Hi, I am a mathematician and I know a little bit about what you are talking about. An excellent book, is Einstein manifolds by Arthur Besse, this is a must. In this book, he explicitly computes how the full curvature tensor, the Ricci tensor, the Weyl tensor, change under a conformal change in the metric. He also talks about the Calabi-Yau problem.
Regards
Heberto
Regards
Dave
1. What is Yau's result for the Ricci curvature on Kahler manifolds?
Yau's result is a theorem in differential geometry that states that on a compact Kahler manifold, the Ricci curvature is bounded below by a negative constant.
2. How does Yau's result relate to the geometry of Kahler manifolds?
Yau's result is important in the study of Kahler manifolds because it provides a lower bound for the Ricci curvature, which is a measure of the curvature of the manifold. This bound has important implications for the geometry and topology of the manifold.
3. What is the significance of a negative lower bound for the Ricci curvature on Kahler manifolds?
A negative lower bound for the Ricci curvature on Kahler manifolds implies that the manifold has negative curvature in some regions. This has important consequences for the behavior of geodesics and the topology of the manifold.
4. Are there any applications of Yau's result for the Ricci curvature on Kahler manifolds?
Yes, Yau's result has many applications in mathematics and physics. It has been used in the study of minimal surfaces, complex geometry, and the Ricci flow. It also has connections to string theory and the study of black holes.
5. What are the assumptions and limitations of Yau's result for the Ricci curvature on Kahler manifolds?
Yau's result assumes that the manifold is compact and Kahler, which means it has a complex structure that is compatible with its Riemannian metric. It also assumes that the manifold has finite total volume and a non-negative first Chern class. These assumptions limit the applicability of the theorem to a specific class of manifolds.
  • Science and Math Textbooks
  • Differential Geometry
